Orbi WiFi 7 RBE973
Reply
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
tarobun
Tutor
Re: New Transmission 2.82 add-on for ReadyNAS Duo/NV+ (sparc
By default the web ui is available at port 9091 of your NAS (ie. http://a.b.c.d:9091/transmission/web/)
If it's not coming up, try reloading/refreshing the web page or try with another browser.
If it still doesn't work try rebooting the NAS.
Message 101 of 160
pepsi1
Here's my feedback on the addon.
In short words: No can do..
For instance:
in start.sh: transmission-daemon is send to the foreground by the '-f ' option. But when the start-stop-daemon is called to throw the transmission-daemon to the background, the command breaks on the first fact. The correct option would be the '-g' and than the location of the 'settings.json'file. But if you set the TRANSMISSION_HOME variable correctly, you don't need that option.
Second. The environment variable "TRANSMISSION_HOME" is set incorrectly. This must be set tot the same directory as where the 'settings.json' file is.
Third: binaries does not belong into the '/etc' directory. Binaries belong (in this case) in /usr/local/bin
Message 102 of 160
tarobun
Tutor
I find that if I don't use the '-f' (foreground) option the settings don't get saved when the addon is stopped. Probably should remove the --background option in start.sh as it is redundant in this case.
Not sure why you think TRANSMISSION_HOME is set incorrectly. It is set to '/c/addons-config/Transmission' which is where the settings.json is found.
For the binaries, I prefer to put all the files in one directory so they are easy for me to find. For me (and others I'm guessing) it doesn't really matter as we don't remote into the NAS to run the transmission commands directly. But feel free to move them to /usr/local/bin
*shrug* Works for me.
Message 103 of 160
InTheShires
Tutor
Me too mate.
Very grateful most are as well.
Message 104 of 160
raider125jeigh
i'm unable to transfer or delete files coming from the Bitorrent folder... it says access denied.. i can copy files without issue..
any help will be greatly appreciated
Message 105 of 160
raider125jeigh
btw heres the error that im getting whenever im trying to delete or move the file
you require permission to unix user\nobody to make changes on this file
Message 106 of 160
kels
Many thanks for this update.
Has the email alert function been removed?
I've configured my NV+ to use an external email server, installed the 'email_alert' script and changed the relevant setting to 'true' in the settings file - but it still doesn't work for me.
Am I missing something here?
Thanks
kels
Message 107 of 160
tarobun
Tutor
Edit the settings.json file and set the umask to 0.
Message 108 of 160
tarobun
Tutor
Not that I know of but I don't use that functionality so not sure.
Message 109 of 160
emk1
Thanks
kels
@Kels
I'm still using the email alerting facility from the SuperPoussin version. I remember having issues initially when I wanted to get emails. I had it all configured but it would just never send an email. Turns out it was permissions on the script file weren't set to 'x' (execute) so it could never be called. After that it was fine. Not long ago I combined my email alert script with an unrar/unzip script to extract torrents after completion which makes my life a bit easier.
Message 110 of 160
kels
@emk
My email_alert file permissions are set as: -rwxrwxrwx+
Here's a copy of my file for exim:
#!/bin/sh
NAIL=/usr/bin/nail
SMTP_SERVER=smtp.orange.fr
SUBJECT="Torrent Done!"
