× Get free training on Switching for AV over IP and receive AVIXA Credits. Sign up at NETGEAR.academy
Reply
onboarded M4250 has no configured profiles
steinyvision
I am using Engage Controller to manage seven M4250 switches.  Six of the switches appear to have onboarded properly, but the seventh does not show the configured profiles on its Configure page.  How can I get that switch to show the configured profiles?
M4250-26G4F-PoE+ (GSM4230P) #Engage
Message 1 of 4
Accepted Solutions
MikeD1234
NETGEAR Expert
Re: onboarded M4250 has no configured profiles
Hi @steinyvision,
it might be, that during the onboarding, something didn't completely sync to the switch.
This doesn't occur often, but, to resolve this, can you remove the switch from your device list:
And once it's removed, can you re-add it back to Engage:
It should then sync all the profiles correctly.
Additionally, make sure you have the latest version of Engage running, you can download the latest version through the link below:
Engage Controller | NETGEAR Support
But, you can also upgrade through the controller itself, it should advise you that there is a newer version, but, if the controller is open, then you can go to Controller Management:
Then, top-right, you have an option showing "Update Available", if you click this, you'll be greeted with the following window:
You can then download and upgrade, and it'll open with the new version.
Let us know how you got on with this, and/or, how you solved the issue.
Thank you,
Mike
Message 2 of 4
All Replies
MikeD1234
NETGEAR Expert
Hi @steinyvision,
Thank you,
Mike
Message 2 of 4
steinyvision
It worked! I removed and then added back that switch, updated the firmware, and now the profiles appear.  Thank you!
Message 3 of 4
MikeD1234
NETGEAR Expert
Hi @steinyvision,
Great to hear it's fixed!
We also have our ProAV Design team always available, @ proavdesign@netgear.com, if you run into any issues.
Have a good weekend!
Mike
Message 4 of 4
Discussion stats
  • 3 replies
  • 4969 views
  • 1 kudo
  • 2 in conversation
Announcements
AV over IP Switches by NETGEAR
