× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Transmission 2.42 Performance Problem
MrAsker
Tutor
I have a strange performance problem that I can't make heads and tails of. Maybe anybody have any ideas,?
What I see is that shortly after I start Transmission I get decent DL speed and UL speeds, approx 1Mb+ cs 80-90 kb/sec. After a few hours or after the first files have completed to DL the DL speed drops to 20-50 kb/s and the UL speed drops to 2-6 kbits/s. Stopping Transmission and restarting it usually but not always brings the speed up again.
Som facts:
- I've got a NV+ with 1Gb RAM, RAIDiator 4.1.8 and Transmission 2.42. I've got plenty of space available on the NAS, even on the hdc1.
- My Internet connection is a 24/1 Mbit xDSL line and I've checked so I know I get at least 13/1 which would allow me to DL with roughly 1.3-1.4 Mb/sec but atleast 1Mb/sec.
- I do not have any speedlimitations set
- The NAS is connected to a WNDR3800 thru a 1Gbit/s Netgear switch so I have plenty of speed avaialble there
- I've even done tests with only the NAS and my laptop connected (ie. disconnected the AppleTV 2:nd Gen, the PS3, the AirportExpress, my Server, our TV, the HD-box, my wifes laptop and my daughters laptop).
- I've gone thru the motions with changing the settings.json parameters for cache, peers, not using the default BT ports, etc. so I'm quite sure this is not the problem, although if someone can share their settings I'm interested.
- I have tried different versions of Transmission but either they have the same problem or they have other worse issues, like crashing.
- I've tried the built in BT client which provides much better speed but much less functionality so I'm pretty sure it's not my ISP or the NAS that is the limitation and I'd rather run Transmission if I can since it is more feature rich.
Does anybody have any ideas?
Message 1 of 13
JarnoG
Guide
Re: Transmission 2.42 Performance Problem
If your router does not forward the right port to your NAS, you can not get new incoming connections. So, for as long as you are asking the tracker for new peers, you can download fast and you will upload to the peers that you are downloading from. However, incoming connections get blocked, so others will not connect to you. Eventually, this reduces the amount of peers you are connected to and with that, your download and upload speed.
You can check if you are forwarding the right port by going to the webinterface of Transmission and look at the Network-tab of the preference window. It should state if the port you've set is open or not. If your router supports upnp (and has it turned on), you can enable the option "use port forwarding from my router" to automatically forward the right port at startup.
Message 2 of 13
MrAsker
Tutor
Thanks for your reply
That does seem like the problem but ..
- I've got uPNP enabled in the WNDR3800
- I have the setting "use port forwarding ..." set for Transmission
- I'm randomizing the port but I've also tried with different fixed ports
- I've got the same ports specified in settings.json (60000-60999) and opened in the router
- Fixed or Random, all these ports are all sent to the NAS and both for UTP and TCP
- In the Router logs I can see that that the Portforwarding is done so I'm pretty sure this works
- On the NAS with Netstat -an | grep -i [portnumber] I can see that there are a lot of connections on the current portnumber
Regardless of this the WebGUI says "Status: Unknown" for the portforwarding and the speeds are as previously described.
Feels like I'm either missing something very simple but I can't see it or this is a very odd and very specific problem that "only" I have.
So, any other ideas? I'm open to any help and any suggestions.
Message 3 of 13
JarnoG
Guide
if the menu of the WNDR3800 is something like the one on my WNR2200, then there is a page with the current upnp ports. Can you check if the port assigned by Transmission is set to the right IP-address. It might happen that it registers the port-forwarding to the wrong IP, for instance that of the ReadyNAS Remote-IP (if you have that running).
This should not be a problem if you turn upnp off in Transmission and manually set the port in Transmission to a fixed one and forward that port to your NAS's IP.