if [ -f /etc/frontview/alert.conf ]; then
EmailTo=`/bin/grep "email" /etc/frontview/alert.conf | /usr/bin/awk -F '!!' '{ print $2 }' | /usr/bin/awk -F ',' '{ print $1 " " $2 " " $3 }'`
else
EmailTo=`/bin/grep "email" /frontview/conf/alert.conf | /usr/bin/awk -F '!!' '{ print $2 }' | /usr/bin/awk -F ',' '{ print $1 " " $2 " " $3 }'`
fi
if [[ "$(readlink `which sendmail`)" = "/usr/bin/msmtp" ]]; then
EmailFrom=`/bin/grep '^from' /etc/msmtprc | /usr/bin/cut -f2 -d' '`
else
EmailFrom=`/bin/echo $EmailTo | awk '{ print $1 }'`
fi
echo "From:$EmailFrom To:$EmailTo"
# Create the email message
EmailFile=/tmp/tmp_email.txt
if [ -f "$EmailFile" ]; then
rm -f $EmailFile
fi
touch $EmailFile
# Create the message headers
echo "Date: `date -R`" >> $EmailFile
echo "From: $EmailFrom" >> $EmailFile
echo "To: $EmailTo" >> $EmailFile
echo "Subject:Torrent Done!" >> $EmailFile
echo "MIME-Version: 1.0" >> $EmailFile
echo "Content-Type: text/plain; charset=ISO-8859-1" >> $EmailFile
echo "" >> $EmailFile
# Create the message body
/bin/echo " Hostname: $HOSTNAME" >> $EmailFile
/bin/echo "Transmission finished downloading \"$TR_TORRENT_NAME\" on $TR_TIME_LOCALTIME" >> $EmailFile
/bin/echo "" >> $EmailFile
/bin/echo "----------------------------------------------------------------------" >> $EmailFile
/bin/echo "Your add-ons developer Super-Poussin" >> $EmailFile
/bin/cat $EmailFile |/usr/sbin/sendmail -f $EmailFrom $EmailTo
#$NAIL -v -S from="$EmailFrom" -S smtp -s "$SUBJECT" -S smtp=$SMTP_SERVER "$EmailTo" < $EmailFile
rm -f $EmailFile
# you can use nail instead of readynas exim in this case : #
# uncomment the $NAIL line #
# comment the message header section #
# put a correct SMTP_SERVER value #
# this script will work with exim if you use custom parateters in frontview aka you specify : #
# username #
# smtp server ans so on #
Test exim emails get through - but nothing from Transmission!
Message 111 of 160
emk1
Kels, you appear to have the stock email script. Compared to my own, in the second line of the script the stock SMTP_SERVER=smtp.orange.fr I changed to whatever smtp resource I am using in Frontview alert (ie: smtp.gmail.com). Not sure if this has an impact. If you can receive test emails from within the Frontview alert testing function then my experience is that Tranmission should work also.
For your reference my relevant settings are below. I think your file permissions would be fine since all users have execute. Make sure you set the script variables correctly. My script is different as mentioned previously because I chucked in an extraction command.
# pwd
# ls -l|grep email
-rwxr-xr-x 1 nobody nogroup 4097 Apr 21 11:21 unrar_email.sh
# cat settings.json|grep script
"script-torrent-done-enabled": true,
"script-torrent-done-filename": "/c/addons-config/Transmission/unrar_email.sh",
I hope this helps you out.
Message 112 of 160
emk1
Oh most importantly, if you intend on making any changes to settings.json you have to stop Transmission first. Any changes that made to settings.json whilst Transmission is running are lost when Transmission stops. Stop the service, save your changes, then start Transmission again.
Message 113 of 160
eton
Luminary
I uninstalled super-poussin's and WhoCare's Transmission versions. Deleted the folders and rebooted. Installed tarobun's version stopped it and edited the settings file (with inspiration from super-poussin's). Started it. But nothing seems to happen. And no error message alert.
One sign of that something is wrong is that my password was not encrypted and my modifed port setting was dismissed.
Can anyone detect what's wrong with my settings (or if thats the error):
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": true,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1",
"cache-size-mb": 2,
"dht-enabled": true,
"download-dir": "/c/media/BitTorrent",
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 1,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/c/media/BitTorrent/Incomplete",
"incomplete-dir-enabled": true,
"lazy-bitfield-enabled": true,
"lpd-enabled": false,
"max-peers-global": 200,
"message-level": 2,
"open-file-limit": 32,
"peer-congestion-algorithm": "",
"peer-limit-global": 200,
"peer-limit-per-torrent": 50,
"peer-id-ttl-hours": 6,
"peer-port": 51413,
"peer-port-random-enabled": 0,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"port-forwarding-enabled": true,
"preallocation": 1,
"prefetch-enabled": 0,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": true,
"rename-partial-files": true,
"rpc-authentication-required": true,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "pass",
"rpc-port": 8181,
"rpc-url": "/transmission/",
"rpc-username": "user",
"rpc-whitelist": "127.0.0.1,10.0.0.*,192.168.*.*",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 400,
"speed-limit-down-enabled": false,
"speed-limit-up": 20,
"speed-limit-up-enabled": true,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 0,
"upload-slots-per-torrent": 14,
"utp-enabled": true,
"watch-dir": "/c/media/BitTorrent/sources/",
"watch-dir-enabled": true
Message 114 of 160
fastfwd
Virtuoso
No closing brace. (Or did you just copy it incompletely?)
