Orbi WiFi 7 RBE973
What is the result of selecting "DHCP" mode for JGS524PE ?
cybr-g
Hi, the JGS524PE has a "DHCP" option that can be activated of disabled.
But the documentation does not explain much more on the result of this activation.
More precisely I would like to know when the "DHCP" option is activated, does it activate a DCHP server on the JGS524PE or on the contrary, it makes the JGS524PE ask its IP to the DHCP server of the network ?
I think the way the option is presented is very obscure for new customers like me.
I have put a screenshot of the config page illustrating the option menu
Model: JGS524PE|ProSafe Plus 24 ports switch with PoE
Message 1 of 4
Accepted Solutions
schumaku
Guru
Re: What is the result of selecting "DHCP" mode for JGS524PE ?
Quickly fly over the fine documentation Gigabit Ethernet Smart Managed Plus Switches User Manual valod for Models GS105Ev2 GS105PE GS108Ev3 ... starting from p.15 - it's always about the IP config assigned to the switch by it's DHCP client, served from a DHCP server on the network.
No Smart Managed Plus or Smart Managed Pro switch does contain a DHCP server for one or multiple VLANs.
Message 2 of 4
All Replies
schumaku
Guru
Message 2 of 4
cybr-g
Thank you for your answer.
I was confused by the default 192.168.0.239 configuration IP.
This IP changes accordingly after network DHCP configuration or user static IP configuration.
Message 3 of 4
schumaku
Guru
The default is DHCP, in case the DHCP request is not honoured, the switch does fall-back to the 192.168.0.239/24 address. This can be useful for an initial config of a switch purely standalone and connected to a computer.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 8152 views
  • 1 kudo
  • 2 in conversation
Announcements