Message 4 of 13
MrAsker
Tutor
I have the same page and if I remove the other devices and obscure the internal IP of the NAS to x.x and sort it by Ext Port it looks like this:
Active Protocol Int. Port Ext. Port IP Address
YES TCP 51413 51413 192.168.x.x
YES UDP 51413 51413 192.168.x.x
YES TCP 60116 60116 192.168.x.x
YES UDP 60116 60116 192.168.x.x
YES TCP 60148 60148 192.168.x.x
YES UDP 60148 60148 192.168.x.x
YES TCP 60176 60176 192.168.x.x
YES UDP 60176 60176 192.168.x.x
YES TCP 60179 60179 192.168.x.x
YES UDP 60179 60179 192.168.x.x
YES TCP 60221 60221 192.168.x.x
YES UDP 60221 60221 192.168.x.x
YES TCP 60288 60288 192.168.x.x
YES UDP 60288 60288 192.168.x.x
YES TCP 60328 60328 192.168.x.x
YES UDP 60328 60328 192.168.x.x
YES TCP 60352 60352 192.168.x.x
YES UDP 60352 60352 192.168.x.x
YES TCP 60494 60494 192.168.x.x
YES UDP 60494 60494 192.168.x.x
YES TCP 60576 60576 192.168.x.x
YES UDP 60576 60576 192.168.x.x
YES TCP 60579 60579 192.168.x.x
YES UDP 60579 60579 192.168.x.x
YES TCP 60608 60608 192.168.x.x
YES UDP 60608 60608 192.168.x.x
YES TCP 60644 60644 192.168.x.x
YES UDP 60644 60644 192.168.x.x
YES TCP 60651 60651 192.168.x.x
YES UDP 60651 60651 192.168.x.x
YES TCP 60655 60655 192.168.x.x
YES UDP 60655 60655 192.168.x.x
YES TCP 60702 60702 192.168.x.x
YES UDP 60702 60702 192.168.x.x
YES TCP 60806 60806 192.168.x.x
YES UDP 60806 60806 192.168.x.x
YES TCP 60839 60839 192.168.x.x
YES UDP 60839 60839 192.168.x.x
YES TCP 60861 60861 192.168.x.x
YES UDP 60861 60861 192.168.x.x
YES TCP 60991 60991 192.168.x.x
YES UDP 60991 60991 192.168.x.x
What strikes me as odd is that the Router seems to be simply creating a new port for every time I start Transmission and leaving the old port opened. At least I assume this is what I see since I can see the "old" static default port 51413 which I haven't used for a few weeks now. Is this the way it should look like? Or isn't it not one line per translation and not per connection, or? What I mean is if I look at the NAS with "netstat -an | grep :60*" I see hundreds of connections. Or how does this really work?
tcp 0 0 0.0.0.0:60221 0.0.0.0:* LISTEN
tcp 0 0 192.168.x.x:60221 92.32.244.205:49448 SYN_RECV
tcp 0 0 192.168.x.x:60221 107.9.141.65:25903 SYN_RECV
tcp 0 0 192.168.x.x:60221 98.210.232.180:62123 SYN_RECV
tcp 0 0 192.168.x.x:60221 203.31.34.25:35285 SYN_RECV
tcp 0 0 192.168.x.x:60221 213.37.63.196:36297 SYN_RECV
tcp 0 0 192.168.x.x:60221 112.205.250.46:50794 SYN_RECV
tcp 0 0 192.168.x.x:60221 62.216.15.152:49655 SYN_RECV
tcp 0 0 192.168.x.x:60221 213.74.225.157:55479 SYN_RECV
tcp 0 0 192.168.x.x:60221 176.45.113.43:50 SYN_RECV
tcp 0 0 192.168.x.x:60221 41.78.79.42:57676 SYN_RECV
tcp 0 0 192.168.x.x:60221 195.210.60.2:2991 SYN_RECV
tcp 0 0 192.168.x.x:60221 99.63.141.201:51081 SYN_RECV
tcp 0 0 192.168.x.x:60221 174.103.14.58:60680 SYN_RECV
tcp 0 0 192.168.x.x:60221 74.97.2.41:58720 SYN_RECV
tcp 0 0 192.168.x.x:60221 82.178.187.19:25861 SYN_RECV
tcp 0 0 192.168.x.x:60221 124.146.58.240:58355 SYN_RECV
tcp 0 0 192.168.x.x:60221 90.163.86.12:55522 SYN_RECV
tcp 0 0 192.168.x.x:60221 76.22.230.126:33085 SYN_RECV
tcp 0 0 192.168.x.x:60221 24.85.241.58:41952 SYN_RECV
tcp 0 0 192.168.x.x:60221 189.1.140.198:55774 SYN_RECV
tcp 0 0 192.168.x.x:60221 82.170.152.123:27243 SYN_RECV
tcp 0 0 192.168.x.x:60221 82.239.56.116:64000 SYN_RECV
tcp 0 0 192.168.x.x:60221 77.49.57.178:55199 SYN_RECV
tcp 0 0 192.168.x.x:60221 82.131.93.112:60490 SYN_RECV
tcp 0 0 192.168.x.x:60221 80.202.240.94:60771 SYN_RECV
tcp 0 0 192.168.x.x:60221 189.4.123.166:54896 SYN_RECV
tcp 0 0 192.168.x.x:60221 90.219.58.60:62525 SYN_RECV
tcp 0 0 192.168.x.x:60221 77.30.110.240:57069 SYN_RECV
