Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XRAID2 / Flexraid: Open questions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-06-19
05:49 AM
2014-06-19
05:49 AM
Hi there,
After reading the ReadyNAS OS manual, I still have questions about XRAID2: I bought a ReadyNAS 516 and I would like to use it with 6 x 4TB drives. This will give me an one disc failure tolerance and 20TB of empty space in one Volume. My questions are:
1. When I purchase an EDA expansion unit later on, I only can expand the 20TB volume? I can not start a second Volume when I stick to XRAID?
2. When I expand the 20tB Volume in the main unit by using an EDA, I can extend the volume to 40TB with a one disc redundancy. Can I also have XRAID with dual redundancy? Would be safer for a single volume comprising of 11 discs (6 main, 5 EDA).
Cheers Chris
Cheers Chris
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-06-19
05:52 AM
2014-06-19
05:52 AM
Re: XRAID2 / Flexraid: Open questions
1. No, the EDA500 will have a separate volume.
2. Disable X-RAID, delete the volume created by default, create a new RAID 6 volume then re-enable X-RAID.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-06-19
05:59 AM
2014-06-19
05:59 AM
1. This means I can have two XRAID2 volumes (with a one disc failure tolerance each), one 20TB volume on the main unit and a 16TB volume on the EDA?
2. When I disable XRAID and create a RAID6 volume, I loose all data, right?
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-06-19
06:03 AM
2014-06-19
06:03 AM
1. Yes
2. When you delete the volume all data is wiped. So yes, you need to backup your data before doing this.
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-06-19
06:11 AM
2014-06-19
06:11 AM
Thanks for your answers. I think option 1. is okay for me, two volumes with a one disc failure tolerance each.
My confusion was caused by the manual, because I got the impression that you can only have ONE XRAID2 volume.
Message 5 of 5
