eton's avatar
eton
Luminary
Sep 19, 2013
How? Transmission Remote GUI path for containing folder
How do I setup Transmission Remote GUI path to open containing folder in the OS X client?
Transmission Remote GUI > Tools > Connection options... > Paths
These settings does not work:
  • Sorry to dredge up an old topic but this is one of the top Google results for this question. I figured out how to do it on my Windows machine:
    My downloads folder on my ReadyNAS is /c/media/Downloads and the network share for that folder is \\hostname\media\Downloads (NB Windows backslashes). So my path mapping is:
    /c/media/Downloads=\\hostname\media\Downloads
    Now I can use the Open containing folder option in the right click menu on my torrents. Hope that helps.
  • Thanks. Ah, i misunderstood the example.
    This seems correct, but doesn't work on OS X:
    /c/media/BitTorrent=/Volumes/media/BitTorrent
    Nor did this:
    /c/media/BitTorrent=afp://duo (AFP)._afpovertcp._tcp.local/media/BitTorrent
    I can find a lot of success stories for making this work on PC, but no luck setting up folder path on OS X with Transmission Remote GUI 4.1 so far.
    Nor did this:
    The following has been working for me:
    /data/Transmission/Downloads/=afp:\\HostnameOfMyNAS\Transmission\Downloads\
    Wow, interesting. Backslashes on OS X? Looks crazy. Does it really work for you on OS X? Or do you run OS X virtually or something like that? It did not work for me (I tried with both server name and IP number).
  • OMG! I solved it with your help. The server path is NOT the full local path, just the "mapped" path as the server sees it (I don't know how to express it better).
    This worked for me!
    /media/BitTorrent/=afp:\\[server name or IP]\media\BitTorrent\
    With that knowledge, the mapped drive method also works and it's faster:
    Note that the "Open containing folder" function only works with fully downloaded files (or with other words not for files stored in the incomplete folder). Also note that Transmission Remote GUI doesn't care if you use forward or backward slashes.
    The local path on the server is as (as you know) /c/media/BitTorrent/ but to make it work with Transmission Remote GUI you will have to modify it to what is shown over the network, in this case: /media/BitTorrent/. Messy
    I don't know how I came up with it, but it works on Mountain Lion and (as I've checked just now) on Mavericks.
    Note: AFP should be enabled for the folder.
    This worked for me!
    I think the code from my previous message is a safer bet, because you're line of code uses a mapped folder on the server (i.e. /media/BitTorrent). I've just checked, and it appears it's not a default map/mount. I've ssh'ed to my ReadyNas, no mount points in /media, but Transmission seems to use /data/Transmission anyway by default.
    If you've opened a folder from Transmission Remote GUI once, the next one will be faster because you probably stay connected.
    Glad it worked for you Eton!
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    nasischijf this forum is for legacy ReadyNAS. With the new OS that you are running there are different mount points.
    Sorry you're right, I didn't notice!
ProSupport for Business