tcp 0 0 192.168.x.x:60221 95.244.29.178:13289 SYN_RECV
tcp 0 0 192.168.x.x:60221 217.131.232.219:60526 SYN_RECV
tcp 0 0 192.168.x.x:60221 188.51.26.149:61859 SYN_RECV
tcp 0 0 192.168.x.x:60221 95.39.137.167:54375 SYN_RECV
tcp 0 0 192.168.x.x:60221 83.213.39.246:61817 SYN_RECV
tcp 0 0 192.168.x.x:60221 205.250.54.16:1653 SYN_RECV
tcp 0 0 192.168.x.x:60221 98.242.105.245:51102 SYN_RECV
tcp 0 0 192.168.x.x:60221 93.50.57.131:37658 SYN_RECV
tcp 0 0 192.168.x.x:60221 87.109.137.202:57689 SYN_RECV
tcp 0 0 192.168.x.x:60221 69.133.56.84:55229 SYN_RECV
tcp 0 0 192.168.x.x:60221 112.198.79.131:29339 SYN_RECV
tcp 0 0 192.168.x.x:60221 86.29.126.40:2406 SYN_RECV
tcp 0 0 192.168.x.x:60221 74.220.191.225:57234 SYN_RECV
tcp 0 0 192.168.x.x:60221 119.71.210.130:53843 SYN_RECV
tcp 0 0 192.168.x.x:60221 213.236.200.7:54683 SYN_RECV
tcp 0 0 192.168.x.x:60221 178.74.56.73:64180 SYN_RECV
tcp 0 0 192.168.x.x:60221 41.78.78.1:12708 SYN_RECV
tcp 0 0 192.168.x.x:60221 204.16.202.130:46494 SYN_RECV
tcp 0 0 192.168.x.x:60221 175.156.128.212:59143 SYN_RECV
tcp 0 0 192.168.x.x:60221 99.139.67.191:60438 SYN_RECV
tcp 0 0 192.168.x.x:60221 71.3.158.29:17529 SYN_RECV
tcp 0 0 192.168.x.x:60221 14.201.68.122:63472 SYN_RECV
tcp 0 0 192.168.x.x:60221 75.159.87.184:61521 SYN_RECV
tcp 0 0 192.168.x.x:60221 94.255.135.88:32207 SYN_RECV
tcp 0 0 192.168.x.x:60221 85.131.129.175:50737 SYN_RECV
tcp 0 0 192.168.x.x:60221 190.19.100.221:53083 SYN_RECV
tcp 0 0 192.168.x.x:60221 46.46.250.211:3645 SYN_RECV
tcp 0 0 192.168.x.x:60221 65.29.245.102:57238 SYN_RECV
tcp 0 0 192.168.x.x:60221 92.32.244.205:64801 SYN_RECV
tcp 0 0 192.168.x.x:60221 92.104.198.32:65018 SYN_RECV
tcp 0 0 192.168.x.x:60221 189.31.251.206:5180 SYN_RECV
tcp 0 0 192.168.x.x:60221 89.2.107.85:49504 SYN_RECV
tcp 0 0 192.168.x.x:60221 86.145.38.250:62699 SYN_RECV
tcp 0 0 192.168.x.x:60221 99.116.232.132:58543 SYN_RECV
tcp 0 0 192.168.x.x:60221 85.24.233.121:3915 SYN_RECV
tcp 0 0 192.168.x.x:60221 83.92.90.26:51712 SYN_RECV
tcp 0 0 192.168.x.x:60221 50.99.112.10:55982 SYN_RECV
tcp 0 0 192.168.x.x:60221 70.119.136.81:51176 SYN_RECV
tcp 0 0 192.168.x.x:60221 184.178.240.81:55910 SYN_RECV
tcp 0 0 192.168.x.x:60221 90.216.20.197:7148 SYN_RECV
tcp 0 0 192.168.x.x:60221 189.4.123.166:55132 SYN_RECV
tcp 0 0 192.168.x.x:60221 78.87.85.81:63381 SYN_RECV
tcp 0 0 192.168.x.x:60221 89.101.22.86:51744 SYN_RECV
tcp 0 0 192.168.x.x:60221 186.215.23.232:54289 SYN_RECV
tcp 0 0 192.168.x.x:60221 81.231.77.190:64967 SYN_RECV
tcp 0 0 192.168.x.x:60221 114.108.194.12:63249 SYN_RECV
tcp 0 0 192.168.x.x:60221 85.228.153.44:3476 SYN_RECV
tcp 0 0 192.168.x.x:60221 81.226.122.148:55467 SYN_RECV
tcp 0 0 192.168.x.x:60221 84.228.66.49:60599 SYN_RECV
tcp 0 0 192.168.x.x:60221 97.77.172.214:55988 SYN_RECV
tcp 0 0 192.168.x.x:60221 184.38.6.52:3762 SYN_RECV
tcp 0 0 192.168.x.x:60221 92.118.14.18:3479 SYN_RECV
tcp 0 0 192.168.x.x:60221 66.225.111.50:48375 SYN_RECV
tcp 0 0 192.168.x.x:60221 77.170.211.68:27161 SYN_RECV
tcp 69 0 192.168.x.x:60221 182.209.232.22:57396 CLOSE_WAIT
tcp 286 0 192.168.x.x:60221 121.7.139.156:39462 CLOSE_WAIT
tcp 396 0 192.168.x.x:60221 89.112.15.178:51408 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 182.209.232.22:57729 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 207.195.68.76:58885 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 121.173.214.232:61210 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 76.0.16.131:12497 LAST_ACK
tcp 219 0 192.168.x.x:60221 98.215.65.231:39097 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 109.186.67.148:63708 FIN_WAIT1
tcp 69 0 192.168.x.x:60221 180.24.190.91:65215 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 187.41.113.64:20337 LAST_ACK
