- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SFP RJ45 1GB Not Work on GC110 Switch
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi ,
I have GC110 , And I have Tried RJ45 Gbics SFP 1GB from different Company Generic and Not Work on Switch.
Could someone will advice to me which Generic 3D Party work SFP RJ45 On This GC110 Last Firmware ?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SFP RJ45 1GB Not Work on GC110 Switch
We've deployed "generic*", Netgear and Cisco Gigabit RJ45 SFP modules eg. in GC510 (e.g. SwissGBIC). On the GC110, we have only Netgear and Cisco "original" SFP fiber modules active.
From Netgear's compatibility list on the data sheet:
Optional Modules and Accessories
AGM731F-10000S SFP Transceiver 1000BASE-SX (Short range, multimode)
AGM732F-10000S SFP Transceiver 1000BASE-LX (Long range, single mode)
AGM734-10000S SFP Transceiver 1000BASE-T Copper RJ45 GBIC
For the records: SFP+ 10G/MultiGig capable or SFP+ DAC are not compatible with standard SFP ports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@schumaku wrote:We've deployed "generic*", Netgear and Cisco Gigabit RJ45 SFP modules eg. in GC510 (e.g. SwissGBIC). On the GC110, we have only Netgear and Cisco "original" SFP fiber modules active.
Thanks You Very much .
Could you please Give me a link on amazon to buy Original Cisco SFP RJ45 That will work ON GC110 ?
I have try Cablematter /10gtek / Ubquiti SFP RJ 45 1GB That said compatible to Netgear :"AGM734-10000S SFP Transceiver 1000BASE-T Copper RJ45 GBIC" but non of them work on The last Firmware , why is that ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No idea what is going on there.
Original Cisco SFP's might easy break your wallet. No need to focus because the Cisco fiber SFP modules are workable in my deployments.
The most easy option would be using an original AGM734-10000S SFP Transceiver 1000BASE-T Copper RJ45 GBIC - because this is (in my understanding) the module that should work and where we can force Netgear to provide support.
Not sure how you understand "compatible" modules - Ubiquity ones are customized for their devices for example. A "compatible [workable]" unit would be some no-name SFP module, with a vendor and product ID in the flash matching to the Netgear model.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@schumaku wrote:No idea what is going on there.
I have bougt Copper SFP RJ45 1GB of two Companies that Support Netgear AGM734 :
1)10GTEK
2)CableMatters
https://www.amazon.com/dp/B01FRQJ1Y2
"1.25G SFP-T, 1000BASE-T Copper SFP, SFP to RJ45 SFP, Compatible with Netgear AGM734"
Non of them work on the Latest Versions , when you connect them you get Loop Failure ( UP DOWN UP DOWN ... )
I see earlier posts in forum from 1 year and more and many people have this problem.
Netgear Adapter - Cost 3 Times of my switch , I can't afford that especially when I need 2/3 Pieces .
I would be happy that you help me to solve this . I have bought some pieces of GC11O Switches and this is very disappointing to know that I can't use this 2 extra Ports .
Thanks you alot for your support .
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, we'll investigate this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@bbl_1 wrote:Thank you, we'll investigate this.
Thanks You Very Much ,
I will wait for your response ,
Have an excellent day .
This is another link for another adapter that compatible but not work :
Cable Matters 1000BASE-T Gigabit SFP to RJ45 Copper Ethernet Modular Transceiver for Cisco, Ubiquiti, TP-Link, Huawei, Mikrotik, Netgear, and Supermicro Equipment
https://www.amazon.com/Cable-Matters-1000BASE-T-Transceiver-Supermicro/dp/B07TXRYJGF/
User | Count |
6 | |
2 | |
1 | |
1 | |
1 |
