Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
QbitTorrent
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-03
11:56 PM
2015-02-03
11:56 PM
QbitTorrent
Hi!
I recently installed QbitTorrent on my RN316. When I launched it I got the login screen and used the default credentials. I then changed the admin password. When trying to login again I kept getting rejected with invalid password. The default password also doesn't work (expected).
I have two issues with this:
1. How do I reset or recover the password? I have not attempted uninstalling the app as I'm running OS6.2.2 and am waiting for the production realease of the updated firmware.
2. The password change screen only allows for the new password to be entered once. The generally accepted way to do this is to enter it twice and confirm that both versions are identical. Therefore, I'm not sure if I made an error entering the new password or if the app cannot handle long passwords (>12 characters).
Thanks in advance,
Shaun
Thanks in advance,
Shaun
Message 1 of 6
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-04
03:19 AM
2015-02-04
03:19 AM
Re: QbitTorrent
You can do an OS reinstall to reset the password back to the default. It will also reset your network settings to dhcp. Data and other settings should not be affected.
See page 47-48 here: http://www.downloads.netgear.com/files/ ... ct2013.pdf
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-04
04:08 AM
2015-02-04
04:08 AM
Re: QbitTorrent
Thanks Stephen. I don't have a problem with the RN admin password but with the QbitTorrent password.
Is reinstalling the RN OS still the only solution for repairing the app password?
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-04
06:39 AM
2015-02-04
06:39 AM
Re: QbitTorrent
Sorry I misunderstood.
I don't use qbitorrent. But I think you can reset the password if you can get access to qbittorent.conf. https://github.com/qbittorrent/qBittorr ... k-password
You can get to this file through SSH. You can also download your config files, and see if it is there, and access the NAS with cifs/smb (from windows explorer) with admin credentials and look in \\nas\data\.apps.
Once you get the file, you need to make sure that you use an editor that supports linux formats. notepad++ is one (DON'T use Windows notepad).
If you are mac user, this last point is not a problem, mac and linux use the same format conventions.
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-07
09:30 AM
2015-02-07
09:30 AM
Re: QbitTorrent
Thanks Stephen. I'm not comfortable using SSH. I tried accessing with Windows explorer but the path wasn't recognised. I'll keep at it and post the outcome.
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-07
12:10 PM
