Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Error with replication
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-03-19
02:42 AM
2013-03-19
02:42 AM
I have been testing replicating folders from one drive to another and vice versa with Replicate. The replication both worked fine when they are on the local LAN but I have now moved one to another site and since then I can run the replication job from site 1 to 2 without problems but the replication from 2 to 1 give the following errors.
Any advice as to what might be causing this?
Log:
2013-03-19 08:48:02 Starting backup job "GlenshielRd_NAS"
2013-03-19 08:48:02 Replicate addon version: 1.1.6 build R1
2013-03-19 08:48:02 Locking target folder: /c/GlenshielRd_Remote/GlenshielRd_NAS
2013-03-19 08:48:05 Resume source is "/c/GlenshielRd_Remote/GlenshielRd_NAS/2013-03-19 03-00 (failed)/data"
2013-03-19 08:48:05 p2p connect to GlenshielRd_NAS in 1351933 network
2013-03-19 08:48:12 Connection method: 0
2013-03-19 08:48:12 LAN connection not available
2013-03-19 08:48:12 Using p2p connection
2013-03-19 08:48:12 Initializing snapshot on source device
2013-03-19 08:48:12 Sending task to source device
2013-03-19 08:48:12 Awaiting task report
2013-03-19 08:48:15 Received success report
2013-03-19 08:48:15 Snapshot initialization finished
2013-03-19 08:48:15 Copy in progress
2013-03-19 09:13:40 Copy failed
2013-03-19 09:13:41 Deinitializing snapshot on source device
2013-03-19 09:13:41 Sending task to source device
2013-03-19 09:13:51 Unable to send task
2013-03-19 09:13:51 Snapshot deinitialization failed
2013-03-19 09:13:51 p2p disconnect with GlenshielRd_NAS in 1351933 network
2013-03-19 09:13:51 Unlock target folder: /c/GlenshielRd_Remote/GlenshielRd_NAS
2013-03-19 09:13:51 Job finished
Files:null
Summary:
Copy start time: 2013-03-19 08:48
Total files processed: 4
Total files transferred: 0
Total files size: 3.50 GB
Total files size transferred: 3.50 GB
Average speed: 2.35 MB/s
Exit code: 30 (Data send/receive timeout)
Copy end time: 2013-03-19 09:13
Log:
Files:null
Summary:
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-03
12:59 PM
2013-04-03
12:59 PM
Re: Error with replication
Are your jobs completed?
What I mean is, say you have a backup job scheduled and specified to keep 3 versions; has the job been left to run completely so that you have three versions on the destination NAS?
After the backups are completed, subsequent backups will be incremental so the data transferred will be much smaller.
Also, I noticed you seem to be trying to replicate 4 files that total 3.5GB in size; I found the hard way that replicate doesn't seem to work well with such large files. It seems to do much better with multiple smaller files.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-03
02:10 PM
2013-04-03
02:10 PM
Please verify if snapshot is enabled on both NAS devices. If not, the snapshot/compression option should be disabled in Replicate. Once the changes are made, re-run the backup job.
Message 3 of 3
