× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
MLDonkey 3.1.5
WhoCares_
Mentor
MLDonkey 3.1.5
MLDonkey 3.1.5
    • Description
      MLDonkey was originally intended as a pure eDonkey2000 clone, running on Unix and Linux, a sector that the original client never served well. Since the release of version 2, there has also been development to access other networks, most notably the eDonkey2000 offspring Overnet, BitTorrent, Kademlia and DirectConnect.
    • Requirements:
      ReadyNAS Platform: ARM
      ReadyNAS Firmware: RAIDiator 5.3.7 or better
    • Please Note
      Due to the limited CPU and memory resources available on the ReadyNAS ARM line the throughput of MLDonkey on the ReadyNAS may be significantly lower than what you may be used to from running MLDonkey on your client computer. That's not a problem with the software itself.
  • Configuration:
      • After installation of the add-on, MLDonkey's web interface can be accessed by typing
        http://<ip of your NAS>:4080/
        in your browser's address field.
        As an alternative you can click on the "Open MLDonkey's web interface" button in MLDonkey's add-on pane.
      • Please note: To ease initial setup, there's <strong>no password</strong> set and also access is allowed from any IP address. Make sure to change these settings!
    • To add a password for the "admin" user, just do as told on the intro screen and enter "useradd addmin <your chosen password>" into the input box in the top center of the screen. If that worked, you'll be prompted to authenticate before you can access MLDonkey's web interface again.
Message 1 of 2
WhoCares_
Mentor
Re: MLDonkey 3.1.5
Updated to MLDonkey 3.1.5
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3645 views
  • 0 kudos
  • 1 in conversation
Announcements
