- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Antivirus false positives
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
ReadyNAS Antivirus is flagging a couple of files in the current version of WordPress, zxcvbn-async.min.js and wp-fullscreen-stub.min.js, but there doesn't appear to be anything wrong with them according to virustotal.com, and I'm getting multiple emails for each file every day.
I've tried editing /opt/ctch/etc/ctscand.conf to exclude these 2 files from scanning, but shortly thereafter the config file just gets reverted and the flagging continues unabated. Only workaround seems to be to turn Antivirus off completely.
Is there a way to submit files as false positives? Any other ideas out there?
Thanks,
Greg
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Antivirus false positives
Have you tried using the NETGEAR Anti-Virus Plus app?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I've tried the Antivirus Plus app many times. It's currently set to "Report and Block", with no options for whitelisting any files. Am I missing something there?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello gbeddow,
Are these the only JavaScript files you have stored to the NAS or there are other JS files that are not getting flagged? What's the current FW version of your NAS?
The AntiVirus and AntiVirus Plus do not have an option to white list files but maybe you can request this feature at idea exchange board.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll look into the feature request idea, thanks.
Firmware is the latest 6.5.2, although it started happening a couple days before upgrading when it was running 6.5.1.
Lots of other JS files on the server, these are the only 2 that get flagged. virustotal.com thinks they're ok, and they're identical to the official WordPress repository versions.
Isn't there a channel through Netgear back to the Antivirus vendor - or directly to the vendor - so that future AV updates fix this type of thing for everyone?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello gbeddow,
Have you tried checking these files with another Anti Virus software?
From what I read, ReadyNAS has integrated Commtouch AntiVirus. I think this built-in AntiVirus is intended to just detect but no action.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The nice thing about virustotal.com is it runs the uploaded file thru more than 50 different virus checkers.
I have ReadyNAS Antivirus configured in its least restrictive "Report and Block" mode, which both reports (via email) and blocks access to the file - even trying to read the file is completely blocked until you turn off Antivirus.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello gbeddow,
I understand. What's the model number of your NAS again? Maybe you can check this with support team?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello gbeddow,
Try contacting support team to have them check the file if that is something that really needs to be flagged.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tech support on the unit expired back in March, so the link you supplied directed here, to the Forum. Infinite loop. 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello gbeddow,
Oh, will it be okay for us to have a copy of the file?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello gbeddow,
Thanks but how do I download this? I'm just trying to copy it and test on our own NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As usual there are lots of ways. You could copy the contents of each file from the links above, then save locally. Another way is to back up one level in github and click the download button
https://github.com/WordPress/WordPress
then unzip the file and locate the 2 files in the resulting directory hierarchy here:
WordPress/wp-admin/js/wp-fullscreen-stub.min.js
WordPress/wp-includes/js/zxcvbn-async.min.js
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello gbeddow,
How do you copy them over? I used the web browser and files but did not get the same problem. By the way, I copied to notepad and saved as .js file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi JennC,
It's not clear to me what's happening for you. Can you describe the steps you're taking in more detail?
Thanks,
Greg
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am seeing the issue with the following file:
I will forward this file information through our channels.
I am not seeing the issue with this file:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for reporting this issue. It was fixed in the AV definiation update. Please make sure your AV definition file is up-to-date. The version should be 201609281626 or late.
You can install Anti-Vius Plus app, click the "Cehck Update" button to update the definition file.
There is a known bug that the "Definition File" is empty in Anti-Virus Plus app 2.0.4. It will be fixed in the next release 2.0.5.
- Mark as New
- Bookmark
- Subscribe
- Permalink
B_L,
Thanks. I turned Antivirus back on a few hours ago and, so far, it hasn't flagged these 2 files - or any other files. Keeping my fingers crossed...
