× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
4.1.8-T5: Frontview stops responding
dnikkel
I installed 4.1.8-T5 on my ReadyNAS Duo so I could run Time Machine on my new Macbook Air. Time Machine is running fine. I also did my first ReadyNAS backup to USB disk and that went fine as well. However, I've had several instances where Frontview stopped responding. Raidair can still find the ReadyNAS and report all status details. I can still access the disks over the network. Everything seems fine, except I can't access Frontview. The only way I can get it back is to go to the ReadyNAS and do a "press power for 5 seconds" physical reboot, which goes fine with no errors logged. I'm not sure what sequence of events actually causes Frontview to stop responding. Oh, and even doing an smb:// responds normally. So it's really like the http:// listener has packed it in.
Message 1 of 3
yoh-dah
Guide
Re: 4.1.8-T5: Frontview stops responding
Can you send your logs (see my sig)?
Message 2 of 3
dnikkel
Sure, no problem. I've emailed the logs to your attention. Frontview has been working normally since my original post, including after I did an incremental backup to USB drive last night. So whatever was triggering the issue have not happened for some days now.
Dave
Message 3 of 3
Discussion stats
  • 2 replies
  • 4579 views
  • 0 kudos
  • 2 in conversation
Announcements