No comma after "utp-enabled": true .
Maybe missing punctuation elsewhere, too; those are just the first errors I saw.
There are online JSON validators... You might want to run your file through one to make sure it's error-free.
Message 115 of 160
eton
Luminary
Thanks fastfwd
Yep I didn't copy the closing brace. I added a comma after "utp-enabled": true. And edited the post above.
And ran a validator, with no errors.
Still the same problem. Transmission starts but nothing happens, and the indicator icon in the upper right corner of the Transmisson modul panel stays grey.
How can I debug this? I've never had problems with Transmission or any other addons before.
Message 116 of 160
tarobun
Tutor
How are you with unix command line? If you are familiar then you can try the following:
tarobun wrote:
To run from command line enter:
cd /etc/frontview/addons/bin/TRANSMISSION
./transmission-daemon --logfile /var/tmp/transmission.log
To view log file:
cat /var/tmp/transmission.log
If not, then there are a few things in the config you could try and remove the following settings as they don't exists anymore (see https://trac.transmissionbt.com/wiki/EditConfigFiles😞
Also check the line endings in the text file, I think they should be unix style line ending (\x0a)
Message 117 of 160
eton
Luminary
To view log file:
Thanks.
I'm ok with the command line.
I did all the stuff above.
I did some of the settings.json editing on OS X. So for safety I changed the line endings in vi with ":set ff=unix". Ref:
http://stackoverflow.com/questions/8272 ... ngs-in-vim
http://stackoverflow.com/questions/3569 ... -text-file
http://stackoverflow.com/questions/1213 ... -of-a-file
But the problems remain. At first there was nog log file, but after starting Transmission from command line I got this:
# cat /var/tmp/transmission.log
[15:59:41.480] Transmission 2.82 (14160) started (session.c:738)
[15:59:41.481] RPC Server Adding address to whitelist: 127.0.0.1 (rpc-server.c:828)
[15:59:41.481] RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (rpc-server.c:1035)
[15:59:41.481] RPC Server Whitelist enabled (rpc-server.c:1039)
[15:59:41.482] UDP Failed to set receive buffer: requested 4194304, got 1048576 (tr-udp.c:78)
[15:59:41.482] UDP Please add the line "net.core.rmem_max = 4194304" to /etc/sysctl.conf (tr-udp.c:83)
[15:59:41.482] UDP Failed to set send buffer: requested 1048576, got 524288 (tr-udp.c:89)
[15:59:41.482] UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:94)
[15:59:41.482] DHT Generating new id (tr-dht.c:310)
[15:59:41.482] Using settings from "/root/.config/transmission-daemon" (daemon.c:526)
[15:59:41.482] Saved "/root/.config/transmission-daemon/settings.json" (variant.c:1217)
[15:59:41.482] Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:73)
[15:59:41.482] Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:73)
[15:59:47.540] Port Forwarding Starting (port-forwarding.c:95)
[15:59:48.550] Port Forwarding (NAT-PMP) readnatpmpresponseorretry succeeded (0) (natpmp.c:73)
[15:59:48.550] Port Forwarding (NAT-PMP) Found public address "95.347.429.326" (natpmp.c:142)
[15:59:48.550] Port Forwarding (NAT-PMP) sendnewportmappingrequest succeeded (12) (natpmp.c:73)
[15:59:48.550] Port Forwarding (NAT-PMP) Port 51413 forwarded successfully (natpmp.c:222)
[15:59:48.550] Port Forwarding Forwarded (port-forwarding.c:95)
[16:00:16.830] DHT Attempting bootstrap from dht.transmissionbt.com (tr-dht.c:248)
[16:05:02.520] Transmission 2.82 (14160) started (session.c:738)
[16:05:02.521] RPC Server Adding address to whitelist: 127.0.0.1 (rpc-server.c:828)
[16:05:02.521] RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (rpc-server.c:1035)
[16:05:02.522] RPC Server Whitelist enabled (rpc-server.c:1039)
[16:05:02.522] Couldn't bind port 51413 on 0.0.0.0: Address already in use (Is another copy of Transmission already running?) (net.c:371)
[16:05:02.522] UDP Couldn't bind IPv4 socket (tr-udp.c:263)
[16:05:02.522] DHT Generating new id (tr-dht.c:310)
