Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
UDP 514 port open for remote logging on syslogd . HELP!
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-03
07:24 PM
2011-08-03
07:24 PM
Hi,
I want to remote logging on readynas.
So I did below,
# then I've added below line for receive log from remote device.
then I restart the syslogd
and check the udp 514 port open
finally it work well and receive log from remote device successfully.
BUT, when I reboot the NAS, upd 514 port blocked again....
netstat -an | grep :514 --> nothing..
For work properly, I have to restart the syslogd manually...
How can I open the udp 514 port consistently?
So I did below,
ReadyNAS-PRO:/# vim /etc/init.d/sysklogd
SYSLOGD="-r -m 0"
ReadyNAS-PRO:/# /etc/init.d/sysklogd restart
Restarting system log daemon: syslogd.
ReadyNAS-PRO:/# netstat -an | grep :514
udp 0 0 0.0.0.0:514 0.0.0.0:*
Message 1 of 9
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-03
07:53 PM
2011-08-03
07:53 PM
Re: UDP 514 port open for remote logging on syslogd . HELP!
If you added the "SYSLOGD="-r -m 0" before the line "test ! -r /etc/default/syslogd || . /etc/default/syslogd" the SYSLOGD far able was redefined.
You should edit the file "/etc/default/syslogd" and modify the definition of SYSLOGD in there.
Message 2 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-03
09:51 PM
2011-08-03
09:51 PM
CharlesLaCour wrote: If you added the "SYSLOGD="-r -m 0" before the line "test ! -r /etc/default/syslogd || . /etc/default/syslogd" the SYSLOGD far able was redefined.
I also added "SYSLOGD="-r -m 0" to "/etc/default/syslogd" as you said but it doesn't work either.. 😞
#! /bin/sh
# /etc/init.d/sysklogd: start the system log daemon.
SYSLOGD="-r -m 0"
PATH=/bin:/usr/bin:/sbin:/usr/sbin
pidfile=/var/run/syslogd.pid
binpath=/sbin/syslogd
test -x $binpath || exit 0
create_xconsole()
if [ ! -e /dev/xconsole ]; then
mknod -m 640 /dev/xconsole p
else
chmod 0640 /dev/xconsole
fi
chown root:adm /dev/xconsole
running()
# No pidfile, probably no daemon present
if [ ! -f $pidfile ]
then
return 1
fi
pid=`cat $pidfile`
# No pid, probably no daemon present
if [ -z "$pid" ]
then
return 1
fi
if [ ! -d /proc/$pid ]
then
return 1
fi
cmd=`cat /proc/$pid/cmdline | tr "\000" "\n"|head -n 1`
# No syslogd?
if [ "$cmd" != "$binpath" ]
then
return 1
fi
return 0
case "$1" in
start)
echo -n "Starting system log daemon: syslogd"
create_xconsole
start-stop-daemon --start --quiet --exec $binpath -- $SYSLOGD
echo "."
stop)
echo -n "Stopping system log daemon: syslogd"
start-stop-daemon --stop --quiet --exec $binpath --pidfile $pidfile
echo "."
reload|force-reload)
echo -n "Reloading system log daemon: syslogd"
start-stop-daemon --stop --quiet --signal 1 --exec $binpath --pidfile $pidfile
echo "."
restart)
echo -n "Restarting system log daemon: syslogd"
sleep 1
echo "."
reload-or-restart)
if running
then
else
fi
echo "."
echo "Usage: /etc/init.d/sysklogd {start|stop|reload|restart|force-reload|reload-or-restart}"
exit 1
esac
exit 0
# Top configuration file for syslogd
# Full documentation of possible arguments are found in the manpage
# syslogd(8).
# For remote UDP logging use SYSLOGD="-r"
SYSLOGD="-r -m 0"
Any advice?
Message 3 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-03
10:02 PM
2011-08-03
10:02 PM
All I did was edit my "/etc/default/syslogd" file like this:
Ran the command:
Looking at the processes bound to ports I see:
What do you get when you run the command:
# syslogd(8).
SYSLOGD="-r"
Ran the command:
mynas:~# lsof -i -nP | grep ':514'
syslogd 24688 root 18u IPv4 872288 UDP *:514
Message 4 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-03
10:28 PM
2011-08-03
10:28 PM
I have question to you.
udp 514 port still open after reboot the NAS?
I configured the NAS completely same as you.
I restart the syslogd then udp 514 port opened. yes it works at this time.
but it stop work after I reboot the NAS. udp 514 is not opened.
This is problem..
This is problem..
Message 5 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-24
08:44 PM
2012-03-24
08:44 PM
Have you ever found a solution to this problem? I am having exactly the same issue, remote logging does not work after reboot. If i look at the list of processes after reboot I see that syslogd was started without the -r switch. After I manually restart it (sysklogd restart) - it starts with -r switch and remote loging works as expected. I've made exactly the same changes to /etc/init.d/sysklogd as shown in the first post.
Message 6 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-05
10:22 AM
2012-05-05
10:22 AM
burokio wrote: Have you ever found a solution to this problem? I am having exactly the same issue, remote logging does not work after reboot. If i look at the list of processes after reboot I see that syslogd was started without the -r switch. After I manually restart it (sysklogd restart) - it starts with -r switch and remote loging works as expected. I've made exactly the same changes to /etc/init.d/sysklogd as shown in the first post.
I have resolved this problem~!
1. edit /etc/default/syslogd
SYSLOGD="-r -m0"
2. add some line to /etc/syslog.conf
local7.debug -/var/log/gs108t.log
3. create a script at /etc/init.d/ like a below.
#! /bin/sh
exit 0
4. update script to rc.
update-rc.d script-name defaults
that's it.
UDP 514 still opened after reboot!
Message 7 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-05
04:59 PM
2012-05-05
04:59 PM
The /etc/inittab defined the default init level as 2 and looking into /etc/rc2.d there are 2 scripts called /etc/init.d/readynas_startup and /etc/rc2.d/S02ToggleSwitchProCPUFan.
Looking at the file "/etc/init.d/readynas_startup" around line 375 you have:
The syslogd is not started using the standard /etc/init.d/sysklogd script it calls the daemon directly.
I made the following changes to "/etc/init.d/readynas_startup":
# RC2
echo -n "Starting system log daemon: syslogd" >$OUT
sync
/sbin/syslogd -m 0 || (echo "...retrying"; sleep 1; /sbin/syslogd -m 0)
echo "." >$OUT
# RC2
sync
/sbin/syslogd ${SYSLOGD}-m 0 || (echo "...retrying"; sleep 1; /sbin/syslogd ${SYSLOGD} -m 0)
echo "." >$OUT
Message 8 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-06
05:57 PM
2012-05-06
05:57 PM
CharlesLaCour wrote: The /etc/inittab defined the default init level as 2 and looking into /etc/rc2.d there are 2 scripts called /etc/init.d/readynas_startup and /etc/rc2.d/S02ToggleSwitchProCPUFan.
Looking at the file "/etc/init.d/readynas_startup" around line 375 you have:# RC2
sync
echo "." >$OUT
I made the following changes to "/etc/init.d/readynas_startup":# RC2
sync
echo "." >$OUT
Thanks! It worked.
Message 9 of 9
