Orbi WiFi 7 RBE973
Reply
ReadyCLOUD red cross folders
AlbertoLD
Hi,
How I share my folders again? I have a red cross in all folders except 'home' folder and I can't sync this with my PC . Look at the picture:
Could you help me?
Thanks.
Model: RN102|ReadyNAS 100 Series
Message 1 of 8
Accepted Solutions
JennC
NETGEAR Employee Retired
Re: ReadyCLOUD red cross folders
Hello AlbertoLD,
In the admin page, click System then Settings. You should be able to see SMB, make sure it is enabled.
After doing that, click Shares, from here you should see all the shares where you saved your files. Go to the Settings on each one of them and go to Network Access. You should see SMB, make sure it is also enabled.
Message 6 of 8
All Replies
JennC
Hello AlbertoLD,
Are you logged in as the main ReadyCloud account in the portal?
The main account is the one that is on the admin page > Cloud > ReadyCloud's "signed in as".
Message 2 of 8
AlbertoLD
Hi JennC,
Yeah, of course, I'm logging in as the main ReadyCLOUD accounyt. In my PC, whit the ReadyCLOUD program, I can only sync up my home' folder, the other have an error, and all my documents are in this folders.
Thanks
Message 3 of 8
JennC
Hello AlbertoLD,
Are the shares' SMB or any file protocol enabled? This red "x" mark appears when the share does not have any protocol enabled.
Message 4 of 8
AlbertoLD
Hi JennC,
I don't know anything about protocols, how I can know about it?
Thanks for all.
Message 5 of 8
JennC
Hello AlbertoLD,
Message 6 of 8
FramerV
Hi AlbertoLD,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 7 of 8
AlbertoLD
Thanks JennC,
The problem was in the configuration in Share. In Settings-Network, I didn't have enable it.
Thanks for all.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4122 views
  • 1 kudo
  • 3 in conversation
Announcements
