Orbi WiFi 7 RBE973
Reply
Current version of Replicate manual or a Repliate setup guide
TullyNYGuy
Tutor
Can anyone point me to a link for the Readynas Replicate manual for OS 6.6.0? The only one I found was from 2010 and some things appear to have changed since then.
Alternatively, is there a setup guide somewhere?
Thanks
Model: RN51600|ReadyNAS 516 6-Bay
Message 1 of 4
Accepted Solutions
Retired_Member
Not applicable
Re: Current version of Replicate manual or a Repliate setup guide
Message 2 of 4
All Replies
Retired_Member
Not applicable
Hello TullyNYGuy
I found a Replicate manual which is from 2013,you can download it at http://www.downloads.netgear.com/files/GDC/READYNAS-COMMON/ReadyNAS%20Replicate%20UM_10Jul2013.pdf
Edit: There's a newer one from 2014: http://www.downloads.netgear.com/files/GDC/READYNAS-COMMON/ReadyNAS%20Replicate%20UM_29Jan2014.pdf
Message 2 of 4
TullyNYGuy
Tutor
That helped. Thanks.
Message 3 of 4
FramerV
NETGEAR Employee Retired
Hi TullyNYGuy,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 4 of 4
Discussion stats
  • 3 replies
  • 2743 views
  • 0 kudos
  • 3 in conversation
Announcements
