Orbi WiFi 7 RBE973
Reply
Hard drive failure
callenan83
Hard drive failure
Hi,
the Hard drive in my first bay has failed.  its got a red indictor on when I look at the Volume overview.
I have it seet up as X-Raid - Raid 5.
Can I just pull out the failed hard drive and put in a new hard drive and it will resync it?  is that how it works?  i've tried to read the documentation but it wasn't clear.
Model: RN21400|ReadyNAS 214 Series 4- Bay (Diskless)
Message 1 of 3
Sandshark
Sensei
Re: Hard drive failure
Yup!  And do it with the power on.  NAS log should report the removed drive, inserted drive, then start and end of sync.
Message 2 of 3
Guru
Note that it syncs automatically if the replacement drive isn't formatted.
If it is formatted, then there is a manual format step you need to do in the web UI after you insert the drive.  The rest is automatic.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1290 views
  • 0 kudos
  • 3 in conversation
Announcements