[16:05:02.522] Using settings from "/root/.config/transmission-daemon" (daemon.c:526)
[16:05:02.522] Saved "/root/.config/transmission-daemon/settings.json" (variant.c:1217)
[16:05:02.522] Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:73)
[16:05:02.522] Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:73)
[16:05:08.580] Port Forwarding Starting (port-forwarding.c:95)
[16:05:09.590] Port Forwarding (NAT-PMP) readnatpmpresponseorretry succeeded (0) (natpmp.c:73)
[16:05:09.590] Port Forwarding (NAT-PMP) Found public address "95.347.429.326" (natpmp.c:142)
[16:05:09.590] Port Forwarding (NAT-PMP) sendnewportmappingrequest succeeded (12) (natpmp.c:73)
[16:05:09.590] Port Forwarding (NAT-PMP) Port 51413 forwarded successfully (natpmp.c:222)
[16:05:09.590] Port Forwarding Forwarded (port-forwarding.c:95)
[16:06:17.240] Saved "/root/.config/transmission-daemon/settings.json" (variant.c:1217)
[16:06:17.240] DHT Not saving nodes, DHT not ready (tr-dht.c:358)
[16:06:17.241] Port Forwarding Stopped (port-forwarding.c:183)
[16:06:17.241] Port Forwarding (NAT-PMP) sendnewportmappingrequest succeeded (12) (natpmp.c:73)
[16:06:17.241] Port Forwarding Stopping (port-forwarding.c:95)
[16:06:17.280] Saved "/root/.config/transmission-daemon/settings.json" (variant.c:1217)
[16:06:17.280] DHT Not saving nodes, DHT not ready (tr-dht.c:358)
[16:06:17.281] Port Forwarding Stopped (port-forwarding.c:183)
[16:06:17.281] Port Forwarding (NAT-PMP) sendnewportmappingrequest succeeded (12) (natpmp.c:73)
[16:06:17.281] Port Forwarding Stopping (port-forwarding.c:95)
The logfile tells about:
What settings file is that?
Message 118 of 160
tarobun
Tutor
Ah... oops, forgot 2 extra commands:
export TRANSMISSION_HOME=/c/addons-config/Transmission
export TRANSMISSION_WEB_HOME=/etc/frontview/addons/ui/TRANSMISSION/web
./transmission-daemon -f --logfile /var/tmp/transmission.log
give it a few seconds then ctrl-c to stop the daemon then view the log file for errors.
Message 119 of 160
eton
Luminary
Thanks
Now it looks like this:
[14:00:43.286] Transmission 2.82 (14160) started (session.c:738)
[14:00:43.287] RPC Server Adding address to whitelist: 127.0.0.1 (rpc-server.c:828)
[14:00:43.287] RPC Server Adding address to whitelist: 10.0.0.* (rpc-server.c:828)
[14:00:43.288] RPC Server Adding address to whitelist: 192.168.*.* (rpc-server.c:828)
[14:00:43.288] RPC Server Serving RPC and Web requests on port 127.0.0.1:8181/transmission/ (rpc-server.c:1035)
[14:00:43.288] RPC Server Whitelist enabled (rpc-server.c:1039)
[14:00:43.288] RPC Server Password required (rpc-server.c:1042)
[14:00:43.288] UDP Failed to set receive buffer: requested 4194304, got 1048576 (tr-udp.c:78)
[14:00:43.288] UDP Please add the line "net.core.rmem_max = 4194304" to /etc/sysctl.conf (tr-udp.c:83)
[14:00:43.288] UDP Failed to set send buffer: requested 1048576, got 524288 (tr-udp.c:89)
[14:00:43.288] UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:94)
[14:00:43.288] DHT Reusing old id (tr-dht.c:306)
[14:00:43.288] DHT Bootstrapping from 114 IPv4 nodes (tr-dht.c:154)
[14:00:43.288] Using settings from "/c/addons-config/Transmission" (daemon.c:526)
[14:00:43.288] Saved "/c/addons-config/Transmission/settings.json" (variant.c:1217)
[14:00:43.288] transmission-daemon requiring authentication (daemon.c:546)
[14:00:43.289] Watching "/c/media/BitTorrent/sources/" for new .torrent files (daemon.c:564)
[14:00:43.289] Using readdir to watch directory "/c/media/BitTorrent/sources/" (watch.c:163)
[14:00:43.289] Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:73)
[14:00:43.289] Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:73)
[14:00:48.314] Port Forwarding Starting (port-forwarding.c:95)
[14:00:48.535] Saved "/c/addons-config/Transmission/settings.json" (variant.c:1217)
[14:00:48.535] DHT Not saving nodes, DHT not ready (tr-dht.c:358)
[14:00:48.535] Port Forwarding Stopped (port-forwarding.c:183)
Message 120 of 160
tarobun
Tutor
Looks fine.... so what's the problem you're seeing?
