× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
NetGear ReadyNas NV+: Transmission 2.42 (remote access)
pox1
Follower
1. How do I remotely access to Transmission from another place?
2. How do I get magnet link to work from another place/home?
Message 1 of 2
JarnoG
Guide
Re: NetGear ReadyNas NV+: Transmission 2.42 (remote access)
You have to make sure that you set these options in settings.json:
"rpc-authentication-required": true,
"rpc-enabled": true,
"rpc-password": "enter your password",
"rpc-port": 12345,
"rpc-username": "enter your username",
You will have to forward the port in your router if you want to access Transmission from over the internet.
I am using Transmission Remote dotnet to access Transmission on my NAS. You can also use Transmission Remote GUI if you don't use Windows or if you don't want to install any software, the standard Transmission webgui is also available.
As far as I know, they can all add magnet links.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3338 views
  • 0 kudos
  • 2 in conversation
Announcements
