Orbi WiFi 7 RBE973
Reply
GS724T unable to read the MAC address using SNMP
Cristinasust
Tutor
I connect a device with a MAC on port 1 of the switch. Normally I used a MIB library called BRIDGE-MIB that if I put the OID to find the port followed by the MAC I am looking for, in decimal, the switch would respond with the port to which the MAC was connected.
The problem is that this does not work for me. If I connect via webserver, I see the MAC connected. There is a list of compatible MIBs, and the BRIDGE-MIB is not in the list.
I do not know if anyone knows which library of the compatible MIBs can find the MAC , or how I can do it so that the BRIDGE-MIB library works.
I communicate with the switch through a Kepware SNMP driver.
Model: GS724T|24-port Gigabit Smart Switch
Message 1 of 6
Accepted Solutions
Cristinasust
Tutor
Re: GS724T unable to read the MAC address using SNMP
Finally I solved with the following OID:
1.3.6.1.2.1.17.7.1.2.2.1.2.1.0.64.157.62.182.191
where 0.64.157.62.182.191 is the MAC address of my device.
Thanks for your help.
Message 5 of 6
All Replies
DaneA
NETGEAR Employee Retired
Hi @Cristinasust,
Welcome to the community! 🙂
What is the exact model of the GS724T switch you have?  Also, what is the current firmware version of it?
If ever you have the GS724Tv4 switch, it latest firmware version is v6.3.1.19 that can be downloaded here and its corresponding MIB v6.3.1.19 can be downloaded here.
Also, you may want to try using the NMS300 which is a network management software by NETGEAR to isolate the problem.  You can download its latest version 1.6.0.3 here and its documentation here.
DaneA
NETGEAR Community Team
Message 2 of 6
Cristinasust
Tutor
Dear DaneA,
Yes, I have this version and this firmware. I have also the MIB libraries, but I don't know wich one to use if i want to read the MAC address.
Is it necessary the software that you mentioned?
Thank you,
Cristina
Message 3 of 6
DaneA
@Cristinasust,
Thanks for the feedback.  To isolate the problem, kindly try using the NMS300 and check if you can accomplish your goal.
DaneA
Message 4 of 6
Cristinasust
Tutor
Message 5 of 6
DaneA
@Cristinasust,
Thanks for the update.  I'm glad to know that the problem got resolved. 🙂
Since your concern is now resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2459 views
  • 1 kudo
  • 2 in conversation
Announcements