Message 121 of 160
eton
Luminary
Hmm, strange.
The problem is that Transmission doesn't start. And I can't access the web gui. But after I executed your commands Transmission read the settings and encrypted my password. So something has changed. But it still don't work.
It might be better to start all over. How do I get rid of Transmission completely? Will it be enough to remove the add-on from Frontview and then the rest that is left of these:
# find / \( -path '/c' -o -path '/USB' \) -prune -or -iname '*transmission*' -exec ls -ld {} \;
-rw-r--r-- 1 admin admin 206 Aug 10 2013 /etc/frontview/apache/addons/TRANSMISSION.conf
drwxr-xr-x 4 admin admin 16384 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION
-rw-r--r-- 1 admin admin 437 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/language/en-us/TRANSMISSION.str
drwxr-xr-x 3 admin admin 16384 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/web/style/transmission
-rw-r--r-- 1 admin admin 43146 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/web/javascript/transmission.js
-rw-r--r-- 1 admin admin 1334 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/TRANSMISSION.html
-rw-r--r-- 1 admin admin 8135 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/TRANSMISSION.js
-rw-r--r-- 1 admin admin 488 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/TRANSMISSION.xml
-rwxr-xr-x 1 admin admin 2743 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/TRANSMISSION_HANDLER.pl
drwxr-xr-x 2 admin admin 16384 Oct 28 2012 /etc/frontview/addons/bin/TRANSMISSION
-rwxr-xr-x 1 admin admin 588300 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-daemon
-rwxr-xr-x 1 admin admin 615028 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-remote
-rwxr-xr-x 1 admin admin 580228 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-create
-rwxr-xr-x 1 admin admin 580128 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-edit
-rwxr-xr-x 1 admin admin 580168 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-show
-rwxr-xr-x 1 admin admin 580016 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-cli
-rw-r--r-- 1 admin admin 825 Apr 29 01:11 /etc/frontview/addons/TRANSMISSION.remove
drwxr-xr-x 5 root root 16384 Apr 29 16:06 /root/.config/transmission-daemon
-rwxr-xr-x 1 root root 7593660 Oct 31 2011 /usr/local/bin/transmission-cli
-rwxr-xr-x 1 root root 7808113 Oct 31 2011 /usr/local/bin/transmission-create
-rw-r--r-- 1 root root 6095 Jan 14 2009 /usr/local/man/man1/transmission-remote.1
-rw-r--r-- 1 root root 2964 Jan 14 2009 /usr/local/man/man1/transmission-daemon.1
-rw-r--r-- 1 root root 3838 Jan 14 2009 /usr/local/man/man1/transmissioncli.1
-rw-rw-rw- 1 root root 5 Apr 29 16:12 /var/run/TRANSMISSION.pid
-rw-r--r-- 1 root root 8644 May 1 14:00 /var/tmp/transmission.log
Or do I have to tinker with some other files?
And what is /root/.config/ ?
Message 122 of 160
tarobun
Tutor
Looks like there are some old transmission files:
Best way to start again is to install the same add-on and then uninstall it. It should remove all related add-on files.
The /root/.config/transmission-daemon is the default location of the config files if you do not specify the TRANSMISSION_HOME env variable. You can safely delete this directory.
Message 123 of 160
eton
Luminary
I actually did install and uninstall super-poussin' and WhoCares' Transmission versions before installing your version. But now I went through that procedure again. Uninstalled yours, installed WhoCares' version and uninstalled it, installed super-poussin' and uninstalled. But these files remains:
drwxrwsr-x 2 root admin 16384 May 4 10:34 /etc/transmission-daemon
-rw-r--r-- 1 nobody nogroup 6 May 4 10:44 /var/run/transmission-daemon.pid
Can those files be safely deleted?
Message 124 of 160
eton
Luminary
Update. I deleted the files listed above (also /c/addons-config/Transmission) and after that the installation of tarobun's Transmission went just fine!
Message 125 of 160
Discussion stats
Announcements
