× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
*OLD* ReadyNASOS 6.6.0 (RC2) *OLD*
Skywalker
NETGEAR Expert
Latest beta: ReadyNASOS 6.6.0 (RC2)
To install: Click on appropriate link above for your system to download firmware image.
Then upload that image from the management UI's System->Settings->Update->Install Firmware section.
New features
  • VLAN virtual network adapter support.
  • ReadyDR - A new disaster recovery service that does block-level replication of share snapshots. (x86 systems only - not available on RN10x/20x/21x/2120)
Changelog
  1. [Alpha 1] Fixed large file uploads to DropBox.
  2. [Alpha 1] Fixed various issues with Amazon Cloud Drive.
  3. [Alpha 1] Made the AmazonCloudDrive backup share optional.
  4. [Alpha 1] Added an option to format external storage devices with BTRFS.
  5. [Alpha 1] Improved ReadyCLOUD client connection stability.
  6. [Alpha 1] Fixed kernel race condition that could lead to crashes, and a "mv_xor_status+88" message on LCD. (RN104)
  7. [Alpha 1] Various security fixes (including CVE-2016-5387/httpoxy, CVE-2016-2119).
  8. [Alpha 1] Updated OS core base (from Debian 7 to 8).
  9. [Alpha 1] App uninstall process improved to remove unused dependencies.
  10. [Beta 2] Many ReadyDR improvements.
  11. [Beta 2] Improved ReadyDR logging.
  12. [Beta 2] Fixed Wake-on-LAN support. (RN312/RN314/RN316)
  13. [Beta 2] Fixed PSU monitoring. (RN3220/RN4220)
  14. [Beta 2] Fixed network tab unnecessarily requiring an IPv6 gateway address.
  15. [Beta 2] Fixed an issue where changing share ownership would silently fail.
  16. [Beta 2] Fixed an issue where snapshots could be skipped during DST adjustments.
  17. [Beta 2] Added a couple security updates. (cURL, Linux kernel)
  18. [Beta 2] Fixed a false error message when adding a ReadyDR share on a remote system.
  19. [RC1] Fixed SNMP service.
  20. [RC1] Fixed disks always spinning up immediately with disk spindown enabled.
  21. [RC1] Fixed a system management crash when encountering bad rsync configuration.
  22. [RC1] Fixed encrypted volume support.
  23. [RC1] Add support for configurable SNMP location and contact.
  24. [RC1] Fixed issue where user home folder snapshot settings would get reset after upgrade.
  25. [RC1] Fixed some cases where formatting a USB drive would fail.
  26. [RC1] Fixed a WSD memory leak when responding to network devices that issued invalid requests.
  27. [RC1] Fixed an issue where ADS groups would show a GID instead of the group name in the GUI on new shares.
  28. [RC1] Fixed a potential crash during shutdown if one of the network interfaces failed to initialize. (RN202/RN204/RN212/RN214)
  29. [RC1] Fixed a rare issue where a network bond many be missing one member after a reboot.
  30. [RC1] Fixed an issue where continuous snapshots would still be taken after the snapshot pruning threshold had been exceeded.
  31. [RC1] Changed the network default gateway priority to prefer the lowest interface number, to match older firmware versions.
  32. [RC1] Snapshot pruning on full volumes should now retain at least the two most recent snapshots on all shares and LUNs.
  33. [RC1] Fixed power supply monitoring on rackmount systems. (RN3220/RN4220/RN3312/RN4312)
  34. [RC1] Fixed compatibility issues with most apps.
  35. [RC2] Fixed UPS support.
  36. [RC2] OpenSSL security updates.
  37. [RC2] Fixed RAIDar endless booting status.
  38. [RC2] Fixed AFP access to ReadyDR shares.
  39. [RC2] Fixed disk sleep status detection on some new high-capacity disk models.
  40. [RC2] Fixed IP address changing GUI issue on Firefox 49.
WARNINGS:
  • Unless you are advised by NETGEAR Support in a support case to update to beta software, NETGEAR Support will deny support if you are running beta software. You can seek help here on the NETGEAR Community for issues encountered on the beta.
  • Devices updated with 6.6.0 firmware cannot be downgraded to earlier firmware versions.
  • ReadyNAS 102, 104, and 2120 must not be updated directly to 6.6.x from 6.3.x or older firmware.  They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.6.x
  • ReadyNAS 202, 204, 212 and 212 must not be updated directly to 6.6.x from 6.3.x. They must first be updated to 6.3.5 then 6.5.2 and then onto 6.6.x
KNOWN ISSUES:
  • Some apps in the Available Apps list are currently incompatible with ReadyNASOS 6.6.0.
Message 1 of 4
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.6.0-T117 (Beta 2)
Posted 6.6.0-T117 (Beta 2).
Message 2 of 4
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.6.0 (RC1)
Posted 6.6.0-RC1.
Message 3 of 4
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.6.0 (RC2)
Posted 6.6.0-RC2.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 7936 views
  • 1 kudo
  • 1 in conversation
Announcements
