Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Setup of SFP port
MCASTILLO
Setup of SFP port
Hi,
I am trying to connect  a 1g SFP module on ports 49-52 with another switch B ( not netgear)
The cable I am using is  FS DAC  40G  (QSFP)-> 4x10G.(SFP)
I know that GS348T support only 1G so I setup 1 G on Switch B, and it shows link up, however Netgear shows link down.
Any clue what could be the problems?
Thanks
Model: GS348T|NETGEAR® S350 Series 48-Port Gigabit Ethernet Smart Managed Pro Switch with 4 SFP Ports
Message 1 of 2
schumaku
Guru
Re: Setup of SFP port
Essential correction: QSFP+ to 4x10G SFP+ Passive Direct Attach Copper Breakout Cable.
It's SFP+, not SFP. SFP+ is not equal to SFP, even if the physical dimensions are the same.
Similar, you can't use a SFP+ DAC to connect two switches with 1G SFP ports each - for this very same reason.
Just to clarify: You can run an SFP+ port on 1G under some conditions (typical example is plussign an SFP module) - but it's still an SFP+. However, you can't run an SFP+ module in a 1G SFP plort.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3187 views
  • 0 kudos
  • 2 in conversation
Announcements
