Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Running VirtualBox VM host on ReadyNAS Pro
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-07
02:41 AM
2009-03-07
02:41 AM
What is VirtualBox?
So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it after using it for ages, plus its open and free 🙂 Eventually, I may look into VMWare as well.
After a bit of messing around, got it installed. Since the system is based off of Debian, was easy to get VirtualBox itself there (deb package). The trickiest part was getting the kernel modules required installed (see end of post).
In the end, I've got Windows 2003 R2 running on my Pro, interacting with it via RDP, and I am happy with the performance. I've added an extra 1GB memory (for a total of 2GB). I assigned 1GB of ram to my virtual OS, which still leaves the default configuration of 1GB for the NAS itself (which is more than enough still, 800MB+ is always cached).
I made a 10GB virtual disk to install the OS on. If I need more space later for extra applications, I can just add another virtual drive to that installation. And since I always like a bit extra security, I went a bit beyond the usual, and also have TrueCrypt running full disk encryption in the virtual OS. So no one can even boot and read the data in that OS without my bootup password.
I don't really have any screenshots to show, just a standard Windows installation. Here is a few of the steps I used while creating the VM on the console:
VirtualBox 3.1 has changed the CLI configuration. Until I update this how-to, please reference this: http://www.uhleeka.com/blog/2009/12/vir ... 9-04-host/
With the OS booted up and just sitting at the desktop, top reports:
Ad-hoc installation of VirtualBox. Should work for RAIDiator 4.2.4. Download links for the kernel modules, for those who don't want to go through the mess of compiling them.
# Creating the Virtual Machine.
$ VBoxManage createvm -name "Windows2003" -register
$ VBoxManage modifyvm "Windows2003" -memory "1024MB" -acpi on -boot1 dvd -nic1 nat
$ VBoxManage createvdi -filename "/c/backup/VirtualBox/Windows2003.vdi" -size 10000 -register
$ VBoxManage modifyvm "Windows2003" -hda "/c/backup/VirtualBox/Windows2003.vdi"
$ VBoxManage registerimage dvd /c/backup/VirtualBox/Windows2003Ent.iso
$ VBoxManage modifyvm "Windows2003" -dvd /c/backup/VirtualBox/Windows2003Ent.iso
$ VBoxHeadless -startvm "Windows2003" &
# Connected via Remote Desktop at this point.
# After the installation, first page requires Ctrl-Alt-Del, so I sent the keycodes.
$ VBoxManage controlvm "Windows2003" keyboardputscancode 1d 38 53
# System is up and running, time to install GuestAdditions for better video, etc.
$ wget http://download.virtualbox.org/virtualbox/2.2.2/VBoxGuestAdditions_2.2.2.iso
$ VBoxManage registerimage dvd /c/backup/VirtualBox/VBoxGuestAdditions_2.2.2.iso
$ VBoxManage controlvm "Windows2003" dvdattach /c/backup/VirtualBox/VBoxGuestAdditions_2.2.2.iso
top - 16:17:10 up 1 day, 17:58, 1 user, load average: 0.00, 0.01, 0.00
Tasks: 93 total, 1 running, 92 sleeping, 0 stopped, 0 zombie
Cpu(s): 0.7%us, 0.2%sy, 0.0%ni, 99.2%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st
Mem: 2072432k total, 2020100k used, 52332k free, 6120k buffers
Swap: 1048536k total, 144k used, 1048392k free, 784620k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
10297 root 20 0 1104m 1.0g 4720 S 4 52.5 57:31.53 VBoxHeadless
12792 root 20 0 46092 9520 1720 S 1 0.5 59:54.51 motion
12196 root 20 0 9196 7688 980 S 0 0.4 0:57.72 wastesrv
1 root 20 0 1948 600 508 S 0 0.0 0:01.30 init
$ mkdir /lib/modules/`uname -r`/miscOr, if you want to compile the kernel modules yourself:
$ cd /lib/modules/`uname -r`/misc
$ wget http://www.readynas.com/contributed/chirpa/modules/virtualbox/pro/vboxdrv.ko
$ wget http://www.readynas.com/contributed/chirpa/modules/virtualbox/pro/vboxnetflt.ko
$ echo "deb http://download.virtualbox.org/virtualbox/debian etch non-free" >> /etc/apt/sources.list
$ wget -q http://download.virtualbox.org/virtualbox/debian/sun_vbox.asc -O- | apt-key add -
$ apt-get update
$ apt-get install virtualbox-2.1
$ /etc/init.d/vboxdrv start
envyious:/c/backup# echo "deb http://download.virtualbox.org/virtualbox/debian etch non-free" >> /etc/apt/sources.listInstall of VirtualBox 2.2.2, before Sun updates the Debian Repository...
