× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
*OLD* ReadyNASOS 6.1.9 [RC11] *OLD*
Skywalker
NETGEAR Expert
Latest beta: ReadyNASOS 6.1.9-RC11
To install: Click on appropriate link above for your system to download firmware image.
Then upload that image from the management UI's System->Settings->Update->Install Firmware section.
Notable changes since ReadyNASOS 6.1.8
1. [RC1] Update kernel with various filesystem and iSCSI improvements.
2. [RC2] Make Richcomm-based UPS devices work.
3. [RC2] Add DLNA support for FLV.
4. [RC2] Avoid issue with too many open file descriptors in some odd AD environments.
5. [RC3] Various security updates. (OpenSSL, GNUTLS)
6. [RC4] Fix periodic log truncation.
7. [RC5] Add UI option to configure sync policy for iSCSI LUNs.
8. [RC6] Disable deprecated SSLv2 for admin UI.
9. [RC6] Fix Bonjour advertisement of SMB service.
10. [RC7] Various kernel security updates.
11. [RC8] Various package security updates.
12. [RC9] Avoid potential flash corruption on some desktop x86 models after update, which can show up during factory default.
13. [RC9] Fix defrag operation so it doesn't try to defrag snapshots.
14. [RC10] Minor filesystem improvements.
15. [RC10] Various security updates.
16. [RC10] Change to Rsync backup job path requirements. If destination is a folder within a share it must be included in the destination path.
17. [RC11] Revert previous rsync change, to avoid a silent change in behavior.
18. [RC11] Fix app installation with when pulling packages from certain repositories.
Message 1 of 5
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.1.9 [RC5]
Posted 6.1.9-RC5.
Message 2 of 5
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.1.9 [RC8]
Posted 6.1.9-RC8.
Message 3 of 5
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.1.9 [RC10]
Posted 6.1.9-RC10.
Message 4 of 5
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.1.9 [RC11]
Posted 6.1.9-RC11.
Message 5 of 5
Discussion stats
  • 4 replies
  • 7825 views
  • 0 kudos
  • 1 in conversation
Announcements
