Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
HOW TO: Hosting multiple websites
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-07-25
03:05 PM
2010-07-25
03:05 PM
Re: HOW TO: Hosting multiple websites
Hey,
Great you found a solution.
-Stefan
-Stefan
Message 26 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-07-25
05:46 PM
2010-07-25
05:46 PM
WhoCares? wrote:
mdgm wrote: Hopefully a firmware re-install would get the NAS working again.
That's one of the problems because most likely it wouldn't.
-Stefan
I was messing with such things for quite a while before biting the bullet and enabling root SSH. I was using eXplorer and PHP shell. The problem, of course, is that both of those access via Apache, and if you trash Apache, you can't undo them.
Having done so three times before enabling root SSH to give me an option, I can vouch that a reinstall overwrites Virtual.conf and htppd.conf. It does not erase non-default files, though, at least in the primary apache directory. Don't know about in addons.
So if all the changes you make are in the standard files, the worst that a user should have to do is a firmware re-install to undo a mess.
Message 27 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-07-25
10:11 PM
2010-07-25
10:11 PM
Hi
That is the beauty of my solution. You do not have to enable root SSH access and you don't need to play around with apache or any of the system files so the chances of trashing the system are negligible. It is therefore unlikely that you will need to do a hardware re-install with this solution.
You do not need to create any additional files in the addons directory and the only system file that is changed is Virtual.conf which is changed within frontview.
Cheers
Phil
Cheers
Phil
Message 28 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-01-23
04:21 PM
2011-01-23
04:21 PM
Thanks in advance 🙂 It works on my duo, but i got one warning when starting apache-ssl:
[Warn] _default_ VirtualHost on port 80, the first has precedence
I solved it by edit /etc/frontview/apache/httpd.conf and added:
NameVirtualHost *:80
Before the lines:
Include /etc/frontview/apache/Ports.conf
Include /etc/frontview/apache/Virtual.conf
Include /etc/frontview/apache/addons/*.conf
Include /etc/frontview/apache/Shares.conf
Before the lines:
Message 29 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-01-25
11:06 AM
2011-01-25
11:06 AM
Hi,
Thanks so much for starting this great forum. I have got a website setup on my new NAS DDO working perfectly now.
One issue I have that is slightly off subject is setting up emails for the domain(s). The NAS obviously does not have any mail server or is there a way to install one? What have you guys done to resolve this issue. I know I can create an MX record for the domain to send the mail to a different mail server but my the mail is rejected as its not for the correct domain! Any help here would be greatly appreciated.
Message 30 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-16
05:25 AM
2011-02-16
05:25 AM
I'm getting redirected to the Shares site too. I'm setting my hosts file to 192.168.x.x test.nas (which is the servername) but I haven't forwarded the IP address using Port Forwarding. Do I need to do this to get it to work?
Message 31 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-16
05:51 AM
2011-02-16
05:51 AM
Port forwarding is for WAN access (i.e. over the internet).
Message 32 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
03:26 PM
2011-02-20
03:26 PM
Ok so I'm using the PHP 1.4 add-on and I can access phpMyAdmin ok as well as static sites. The big problem is .htaccess and mod_rewrite. I get 443 errors.
None of the threads on this forum seem to help and I'm getting a little bit frustrated as I just want a system that works.
Can someone give me a pointer (and some code!) as to what I should do to enable mod_rewrite?
I get the following error.log message -
[Mon Feb 21 09:24:45 2011] [error] [client 192.168.0.192] Options FollowSymLinks or SymLinksIfOwnerMatch is off which implies that RewriteRule directive is forbidden: /c/sites/mysite/
Message 33 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
03:32 PM
2011-02-20
03:32 PM
Since I don't know how you configured your virtual host, this is just a generic advice. Under the <Directory ....> statement for your master directory (DocumentRoot) add:
-Stefan
Options +FollowSymLinks
-Stefan
Message 34 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
03:36 PM
2011-02-20
03:36 PM
Hi Stefan!
Here is an example from my Virtual Host which is in /etc/frontview/apache/addons/my-virtual.conf
<VirtualHost *:80>
ServerName xxx.xxx.dynalias.com
DocumentRoot /c/sites/xxx/
SSLEngine off
RewriteEngine on
DirectoryIndex index.php
Options All
</VirtualHost>
<VirtualHost *:80>
SSLEngine off
RewriteEngine on
Options All
</VirtualHost>
Message 35 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
03:39 PM
2011-02-20
03:39 PM
Ok, so you'd need to add:
Somewhere between <VirtualHost ...> and </VirtualHost>. Don't forget to restart Apache afterwards.
-Stefan
<Directory /c/sites/xxx>
AllowOverride All
Order allow,deny
Allow from all
</Directory>
-Stefan
Message 36 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
03:44 PM
2011-02-20
03:44 PM
No dice 😞
Still getting 403 errors. The error log still gives the same error.
Yes I did restart apache!
Message 37 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
03:47 PM
2011-02-20
03:47 PM
Any other diagnostics I could run to make sure nothing is conflicting?
Message 38 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
03:49 PM
2011-02-20
03:49 PM
My .htaccess is -
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^(.*)$ /index.php/$1 [L]
RewriteEngine On
Message 39 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
03:50 PM
2011-02-20
03:50 PM
403 means "no access". Or in short: the process apache is running under doesn't have sufficient file system rights to access the data of your vhosts. You can try running
-Stefan
cd /c/sites
chmod -R a+r *
-Stefan
Message 40 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
03:59 PM
2011-02-20
03:59 PM
Still not working. Tried it with a static html page. Works fine without .htaccess but I get the 403 if I add the .htaccess.
Message 41 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
04:09 PM
2011-02-20
04:09 PM
What does the error.log of Apache say about this?
-Stefan
-Stefan
Message 42 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
04:22 PM
2011-02-20
04:22 PM
Message 43 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
04:25 PM
2011-02-20
04:25 PM
There's something wrong with your vhost config. To debug this using the forum isn't going to work I think. If you're interested I can have a look using TeamViewer (www.teamviewer.com). Just PM me with the login info if you like.
-Stefan
-Stefan
Message 44 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
04:51 PM
2011-02-20
04:51 PM
Thanks Stefan!
I'll let you know when I've got it all set up.
Message 45 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
04:54 PM
2011-02-20
04:54 PM
Don't worry too much. I'm not at all interested in what you're going to serve and if possible I won't even look there 😉
-Stefan
-Stefan
Message 46 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
07:37 PM
2011-02-20
07:37 PM
I trust you 🙂
We need a definitive web hosting server setup guide as opposed to bits and pieces scattered around the forums.
In fact I'm surprised ReadyNas don't ship one as standard like QNAP do. It can always be updated if it doesn't suit.
Message 47 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-20
11:41 PM
2011-02-20
11:41 PM
Wait for me to finish my add-on 😉
-Stefan
-Stefan
Message 48 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-21
07:11 AM
2011-02-21
07:11 AM
Ooh really? Got an ETA for that? Really need to start developing sites on this box.
PS. PHP 5.3.x would be a bonus!
Message 49 of 130
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-21
05:10 PM
2011-02-21
05:10 PM
Silence... PM me with details?
Message 50 of 130