envyious:/c/backup# wget -q http://download.virtualbox.org/virtualbox/debian/sun_vbox.asc -O- | apt-key add -
envyious:/c/backup# apt-get update && apt-get install build-essential
Setting up build-essential (11.3) ...
envyious:/c/backup# wget -q http://www.readynas.com/download/GPL/RNDP6xxx_4.2.4_WW_src.zip
envyious:/c/backup# unzip -q RNDP6xxx_4.2.4_WW_src.zip -d ./GPL
envyious:/c/backup# cd GPL/linux-x86-2.6/
envyious:/c/backup/GPL/linux-x86-2.6# make && make prepare
envyious:/c/backup/GPL/linux-x86-2.6# ln -s /c/backup/GPL/linux-x86-2.6/ /usr/src/linux
envyious:/c/backup/GPL/linux-x86-2.6# KERN_DIR=/usr/src/linux
envyious:/c/backup/GPL/linux-x86-2.6# apt-get install virtualbox-2.1
Setting up virtualbox-2.1 (2.1.4-42893_Debian_etch) ...
Adding group `vboxusers' (GID 101) ...
Done.
Messages emitted during module compilation will be logged to /var/log/vbox-install.log.
Success!
Starting VirtualBox kernel module: done.
envyious:/c/backup/GPL/linux-x86-2.6# cd
envyious:/c/backup/GPL/linux-x86-2.6# VBoxManage list vms
VirtualBox Command Line Management Interface Version 2.1.4
(C) 2005-2009 Sun Microsystems, Inc.
All rights reserved.
# export KERN_DIR=/usr/src/linux
# apt-get install libfontconfig1 libglib2.0-0 libice6 libsdl1.2debian libsm6 libx11-6 libxcursor1 libxext6 libxi6 libxmu6 libxrandr2 libxrender1 libxslt1.1 libxt6 python2.4
# wget -q http://download.virtualbox.org/virtualbox/2.2.2/virtualbox-2.2_2.2.2-46594_Debian_etch_i386.deb
# dpkg -i virtualbox-2.2_2.2.2-46594_Debian_etch_i386.deb
Setting up virtualbox-2.2 (2.2.2-46594_Debian_etch) ...
Recompiling VirtualBox kernel module: done.
Message 1 of 442
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-07
01:16 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-08
04:01 PM
2009-03-08
04:01 PM
Re: Running VirtualBox VM host on ReadyNAS Pro
Added a quick 'this should sorta work' installation for VirtualBox to end of the first post.
Message 3 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-08
09:02 PM
2009-03-08
09:02 PM
Sounds like a readynas.com how-to waiting to happen 😎
Message 4 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-09
10:47 AM
2009-03-09
10:47 AM
Chirpa,
I am glad you are trying virtualization on the Pro. I PM'ed you a couple months ago the steps I undertook to try to install VMWare server for Linux on the Pro, and the problems I ran into.
I hope you are going to try VMWare Server on the Pro soon. Please PM me if you need me to re-send the steps I took before I ran into the problem with Linux headers.
Thanks!
Thanks!
Message 5 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-09
04:29 PM
2009-03-09
04:29 PM
All hail Chirpa!
Message 6 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-09
04:35 PM
2009-03-09
04:35 PM
I'll post my full details a little later... I had a lot of help from Chirpa to get things working.
-Dave
-Dave
Message 7 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-09
04:47 PM
2009-03-09
04:47 PM
Ubuntu running inside Debian 🙂
Message 8 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-09
09:26 PM
2009-03-09
09:26 PM
Cool! How about Windows 7 and Mac?
Message 9 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
01:59 AM
2009-03-10
01:59 AM
count me in if you need help 🙂
Message 10 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
02:17 AM
2009-03-10
02:17 AM
* No suitable module for running kernel found
ok what am i doing wrong?
i followed chirpas steps.
