Depending on how JBOD is implemented.
This topic has been closed to new posts due to inactivity. We hope you'll join the conversation by posting to an open topic or starting a new one.
@matmar wrote:
Why not raid 0 ?
The NAS supports it, but it is inherently extremely fragile. If any drive fails, the full volume is lost. If you have backups for it, and are willing to accept the downtime to rebuild it when the volume fails, then it is fine.
That's the point, I save 3To and accept the risk as I have back up on external HDD.
I use xraid on my main NAS, but not on the newer backup NAS. I prefer jbod myself - which also gives you full space and is much less fragile. The downside of jbod is that you have to balance the free space yourself (keeping track of fullness on each volume). But as disk sizes have become bigger, that is easier to do.
Stephen,
Giving up striping is going to impact performance when comparing JBOD to RAID0.
Alex
I understand that. But I think for most users the performance gains are marginal. WiFi access for instance is network bound even with 802.11ac. My RN202 running jbod delivers ~95 MB/s, which is close enough to network bound on gigabit ethernet.
Another factor for me is that data recovery (if ever needed) is a whole lot easier for jbod than RAID0.
In most home use cases the fragility of RAID0 outweighs any performance gain. If users fully understand the consequences of using it (and the implications for backup) then that's fine. But based on posts here, I think many users don't understand the impact of a single disk failure on a RAID0 array.
Matmar is making a considered choice, and does maintain backups- so on this thread I simply pointed out my preference and the main reason for it. I don't see any immediate need for him to switch modes, but if he does do a reset for other reasons it might be worth revisiting.
@matmar wrote:
I prefer raid 0 for eda because the volume is managed by the readynas 516 so that i can use maintenance tools (defrag, scrub...)
Just wanted to point out that the same maitenance tools are available for jbod volumes.
The main drawback is the need to balance storage. If you have any shares that are too large to comfortably fit on a single disk, then you'd need to break them up, and you do sometimes need to move shares around. As AlexPE points out, there can be some performance loss over RAID0 also.
Yes, you can do JBOD on anything. To be clear, JBOD in this case means creating a separate volume per disk (the term JBOD tends to be used to describe a variety of different volume configurations).
