Orbi WiFi 7 RBE973
Reply
VPN Disconnected as of 2017-05-25
davesumm
Luminary
I'm currently Online (VPN disconnected) again. Is this an anomaly or is there yet another Netgear fail?
Model: RN10200|ReadyNAS 100 Series 2-Bay (Diskless)
Message 1 of 10
Accepted Solutions
davesumm
Luminary
Re: VPN Disconnected as of 2017-05-25
Turns out all i needed to do was restart the desktop client 😛
Message 9 of 10
All Replies
Retired_Member
Not applicable
Hello Davesumm
can you please check if Leaf network interface of your Windows has obtained IP address from server?you can go to Network and Sharing Center>Change Adapter Setting>Leaf  Networks Adapter>Details,correct IP should be 5.*.*.*,have you installed any firewall application on your Windows?
Message 2 of 10
davesumm
Luminary
I have an IP address beginning with 5 and no, I haven't installed any firewall. Was working fine earlier and now it's gone **bleep**-up
Message 3 of 10
Retired_Member
Not applicable
Can you reboot the NAS?I just connect to  my NAS and able to  get VPN connection
Message 4 of 10
davesumm
Luminary
I rebooted the NAS 5 minutes after I created this thread. Problem existed so I checked readycloud on the web and there was a firmware upgrade. I downloaded & rebooted it but it didn't fix the problem
Message 5 of 10
Retired_Member
Not applicable
Can you send logs? thanks
Message 6 of 10
davesumm
Luminary
I am at work so I can't access the logs until I get home, which is also where my NAS lives.
Message 7 of 10
davesumm
Luminary
There was nothing unusual in the logs. Same old **bleep**e as from days previous
Message 8 of 10
davesumm
Luminary
Message 9 of 10
davesumm
Luminary
Broken again FFS!
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 7773 views
  • 0 kudos
  • 2 in conversation
Announcements