tcp 0 1 192.168.x.x:60221 84.105.179.112:58633 LAST_ACK
tcp 351 0 192.168.x.x:60221 84.105.179.112:58649 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 14.45.5.8:3365 LAST_ACK
tcp 0 0 192.168.x.x:60221 213.150.55.92:40731 ESTABLISHED
tcp 0 1 192.168.x.x:60221 83.154.101.172:50982 LAST_ACK
tcp 0 0 192.168.x.x:60221 69.133.62.181:54655 ESTABLISHED
tcp 421 0 192.168.x.x:60221 24.85.241.58:55194 CLOSE_WAIT
tcp 18432 0 192.168.x.x:60221 69.123.55.246:58231 ESTABLISHED
tcp 69 0 192.168.x.x:60221 77.68.143.171:60541 CLOSE_WAIT
tcp 68 0 192.168.x.x:60221 64.136.208.115:61963 ESTABLISHED
tcp 0 1 192.168.x.x:60221 94.145.209.65:29856 LAST_ACK
tcp 0 1 192.168.x.x:60221 83.212.32.221:3490 LAST_ACK
tcp 0 0 192.168.x.x:60221 173.237.100.189:52557 ESTABLISHED
tcp 69 0 192.168.x.x:60221 90.224.230.132:62759 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 91.74.118.96:52921 LAST_ACK
tcp 69 0 192.168.x.x:60221 98.210.232.180:61846 CLOSE_WAIT
tcp 561 0 192.168.x.x:60221 109.89.33.60:48253 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 84.215.57.35:4721 CLOSE_WAIT
tcp 0 0 192.168.x.x:3123 193.90.49.177:60001 ESTABLISHED
tcp 0 1 192.168.x.x:60221 68.41.119.34:64746 LAST_ACK
tcp 0 1 192.168.x.x:60221 213.89.204.64:58902 LAST_ACK
tcp 69 0 192.168.x.x:60221 92.20.167.45:51859 CLOSE_WAIT
tcp 268 0 192.168.x.x:60221 157.158.137.18:61320 ESTABLISHED
tcp 68 0 192.168.x.x:60221 27.32.21.214:51783 ESTABLISHED
tcp 69 0 192.168.x.x:60221 115.66.70.124:54136 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 109.60.5.165:63355 LAST_ACK
tcp 348 0 192.168.x.x:60221 173.174.173.218:52582 CLOSE_WAIT
tcp 318 0 192.168.x.x:60221 94.23.147.4:47533 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 192.167.23.210:21183 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 90.224.230.132:64813 LAST_ACK
tcp 69 0 192.168.x.x:60221 186.14.19.44:18049 CLOSE_WAIT
tcp 126 0 192.168.x.x:60221 91.193.208.106:60229 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 78.101.135.6:52652 CLOSE_WAIT
tcp 337 0 192.168.x.x:60221 24.220.186.207:56926 CLOSE_WAIT
tcp 5840 0 192.168.x.x:60221 24.231.89.242:1760 ESTABLISHED
tcp 0 1 192.168.x.x:60221 217.211.27.138:28355 LAST_ACK
tcp 0 1 192.168.x.x:60221 81.104.3.214:50521 LAST_ACK
tcp 268 0 192.168.x.x:60221 81.204.60.131:56882 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 85.71.213.239:14709 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 84.107.74.143:52103 CLOSE_WAIT
tcp 0 0 192.168.x.x:60221 195.1.152.6:58408 ESTABLISHED
tcp 0 1 192.168.x.x:60221 79.138.34.76:55691 LAST_ACK
tcp 335 0 192.168.x.x:60221 192.167.23.210:20019 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 178.159.51.141:58231 CLOSE_WAIT
tcp 0 0 192.168.x.x:60221 24.132.217.202:47174 ESTABLISHED
tcp 4839 0 192.168.x.x:60221 201.51.207.20:51363 CLOSE_WAIT
tcp 68 0 192.168.x.x:60221 85.17.74.154:45957 ESTABLISHED
tcp 0 1 192.168.x.x:60221 115.66.251.252:46849 LAST_ACK
tcp 69 0 192.168.x.x:60221 114.77.211.113:53693 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 98.198.199.12:56935 CLOSE_WAIT
tcp 1 0 192.168.x.x:60221 91.121.60.42:41642 CLOSE_WAIT
tcp 139 0 192.168.x.x:60221 84.202.67.49:41253 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 114.231.110.17:1867 FIN_WAIT1
tcp 69 0 192.168.x.x:60221 95.211.10.25:64770 CLOSE_WAIT
tcp 129 0 192.168.x.x:1786 49.48.60.118:60212 ESTABLISHED
tcp 69 0 192.168.x.x:60221 173.215.203.186:51741 CLOSE_WAIT
tcp 217 0 192.168.x.x:60221 69.122.27.151:56886 ESTABLISHED
tcp 0 1 192.168.x.x:60221 81.204.60.131:56167 LAST_ACK
tcp 69 0 192.168.x.x:60221 60.53.234.98:55871 CLOSE_WAIT
tcp 0 0 192.168.x.x:60221 88.117.36.62:61584 ESTABLISHED
