× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNASOS 6.4.1-RC3 - Repeated quota message for external USB flash drive
Kardano
Luminary
After installing 6.4.1-RC3 I get every day at 04:00 this e-mail message:
ReadyNAS Alert Message (PMNAS02 Share: Warning)
Consumed space on folder USB_FLASH_1 exceeds 83% of the quota (29.3 GB).
it IS really annoying, because there is NO quota setting in share properties for external USB drive.
This begin after install 6.4.1-RC3. (my unit is RN204, USB flash drive is 84% full - same as before RC3)
Is it possible to repair? I mean, get quota management for external drive to or disable this message but still showing consumed and available for external device in shares pane
Message 1 of 4
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNASOS 6.4.1-RC3 - Repeated quota message for external USB flash drive
This is fixed in the next build. Please wait for this and try that.
We don't set quotas on external disks so we should ignore them when checking for quota usage.
Message 2 of 4
Skywalker
NETGEAR Expert
As you can see, the "quota" in this case is the full size of your USB drive.  You can disable this from the command line with the following two commands:
# sqlite3 /var/readynasd/db.sq3 "update account_default set diskquota_warn = 100"
# sed -i '/diskquota_warn/s/80/100/' /etc/frontview/account.conf
Message 3 of 4
Kardano
Luminary
MDGM,
I updated to FW 6.4.1 final and message persisit. Every day about 04:00 AM:
e-mail message and in the log:
Share: Consumed space on folder USB_FLASH_1 exceeds 83% of the quota (29.3 GB).
So i asume, that you think  another build than 6.4.1.
Thnaks.
For Skywalker.
I wont change setttings, wait til changes in FW (so I can chek and test it as new builds goes.
Thanks.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4694 views
  • 1 kudo
  • 3 in conversation
Announcements
