× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
*OLD* ReadyNASOS 6.7.0-T206 (Beta 4) *OLD*
Skywalker
NETGEAR Expert
Latest beta: ReadyNASOS 6.7.0-T206 (Beta 4)
• ARM (102 / 104 / 2120 / 202 / 204 / 212 / 214)
• x86_64 (312 / 314 / 316 / 422 / 424 / 516 / 524 / 526 / 528 / 626 / 628 / 716 / 3130 / 3220 / 3312 /...
To install: Click on appropriate link above for your system to download firmware image.
Then upload that image from the management UI's System->Settings->Update->Install Firmware section.
New Features
  1. Expanded Flex-RAID configuration options
    • RAID 50 and 60 support
    • Support for adding disks to existing RAID arrays
    • Explicit Global Hot Spare support
  2. SAS Expansion support for RR3312 and RR4312 (requires addon card)
  3. Google Drive cloud sync support
  4. Amazon AWS cloud sync support
Changelog
  1. [Beta 1] Updated to Linux kernel version 4.4.
  2. [Beta 1] Updated to Dropbox v2 API.
  3. [Beta 1] ReadyNAS Apps can now add third party package repositories from the app.
  4. [Beta 1] ReadyNAS Apps now show more progress information during the installation process.
  5. [Beta 1] Added support for several new ReadyNAS models.
  6. [Beta 1] Updated AV to prevent some false postitive reports.
  7. [Beta 1] Fixed ReadyDR support for long snapshot names.
  8. [Beta 1] Removed unnecessary user and share naming restrictions (c_, m_, b_, and r_).
  9. [Beta 1] Added more thorough checks to prevent protocol port conflicts.
  10. [Beta 1] Fixed issue where switching network configuration from DHCP to Static would lose DNS settings.
  11. [Beta 1] Added the ability to completely disable volume quota support.
  12. [Beta 1] Fixes for various security vulnerabilities.
  13. [Beta 1] Fixed an issue where iSCSI may not reconnect after a network interruption with static IPs on ReadyNAS.
  14. [Beta 2] Fixed an issue where disk spindown may refuse to be disabled.
  15. [Beta 2] Added some missing strings.
  16. [Beta 2] Restored snapshot and share capacity display when quotas are enabled.
  17. [Beta 2] Fixed an issue where leaving ReadyCLOUD may cause you to not be able to re-join with the same account.
  18. [Beta 2] Fixed potential package database errors when updating from 6.6.1.
  19. [Beta 2] Many bug fixes in cloud storage services.
  20. [Beta 3] Fixed additional package database errors when updating from 6.6.1.
  21. [Beta 3] Added migration support from Dropbox v1 to v2 API.
  22. [Beta 3] Fixed SNMP filesystem support.
  23. [Beta 3] Fixed occasional incomplete removal of visible snapshot directories when removing snapshots.
  24. [Beta 3] Fixed false PSU removal alerts on units with multiple PSUs.
  25. [Beta 3] Relax requirements for SNMP community string.
  26. [Beta 4] Fixed unresponsive front panel wheel buttons. (RN316)
  27. [Beta 4] Fixed unresponsive backup button. (RN314)
  28. [Beta 4] Fixed a bug where plugging and unplugging a USB drive may enable FTP sharing on it.
  29. [Beta 4] Fixed an issue where DLNA or other services may not notice file changes.
  30. [Beta 4] Fixed an issue where new ReadyDR access keys could not be uploaded.
  31. [Beta 4] Many cloud storage fixes.
  32. [Beta 4] Fixed new Flex-RAID expansion options.
WARNINGS:
  • Unless you are advised by NETGEAR Support in a support case to update to beta software, NETGEAR Support may deny support if you are running beta software. You can seek help here on the NETGEAR Community for issues encountered on the beta.
  • Devices updated with 6.7.0 firmware should not be downgraded to earlier firmware versions.
  • ReadyNAS 102, 104, and 2120 must not be updated directly to 6.7.x from 6.3.x or older firmware.  They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.7.x.
  • ReadyNAS 202, 204, 212 and 212 must not be updated directly to 6.7.x from 6.3.x. They must first be updated to 6.3.5 then 6.5.2 and then onto 6.7.x.
KNOWN ISSUES:
  • Existing Dropbox settings will need to be reconfigured on the new Dropbox v2 API.
Message 1 of 3
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.7.0-T180 (Beta 3)
Posted 6.7.0-T180 (Beta 3).
Message 2 of 3
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.7.0-T206 (Beta 4)
Posted 6.7.0-T206 (Beta 4).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 10196 views
  • 6 kudos
  • 1 in conversation
Announcements