tcp 69 0 192.168.x.x:60221 115.187.38.64:55563 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 94.210.54.198:52684 CLOSE_WAIT
tcp 337 0 192.168.x.x:60221 36.37.234.16:7343 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 24.87.130.67:64192 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 115.187.38.64:55447 LAST_ACK
tcp 69 0 192.168.x.x:60221 115.187.38.64:55481 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 91.74.118.96:53934 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 95.146.169.133:53259 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 87.194.85.176:62547 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 59.93.161.158:62614 LAST_ACK
tcp 69 0 192.168.x.x:60221 124.170.112.251:21858 CLOSE_WAIT
tcp 68 0 192.168.x.x:60221 110.159.160.219:57869 ESTABLISHED
tcp 316 0 192.168.x.x:60221 213.114.80.218:33847 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 110.8.131.25:5342 LAST_ACK
tcp 0 1 192.168.x.x:60221 24.2.83.59:47338 LAST_ACK
tcp 0 0 192.168.x.x:60221 173.63.25.168:64509 ESTABLISHED
tcp 0 1 192.168.x.x:60221 77.110.28.82:53186 LAST_ACK
tcp 0 1 192.168.x.x:60221 94.209.79.14:61530 LAST_ACK
tcp 231 0 192.168.x.x:60221 77.110.28.82:53239 CLOSE_WAIT
tcp 0 0 192.168.x.x:60221 80.100.44.223:59561 ESTABLISHED
tcp 68 0 192.168.x.x:60221 166.194.36.217:61589 ESTABLISHED
tcp 69 0 192.168.x.x:60221 93.35.226.227:54182 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 173.206.236.83:49234 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 182.55.137.182:51164 LAST_ACK
tcp 224 0 192.168.x.x:60221 187.18.144.151:63119 CLOSE_WAIT
tcp 417 0 192.168.x.x:60221 92.104.198.32:64551 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 98.225.6.141:52086 LAST_ACK
tcp 352 0 192.168.x.x:60221 96.50.18.237:52718 CLOSE_WAIT
tcp 310 0 192.168.x.x:60221 80.5.34.211:64443 CLOSE_WAIT
tcp 333 0 192.168.x.x:60221 96.50.18.237:52001 CLOSE_WAIT
tcp 97 0 192.168.x.x:60221 188.49.116.6:62104 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 69.251.56.239:52391 LAST_ACK
tcp 68 0 192.168.x.x:60221 219.77.99.131:65497 ESTABLISHED
tcp 69 0 192.168.x.x:60221 121.54.64.39:50467 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 124.184.186.53:62585 CLOSE_WAIT
tcp 0 18000 192.168.x.x:60221 66.29.191.9:10718 ESTABLISHED
tcp 0 1 192.168.x.x:60221 96.54.102.189:63565 LAST_ACK
tcp 0 1 192.168.x.x:60221 217.159.145.239:57320 LAST_ACK
tcp 148 0 192.168.x.x:60221 176.58.192.41:49686 CLOSE_WAIT
tcp 0 217 192.168.x.x:60221 219.77.99.131:64792 ESTABLISHED
tcp 69 0 192.168.x.x:60221 220.255.135.39:60583 CLOSE_WAIT
tcp 351 0 192.168.x.x:60221 62.57.129.107:49528 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 175.124.239.109:64488 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 31.171.63.83:3520 LAST_ACK
tcp 0 1 192.168.x.x:60221 79.114.40.133:53500 LAST_ACK
tcp 69 0 192.168.x.x:60221 124.182.36.164:60204 CLOSE_WAIT
tcp 207 0 192.168.x.x:60221 90.227.252.198:33000 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 85.96.166.168:55233 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 82.5.128.2:54206 LAST_ACK
tcp 68 0 192.168.x.x:60221 79.116.104.28:55060 ESTABLISHED
tcp 0 1 192.168.x.x:60221 83.53.4.164:57843 LAST_ACK
tcp 69 0 192.168.x.x:60221 89.100.64.42:65534 CLOSE_WAIT
tcp 99 0 192.168.x.x:60221 85.131.129.174:54678 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 118.167.28.60:3854 CLOSE_WAIT
tcp 298 0 192.168.x.x:60221 180.131.228.29:53870 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 60.230.214.190:52689 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 82.114.220.156:64699 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 31.151.235.152:58126 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 94.201.183.107:57508 LAST_ACK
