Orbi WiFi 7 RBE973
Reply
MS510TX - Ports 10Gb in normal mode ?
Boboss
hi,
I want to buy a switch MS510TX.
Can uplinks ports be used in normal mode?
example:
SFP + (10Gb) for 10GB internet input
RJ45 (10Gb) to connect the computer
thanks
Model: MS510TX|8-port Multi-Gigabit Ethernet Smart Managed Pro Switch with 10G Copper / 10G SFP+ Fiber Uplinks
Message 1 of 6
Accepted Solutions
LaurentMa
NETGEAR Expert
Re: MS510TX - Ports 10Gb in normal mode ?
Yes, of course you can connect PCs, Nas, Webcam or TV etc.
An uplink is a standard Ethernet port that can be used as any other port on the switch, for local devices, or used as an aggregation link (faster speed) to transport other devices' traffic to a core, for instance. I hope this helps
Message 5 of 6
All Replies
LaurentMa
NETGEAR Expert
Hi Boboss
Sure, you can.
Not sure what you meant as abnormal mode, these two 10G ports, one Copper and one Fiber, only work as standard Ethernet ports. Hope this helps
Message 2 of 6
msi
Luminary
Luminary
Hi Boboss
What exactly do you mean by "normal mode"?
On that switch the hardware install guide for example mentions that the last 2 ports are independent. For comparison: There are switches (I remember several M4100's) where there are 2 physical ports, such a RJ45 and SFP but only one of them can be active at any given time. On that switch both ports should be usable when the other one is.
If you want to connect your internet feed directly to the switch (i.e. you have a SFP Module for FTTH from your porovider) and don't want your router before that you'd have to configure VLANs. I can give more details on that if that applies to your use case.
Message 3 of 6
Boboss
my question is rather:
What is an uplink port?
can I use these 2 "uplink ports" as standard ports to connect any device (computer, NAS, webcam, TV ...) ?
Message 4 of 6
LaurentMa
NETGEAR Expert
Message 5 of 6
Boboss
Thanks a lot for your answers Laurent and Msi 🐵
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1659 views
  • 1 kudo
  • 3 in conversation
Announcements
