Orbi WiFi 7 RBE973
Reply
FOLDER ICONS; WHAT DO THEY INDICATE?
GPSIS_HQ
Guide
Hello all...I'm back again,
Can anyone explain the icons on the folders inthe ReadyCLOUD Desktop Client?
I've shared several folders, some on an external drive and some on the local laptop drive.
Some have what appears to be an icon of a clock, and the other an icon of a fwd & back arrow.
Anyone know what they indicate, or where I can find the information?
Regards!
Model: RN204|ReadyNAS204
Message 1 of 4
Accepted Solutions
GPSIS_HQ
Guide
Re: FOLDER ICONS; WHAT DO THEY INDICATE?
Ok great! Thank you!
I guess I should reevaluate the clock folders; I want them all to sync the changes.
Thanks for the assist!
Regards
Message 3 of 4
All Replies
JennC
NETGEAR Employee Retired
Hello GPSIS_HQ,
The one with the icon that looks like a clock is a folder that is set to backup with a PC while the one that has an icon that of 2 arrows is a folder that is set to sync with the PC. Backup with the PC is set when you want to backup a folder from the computer to the NAS, the SYNC option is ReadyCloud will create the same folder in the computer's main volume's ReadyCloud folder, this will copy whatever you save in the ReadyNAS' folder to your computer.
I hope this answers your question.
Message 2 of 4
GPSIS_HQ
Guide
Regards
Message 3 of 4
JennC
Hello GPSIS_HQ,
To properly close the topic, please select the response that answered/solved the concern you have raised.
We appreciate your contribution to the community!
Message 4 of 4
Discussion stats
  • 3 replies
  • 3307 views
  • 1 kudo
  • 2 in conversation
Announcements