tcp 0 1 192.168.x.x:60221 188.93.189.221:56415 LAST_ACK
tcp 300 0 192.168.x.x:60221 121.54.2.251:52718 ESTABLISHED
tcp 0 1 192.168.x.x:60221 182.55.137.182:51356 LAST_ACK
tcp 69 0 192.168.x.x:60221 87.69.83.2:49515 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 86.104.49.225:53187 CLOSE_WAIT
tcp 68 0 192.168.x.x:60221 85.186.2.250:60704 ESTABLISHED
tcp 0 1 192.168.x.x:60221 83.249.163.204:54820 FIN_WAIT1
tcp 0 0 192.168.x.x:60221 99.27.241.230:54934 ESTABLISHED
tcp 203 0 192.168.x.x:60221 94.212.61.216:59627 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 92.72.91.151:53500 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 59.167.171.235:59668 LAST_ACK
tcp 69 0 192.168.x.x:60221 121.96.148.197:54158 CLOSE_WAIT
tcp 0 0 192.168.x.x:60221 83.119.137.40:62417 ESTABLISHED
tcp 0 0 192.168.x.x:60221 180.191.228.172:29098 ESTABLISHED
tcp 0 1 192.168.x.x:60221 213.65.145.228:56229 LAST_ACK
tcp 0 1 192.168.x.x:60221 223.29.198.241:39255 LAST_ACK
tcp 0 1 192.168.x.x:60221 95.211.139.146:55934 LAST_ACK
tcp 191 0 192.168.x.x:60221 85.75.220.238:57252 ESTABLISHED
tcp 0 1 192.168.x.x:60221 79.119.185.221:23875 LAST_ACK
tcp 0 1 192.168.x.x:60221 85.131.129.177:35841 LAST_ACK
tcp 212 0 192.168.x.x:60221 192.167.23.210:43924 CLOSE_WAIT
tcp 195 0 192.168.x.x:60221 88.162.203.3:59999 CLOSE_WAIT
tcp 247 0 192.168.x.x:60221 110.159.191.244:54476 CLOSE_WAIT
tcp 216 0 192.168.x.x:60221 178.36.125.120:61930 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 71.50.4.201:10491 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 109.8.209.238:44461 LAST_ACK
tcp 0 0 192.168.x.x:60221 71.95.52.254:62512 ESTABLISHED
tcp 297 0 192.168.x.x:60221 175.156.128.212:58544 CLOSE_WAIT
tcp 0 209 192.168.x.x:60221 90.230.55.112:56527 ESTABLISHED
tcp 69 0 192.168.x.x:60221 79.81.34.197:60355 CLOSE_WAIT
tcp 241 0 192.168.x.x:60221 220.245.19.218:60475 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 71.202.242.44:59797 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 178.85.255.57:36548 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 64.34.147.107:58424 CLOSE_WAIT
tcp 270 0 192.168.x.x:60221 95.36.35.2:52591 CLOSE_WAIT
tcp 173 0 192.168.x.x:60221 24.127.181.87:51108 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 77.126.208.13:63417 LAST_ACK
tcp 0 1 192.168.x.x:60221 69.165.162.190:54924 LAST_ACK
tcp 0 1 192.168.x.x:60221 98.212.244.140:53578 LAST_ACK
tcp 69 0 192.168.x.x:60221 71.54.233.130:19227 CLOSE_WAIT
tcp 293 0 192.168.x.x:60221 118.208.75.139:65078 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 69.112.54.88:36912 CLOSE_WAIT
tcp 1 0 192.168.x.x:60221 83.227.172.21:3623 CLOSE_WAIT
tcp 280 0 192.168.x.x:60221 90.218.149.42:51104 CLOSE_WAIT
tcp 68 0 192.168.x.x:60221 85.101.153.133:64409 ESTABLISHED
tcp 69 0 192.168.x.x:60221 84.0.157.249:56124 CLOSE_WAIT
tcp 116 0 192.168.x.x:60221 70.50.7.77:57628 CLOSE_WAIT
tcp 69 0 192.168.x.x:60221 84.90.249.141:59027 CLOSE_WAIT
tcp 231 0 192.168.x.x:60221 178.178.10.176:56216 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 90.218.149.42:50207 LAST_ACK
tcp 69 0 192.168.x.x:60221 121.3.198.252:44247 CLOSE_WAIT
tcp 0 1 192.168.x.x:60221 71.179.177.87:54717 LAST_ACK
tcp 0 1 192.168.x.x:60221 79.161.14.44:61579 LAST_ACK
udp 1048332 0 0.0.0.0:60221 0.0.0.0:*
But I can also with " netstat -an | grep x.x | grep EST | grep -v .x.y| grep -v :60221" see a lot of other ports that are in use by the NAS. Some I can understand why they are there (SSH, CIFS/SMB, DLNA, etc ... ) but some I don't know what they are there for. Maybe they are used by Transmission, or?