Message 11 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
02:31 AM
2009-03-10
02:31 AM
for some reason the vboxdrv.ko file disappears all the time..
anyway i got a little further:
and
ReadyNAS-Pro:/lib/modules/2.6.27.6.RNx86.2.1/misc# /etc/init.d/vboxdrv start
* modprobe vboxdrv failed. Please use 'dmesg' to find out why
and
vboxdrv: Trying to deactivate the NMI watchdog permanently...
vboxdrv: Successfully done.
vboxdrv: Found 2 processor cores.
vboxdrv: fAsync=0 offMin=0x1b0 offMax=0xce7
vboxdrv: TSC mode is 'synchronous', kernel timer mode is 'normal'.
vboxdrv: Successfully loaded version 2.1.4 (interface 0x000a0009).
Message 12 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
02:41 AM
2009-03-10
02:41 AM
ReadyNAS-Pro:/lib/modules/2.6.27.6.RNx86.2.1/misc# VBoxHeadless -startvm "Windows2003"
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (2.6.27.6.RNx86.2.1) or it failed to
load. Please recompile the kernel module and install it by
sudo /etc/init.d/vboxdrv setup
You will not be able to start VMs until this problem is fixed.
WARNING: The compilation of the vboxdrv.ko kernel module failed during the
installation for some reason. Starting a VM will not be possible.
Please consult the User Manual for build instructions.
VBoxHeadless: Error -1908 in suplibOsInit!
VBoxHeadless: VERR_VM_DRIVER_NOT_INSTALLED
VBoxHeadless: Tip! Make sure the kernel module is loaded. It may also help to reinstall VirtualBox.
hmmm 😞
Message 13 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
06:54 AM
2009-03-10
06:54 AM
beisser wrote: for some reason the vboxdrv.ko file disappears all the time..
It happened to me too.
I redownloaded the .ko files and inserted them into the kernel (you need to insert vboxdrv.ko before vboxnetflt.ko):
insmod vboxdrv.ko
insmod vboxnetflt.ko
I also updated to Raidiator T43 (you can probably just upgrade to 4.2.4 now that it's been released).
If you look very carefully, you can see in my screenshot above that there is an error message:
WARNING: The compilation of the vboxdrv.ko module failed during the installation for some reason. Starting a VM will not be possible. Please consult the User Manual for build instructions.
Obviously, we can see the VM is actually running, so I don't quite know what to make of the error.
The screen shots show a "Live CD" of Ubuntu 8.10 (everything working, albeit a bit sluggish --- only 1 GB RAM on the Pro). I also did not install the VBoxGuestAdditions_2.1.0.iso yet. Next, I performed the actual HD install of Ubuntu --- again, everything worked as expected.
I'll check my notes at home tonight to see if I've neglected to add any other pertinent details.
-Dave
Message 14 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
07:47 AM
2009-03-10
07:47 AM
that did it 🙂 thanx
now installing server 2003 just for fun..
Message 15 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
08:05 AM
2009-03-10
08:05 AM
the insmod-stuff was nmentioned nowhere in chirpas text.. that was the missing link.
Message 16 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
10:21 AM
2009-03-10
10:21 AM
My bad, missed a step in my ad-hoc installation 😉 Like I said, it was not tested. This will do the same thing as the insmod steps:
/etc/init.d/vboxdrv startHaven't rebooted yet to see if that runs on bootup properly.
Message 17 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
11:02 AM
2009-03-10
11:02 AM
do you know if there's a php interface or so we can add in a add-on ?
Message 18 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
11:18 AM
2009-03-10
11:18 AM
PHP interface to VirtualBox?
Message 19 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
11:59 AM
2009-03-10
11:59 AM
chirpa wrote: PHP interface to VirtualBox?
that would actually rock.. an interface where you can easily create new vms, new disks or modify existing ones.
Message 20 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
12:08 PM
2009-03-10
12:08 PM
I do a quick test :
if we want an add-on will all the deb files in it , the size will be 59 MB 😞
Message 21 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
12:23 PM
2009-03-10
12:23 PM
super-poussin wrote: I do a quick test :
so what? its about the same size as a firmware upgrade 🙂
Message 22 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
12:29 PM
2009-03-10
12:29 PM
yep 🙂
:rofl: :rofl: :rofl:
Message 23 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
02:05 PM
2009-03-10
02:05 PM
Or drop the .deb file in your /contributed folder, and make the addon wget the file on install.
Message 24 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-03-10
02:11 PM
2009-03-10
02:11 PM
do you mean I can do a echo 'y' | apt-get install 😛
Message 25 of 442
