× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
4.1.8-T5 Transmission add-on doesn't work
boywithumbrella
I've upgraded to Mac OS X 10.7 Lion today and - correspondigly - upgraded my ReadyNAS Duo to the RAIDiator 4.1.8-T5 beta, that adds Lion AFP support.
File transfer works fine, but now the Transmission add-on doesn't work.
I've been using the 2.31 version of the add-on (newest but for the 2.32 beta2). After the reboot following the firmware upgrade Transmission didn't start. I tried starting it from FrontView and received the generic error "Transmission add-on failed to start".
I tried reinstalling it - removing went fine, but when I tried to install it again, I received the error "Update file is not valid for this architecture." - I am however sure, that I'm using the same .zip-file I used last time to upgrade Transmission to v2.31 - and even more sure the architecture of my ReadyNAS did not change overnight 😃
Same error for the 2.32 beta2 btw
Any thoughts on what I could do about it?
Is the 4.1.8 T5 beta screwing up the architecture detection, because the newer netatalk code has been ported from x86? o_O
Message 1 of 20
mdgm-ntgr
NETGEAR Employee Retired
Re: 4.1.8-T5 Transmission add-on doesn't work
Could you reboot the ReadyNAS then try installing the add-on again?
If that doesn't work try a firmware/OS re-install (http://www.readynas.com/kb/faq/boot/how_do_i_re-install_the_firmware) then attempt to install the add-on again.
Message 2 of 20
boywithumbrella
no luck after a reboot, will try a firmware reinstall now...
Message 3 of 20
spoot
did the firmware reinstall work for you? having the same issue.
Message 4 of 20
mdgm-ntgr
If it doesn't work there's three possibilities:
1. An issue with your system
2. A compatibility issue with the Transmission add-on and the beta firmware.
3. An issue with the beta firmware that needs to be addressed.
Do you have any other add-ons installed?
Do you have SSH access to your NAS?
Message 5 of 20
boywithumbrella
I'm waiting for the firmware to reinstall. In the meantime:
I think p. 1 would be less likely than p. 2 or 3, because up to the upgrade to the beta everything seemed to work.
I have the PHP v1.3 and DynDNS v1.0 add-ons installed.
SSH is enabled on my NAS, but that is another thing that broke with Lion (Terminal throws error "'xterm-256color': unknown terminal type.", seems that the server - the NAS in this case - is missing an nurses package http://www.osterman.com/wordpress/2011/ ... minal-type)
Message 6 of 20
spoot
MysqlOn 1.0
php5
Wget4Web 1.4
yes for ssh
Message 7 of 20
boywithumbrella
same error after firmware reinstall
guess I'll have to use the spare MacBook for my torrenting needs (Lion auto-corrects 'torrenting' into 'tormenting' %) ) for the time being.
Still hopeful there will be a fix...
Message 8 of 20
spoot
thanks for the update. I'm actually still on 10.6.... debating on the lion update for now.
Message 9 of 20
mdgm-ntgr
What do you get if you do the following?:
ls -la /tmp
Message 10 of 20
boywithumbrella
Arikel:~# ls -la /tmp
total 20832
drwxrwxrwt 2 root root 16384 Jul 22 03:15 .
drwxr-xr-x 22 root root 16384 Jul 22 03:15 ..
-rw-r--r-- 1 root root 10 Jul 22 03:12 .dhcp_server
-rw-r--r-- 1 admin admin 21258752 Jul 22 03:15 update_file
Message 11 of 20
spoot
nas_server:/# ls -la /tmp
total 21536
drwxrwxrwt 3 root root 16384 Jul 21 20:55 .
drwxr-xr-x 23 root root 16384 Jul 21 21:10 ..
drwxr-xr-x 2 root root 16384 Jul 21 20:21 addons
-rw-r--r-- 1 root root 207141 May 26 18:45 config.zip
-rw-r--r-- 1 root root 12 Mar 14 20:14 .dhcp_server
-rw-r--r-- 1 root root 0 Jul 15 01:14 errors_001.log
-rw-r--r-- 1 root root 11563 May 25 2010 evdns.3
-rw-r--r-- 1 root root 17705 May 25 2010 event.3
-rwxr-xr-x 1 root root 45502 May 25 2010 event_rpcgen.py
-rwxr-xr-x 1 root root 220129 May 25 2010 libtool
-rw-r--r-- 1 root root 2119 May 20 07:22 settings_empty.json
-rw-r--r-- 1 root root 2063 May 20 07:22 settings.json
-rw-r--r-- 1 root root 0 Jul 21 19:06 smtp_providers
-rw-r--r-- 1 root root 90624 Jun 18 2010 Thumbs.db
-rw-r--r-- 1 admin admin 21258752 Jul 21 20:55 update_file
nas_server:/#
Message 12 of 20
mdgm-ntgr
Those look fine, I think.
Message 13 of 20
boywithumbrella
well, first of all that would mean that we still don't know what's broke and how to fix it.
But still, thanks for your help. I'll wait for a fix from yoh-dah and/or super-poussin then...
Message 14 of 20
markj23
im getting the same errors as you guys - happily waiting for an upgrade to transmission as for me the Time Machine support was more critical then torrents
Message 15 of 20
mdgm-ntgr
Just had a look and I think there's a problem with the architecture checking of addin 4.1.8-T5. Of the add-ons I've looked at, add-ons without the "arch" option in the header work fine. Other add ons don't work.
Message 16 of 20
mdgm-ntgr
You should still be able to install Transmission if you're willing to use SSH.
Try something like this (note that creating a directory with a unique name highly unlikely to be used by the add-on install.sh script and changing the working directory are essential steps):
mkdir /tmp/tran783
cd /tmp/tran783
wget http://www.readynas.com/contributed/super-poussin/Transmission_2.31.bin
tar xvf Transmission_2.31.bin
sh install.sh
I haven't tried this, but I did something similar to update ReadyNAS Remote to the latest version and ReadyNAS Remote is working for me.
Message 17 of 20
spoot
ssh install worked
Message 18 of 20
mdgm-ntgr
Thanks for letting me know.
I thought it would work. super-poussin also rebuilt the latest beta of the Transmission add-on so it can install via Frontview on 4.1.8-T5. See http://www.readynas.com/forum/viewtopic.php?p=312862#p312862
Message 19 of 20
spoot
thanks for the help on this one!
Message 20 of 20
Top Contributors
Discussion stats
  • 19 replies
  • 6683 views
  • 0 kudos
  • 4 in conversation
Announcements