tcp 0 0 192.168.x.x:1535 82.238.118.184:51413 ESTABLISHED
tcp 0 0 192.168.x.x:1957 175.136.7.46:42176 ESTABLISHED
tcp 0 0 192.168.x.x:4248 94.75.78.110:51413 ESTABLISHED
tcp 1439 0 192.168.x.x:4933 68.47.253.116:18480 ESTABLISHED
tcp 0 0 192.168.x.x:2845 109.203.53.65:21766 ESTABLISHED
tcp 0 0 192.168.x.x:4395 93.82.143.2:40041 ESTABLISHED
tcp 15653 0 192.168.x.x:1721 90.224.93.54:44801 ESTABLISHED
tcp 0 0 192.168.x.x:1082 199.59.241.239:80 ESTABLISHED
tcp 0 0 192.168.x.x:1267 70.232.56.185:55473 ESTABLISHED
tcp 0 0 192.168.x.x:3821 68.63.135.129:14607 ESTABLISHED
tcp 5 0 192.168.x.x:2131 24.205.85.4:56698 ESTABLISHED
tcp 0 0 192.168.x.x:1186 86.16.189.181:43309 ESTABLISHED
tcp 1024 0 192.168.x.x:2312 85.247.197.146:32422 ESTABLISHED
tcp 0 0 192.168.x.x:1429 124.178.34.125:47199 ESTABLISHED
tcp 0 0 192.168.x.x:1132 220.4.91.95:21871 ESTABLISHED
tcp 14983 0 192.168.x.x:2410 109.108.198.125:56720 ESTABLISHED
tcp 16060 0 192.168.x.x:4599 145.97.217.230:58967 ESTABLISHED
tcp 0 13880 192.168.x.x:2331 109.58.20.31:54555 ESTABLISHED
tcp 6000 0 192.168.x.x:2371 85.64.11.98:51414 ESTABLISHED
tcp 13032 0 192.168.x.x:2343 93.152.143.137:6954 ESTABLISHED
tcp 0 0 192.168.x.x:2107 78.101.10.247:62205 ESTABLISHED
tcp 0 0 192.168.x.x:3427 79.103.253.120:50139 ESTABLISHED
tcp 0 0 192.168.x.x:4277 85.74.42.181:16042 ESTABLISHED
tcp 32794 0 192.168.x.x:1357 176.31.108.31:23880 ESTABLISHED
tcp 0 0 192.168.x.x:3309 71.237.114.248:36654 ESTABLISHED
tcp 0 344 192.168.x.x:4086 95.211.88.54:80 ESTABLISHED
tcp 6157 0 192.168.x.x:1440 188.165.198.56:16301 ESTABLISHED
tcp 0 0 192.168.x.x:4097 85.247.219.171:51413 ESTABLISHED
tcp 0 0 192.168.x.x:3802 66.8.164.137:3579 ESTABLISHED
tcp 0 0 192.168.x.x:2998 129.241.124.236:28476 ESTABLISHED
tcp 229558 0 192.168.x.x:2948 219.222.21.212:11916 ESTABLISHED
tcp 0 0 192.168.x.x:2692 88.235.103.134:11114 ESTABLISHED
tcp 0 0 192.168.x.x:2324 113.142.11.113:2262 ESTABLISHED
tcp 0 0 192.168.x.x:3023 80.108.91.227:39590 ESTABLISHED
tcp 0 0 192.168.x.x:1648 94.8.10.220:11418 ESTABLISHED
tcp 0 0 192.168.x.x:3219 178.76.158.61:39873 ESTABLISHED
tcp 0 0 192.168.x.x:4570 2.90.197.96:48090 ESTABLISHED
tcp 186 0 192.168.x.x:1306 68.81.165.49:33341 ESTABLISHED
tcp 0 14520 192.168.x.x:4533 114.91.147.194:55390 ESTABLISHED
tcp 0 0 192.168.x.x:3890 64.180.149.144:53649 ESTABLISHED
tcp 0 0 192.168.x.x:2459 115.64.89.225:23762 ESTABLISHED
tcp 51 0 192.168.x.x:4070 142.177.75.192:50320 ESTABLISHED
tcp 0 0 192.168.x.x:4973 80.212.153.56:13862 ESTABLISHED
Another thing that might be worth mentioning is what I see when I look at the connections using "netstat -an | [a lot of greps to includes and excludes to filter what I want to see] | wc -l". What I exclude is basically all the local connections and to the location where I am now and what I include is basically everything. So what I then end up with is:
TOTAL: 398
ESTABLISHED: 82
SYN_RECV: 89
CLOSE_WAIT: 133
LAST_ACK: 75
If I do the same but add to the filter at the end to filter on Transmission port as well I see for the Transmission port:
TOTAL : 270
ESTABLISHED: 19
SYN_RECV: 86
CLOSE_WAIT: 98
LAST_ACK: 64
The time between these values are the time it takes to execute the script that I built for this, so it is more or less at the same seconds that all these values are for.
