Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
goto unexpected state 'failed'
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-17
05:18 AM
2015-02-17
05:18 AM
I'm getting the following on my log for an addon I created
The application log shows nothing, is there any log I can get more info?
Thank you
Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'inactive'('deactivating').
Thank you
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-17
07:18 AM
2015-02-17
07:18 AM
Re: goto unexpected state 'failed'
What do you have in that file?
Envoyé de mon iPhone en utilisant Tapatalk
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-17
07:39 AM
2015-02-17
07:39 AM
Hi poussin, here is the full log:
Here is the repo with the contents for couchpotato files
https://github.com/diego-vieira/ReadyNAS-Add-ons
Logs begin at Sat, 14 Feb 2015 15:57:29 -0300, end at Sun, 15 Feb 2015 23:58:12 -0300.
Feb 16 22:53:17 ReadyNAS readynasd[1634]: PropertyChanged (/ethernet_2cb05dbf1c24_cable): State=disconnect
Feb 16 22:53:17 ReadyNAS readynasd[1634]: PropertyChanged (/): State=idle
Feb 16 22:53:17 ReadyNAS readynasd[1634]: PropertyChanged (/ethernet_2cb05dbf1c24_cable): State=idle
Feb 16 22:53:17 ReadyNAS readynasd[1634]: Service ethernet_2cb05dbf1c24_cable removed
Feb 16 22:53:31 ReadyNAS readynasd[1634]: Service ethernet_2cb05dbf1c24_cable changed
Feb 16 22:53:32 ReadyNAS readynasd[1634]: Radar: create_single_run_worker(radarworker) failed
Feb 16 22:53:32 ReadyNAS readynasd[1634]: PropertyChanged (/ethernet_2cb05dbf1c24_cable): State=ready
Feb 16 22:53:32 ReadyNAS readynasd[1634]: PropertyChanged (/): State=ready
Feb 16 23:16:36 ReadyNAS readynasd[1634]: Application 'couchpotato_2.6.1_all.deb' is installed successfully.
Feb 16 23:18:54 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'active'('activating').
Feb 16 23:19:48 ReadyNAS readynasd[1634]: Error proxy call. GDBus.Error:org.freedesktop.systemd1.NoSuchUnit: Unit fvapp-transmissionr6.service is not loaded.
Feb 16 23:19:48 ReadyNAS readynasd[1634]: Service 'fvapp-transmissionr6.service' goto unexpected state 'inactive'. Expect to be 'active'('activating').
Feb 16 23:19:48 ReadyNAS readynasd[1634]: Application 'Transmission for Readynas' is installed successfully.
Feb 16 23:23:13 ReadyNAS readynasd[1634]: Protocol 'http' is restarted
Feb 16 23:23:13 ReadyNAS readynasd[1634]: Service 'apache2.service' goto unexpected state 'deactivating'. Expect to be 'active'('activating').
Feb 16 23:31:01 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'inactive'('deactivating').
Feb 16 23:32:05 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'inactive'. Expect to be 'active'('activating').
Feb 16 23:33:42 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'active'('activating').
Feb 16 23:40:59 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'inactive'('deactivating').
Feb 16 23:41:02 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'active'('activating').
Feb 16 23:41:03 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'inactive'('deactivating').
Feb 16 23:42:35 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'active'('activating').
Feb 16 23:46:23 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'inactive'('deactivating').
Feb 16 23:47:54 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'active'('activating').
Feb 16 23:47:54 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'inactive'('deactivating').
Feb 16 23:49:39 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'active'('activating').
Feb 17 00:35:04 ReadyNAS readynasd[1634]: Error proxy call. Timeout was reached
Feb 17 00:43:47 ReadyNAS readynasd[1634]: Cannot apply access acl to /media/USB_HDD_1. errno=95
Feb 17 00:43:47 ReadyNAS readynasd[1634]: access acl
Feb 17 00:43:47 ReadyNAS readynasd[1634]: user::rwx
Feb 17 00:43:47 ReadyNAS readynasd[1634]: user:admin:rwx
Feb 17 00:43:47 ReadyNAS readynasd[1634]: group::rwx
Feb 17 00:43:47 ReadyNAS readynasd[1634]: group:admin:rwx
Feb 17 00:43:47 ReadyNAS readynasd[1634]: mask::rwx
Feb 17 00:43:47 ReadyNAS readynasd[1634]: other::rwx
Feb 17 00:43:47 ReadyNAS readynasd[1634]: apply_acl(/media/USB_HDD_1) err=95:
Feb 17 00:43:48 ReadyNAS readynasd[1634]: acl
Feb 17 00:43:48 ReadyNAS readynasd[1634]: user::rwx
Feb 17 00:43:48 ReadyNAS readynasd[1634]: user:admin:rwx
Feb 17 00:43:49 ReadyNAS readynasd[1634]: group::rwx
Feb 17 00:43:49 ReadyNAS readynasd[1634]: group:admin:rwx
Feb 17 00:43:49 ReadyNAS readynasd[1634]: mask::rwx
Feb 17 00:43:49 ReadyNAS readynasd[1634]: other::rwx
Feb 17 00:44:02 ReadyNAS readynasd[1634]: External storage device connected.
Feb 17 00:46:33 ReadyNAS readynasd[1634]: Error proxy call. Timeout was reached
Feb 17 00:47:02 ReadyNAS readynasd[1634]: External storage device disconnected.
Feb 17 08:13:16 ReadyNAS readynasd[1634]: Antivirus scanner definition file has been updated to '201502170834'.
Feb 17 08:51:38 ReadyNAS readynasd[1634]: Disk Model:WDC WD20EARX-00PASB0 Serial:WD-WCAZAF610268 has been added to Channel '2' of the head unit.
Feb 17 08:55:50 ReadyNAS readynasd[1634]: Rebuilding started for Volume 'data'.
Feb 17 08:56:00 ReadyNAS readynasd[1634]: Volume 'data' health changed from 'Unprotected' to 'Degraded'.
Feb 17 09:35:01 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'inactive'('deactivating').
Feb 17 09:36:32 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'deactivating'. Expect to be 'active'('activating').
Feb 17 09:54:42 ReadyNAS readynasd[1634]: Application 'Plex Media Server' is uninstalled successfully.
Feb 17 09:54:54 ReadyNAS readynasd[1634]: Cannot send event message. fd=15
Feb 17 09:57:37 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'failed'. Expect to be 'inactive'('deactivating').
Feb 17 09:59:08 ReadyNAS readynasd[1634]: Service 'fvapp-couchpotato.service' goto unexpected state 'deactivating'. Expect to be 'active'('activating').
Feb 17 09:59:24 ReadyNAS readynasd[1634]: Protocol 'daap' is restarted
Feb 17 10:00:42 ReadyNAS readynasd[1634]: Protocol 'daap' is restarted
Feb 17 10:01:39 ReadyNAS readynasd[1634]: Protocol 'daap' is restarted
Feb 17 10:01:41 ReadyNAS readynasd[1634]: Protocol 'replicate' is stopped
Feb 17 10:02:00 ReadyNAS readynasd[1634]: Service 'forked-daapd.service' goto unexpected state 'deactivating'. Expect to be 'active'('activating').
Feb 17 10:02:02 ReadyNAS readynasd[1634]: Protocol 'replicate' is stopped
Feb 17 10:02:25 ReadyNAS readynasd[1634]: Protocol 'daap' is restarted
Feb 17 10:02:27 ReadyNAS readynasd[1634]: Protocol 'replicate' is stopped
Message 3 of 3
