× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Wrong link for ReadyNAS OS 6.2.4 src in GPL section
Hi,
Just to report that the link for ReadyNAS OS 6 6.2.4 sources is not working on http://kb.netgear.com/app/answers/detail/a_id/2649/~/netgear---open-source-code-for-programmers-%28gpl%29.
It's pointing to http://www.downloads.netgear.com/files/GPL/ReadyNASOS_V6.2.3_WW_src.zip...
I tried with ReadyNASOS_V6.2.4_WW_src.zip or ReadyNASOS-V6.2.4_WW_src.zip (as - and _ are mixed time to time...), but still get ERROR 404: Not Found.
I need the sources to recompile kernel modules and proceed to the upgrade 😄
Already had issues by the past with sources not containing the correct kernel sources by the way... hope that will be fine this time.
Message 1 of 4
mdgm-ntgr
NETGEAR Employee Retired
Re: Wrong link for ReadyNAS OS 6.2.4 src in GPL section
See http://www.readynas.com/forum/viewtopic.php?p=458767
6.2.4 has minimal changes from 6.2.3 and uses the same kernel
Message 2 of 4
berkut1
Tutor
mdgm
The topic link you provided does not work for me.
It opens a web page that points to the topic of the forum, not the tread you intended.
Message 3 of 4
Guru
@berkut1 wrote:
mdgm
The original post just says that there were no open source changes for 6.2.4, so they didn't redo the zip..
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3562 views
  • 0 kudos
  • 4 in conversation
Announcements