Anywho, is this normal?
Message 5 of 13
JarnoG
Guide
I think the connections to port 60221 (2nd code block) are the peers connected to you and the other ones (3rd code block) are either to other services (CIFS,HTTP,etc) or are the connections you made to other people to download from.
Your router log shows that it is forwarding the right port to the right IP, so that shouldn't be a problem. I've got no idea why it doesn't delete the unused upnp ports.
It also shows that you're connected to plenty peers, so that shouldn't be a problem either, which means I'm kinda out of options...
Message 6 of 13
MrAsker
Tutor
The more I think about the more I think this is the problem.
I wish I could get a better logging from Transmission so that I can understand what it is doing and more importantly, what it is not doing. I've search but I can't seem to find a way to turn on better logging. Do you know of any way to do it?
Message 7 of 13
JarnoG
Guide
I'm assuming Transmission is keeping some kind of log somewhere, but my knowledge (or lack thereof) of Linux tells me not to enable SSH so I can't go look for it.
What you can try is disabling upnp on your router and enabling a DMZ for your NAS. That way all ports are forwarded to your NAS. If that would give you better downloading, then there is most likely some port-forwarding problem (or another problem in your router).
Message 8 of 13
MrAsker
Tutor
I think Transmission is supposed to save everything in /var/log/daemon.log but I'm not sure ...
I've disabled uPnP in Transmission and it seems to work slightly better but still not good.
I'm reluctant to putting the NAS in DMZ since it becomes to Wide-open then. But I'll test it all the same when I get back home. Not the kind of thing you want to test when you're on vacation. 🙂
Even of this does not help I still want to thank your for your efforts. I really appreciate it.
Message 9 of 13
MrAsker
Tutor
I 've started to get better speed, 200kb/s plus which is better not close to my max of 1-1.5Mbyte/s which I should be able to get.
So, I checked the daemon.log for more info and since last time I see a lot of "Could not connect to tracker (announcer.c:990)". Afaik this is a problem if the port(s) used are not forwarded in the FW to the NAS (where I run transmission) but I've double checked and "random ports" I've designated in the settings.json file 60000-60999 and the default ports 6880-6999+51413 are forwarded to the NAS so I'm pretty sure this is not the problem. This is with uPnP disabled so I will try again with it enabled.
I find it strange that I do get better DL but still a lot of errors in the logs.
tbc
Message 10 of 13
MrAsker
Tutor
OK, now I'm back at the terrible speeds that I had before and I have no idea why.
I've tried with uPNP enables and disables in Transmission and it does not make any difference.
I've tried limiting the Active DL:s to <5, <10, <20, <30, etc, and it doesn't seem to make any difference.
I've tried only having the torrents with 1000+ seeds Active, and it doesn't seem to make any difference.
I've tried having only smaller (<200Mb) and only larger (4Gb<) torrents Active, but it does not make any difference.
I've naturally stop:ed and started Transmission a number of times to see if it's a port issue, but it does not seem to be so.
In the daemon.log I can still see a lot of the errors above but I can not make heads or tails of if it's worse or less then before. It's simply to many of them.
Anybody have any help?
Message 11 of 13
MrAsker
Tutor
For those who see this I have now found a useful link: http://www.demonoid.me/faq.php#dut_25
I gave me a few ideas:
1. Find a good balance of the number of Torrents in Transmission. Still working on that but it seems like Transmission and the ReadyNAS NV+ is at best below 20-30 concurrent Torrents, including the ones you are seeding.
2. Have the ReadeyNAS drop connections faster. This is a bit tricky so does anybody have any suggestions?
Message 12 of 13
MrAsker
Tutor
I think the problem is found. The main problem is that I had some 400+ torrent Active in Transmission, that is to many. Pausing some 300+ torrent made it better, but not good.
The other problem I think was that I had a UL limit set to approx 80% of my DL, per recommendation to make things faster. I removed this limit and things started to DL at reasonable speed.
However I still was not having a lot of luck connection but when connection I get good DL so then i limited the number of active torrent based on the number of available seed and when I kept the number of active seeds to under approx 2000 seeders for all Active Torrent, things are faster again. Not as fast as expected but faster.
So I'm left to think that I have reached the limitation of the ReadyNAS NV+. Anybody got any input on that?
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 7176 views
  • 0 kudos
  • 2 in conversation
Announcements
