× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
problems with EnableRootSSH (ARM) on Raidator 5.3.3
pimeson
ReadyNAS DUO V2
1. Downloaded http://www.readynas.com/download/addons/arm/5.3/EnableRootSSH_1.0-arm.bin
2. Tried to install, said it was partially completed, would you like to restart? yes
3. I get an alert saying "http://www.readynas.com/download/addons/arm/5.3/EnableRootSSH_1.0-arm.bin"
4. Tried 'ssh root@192.168.0.188', connection refused.
restarted, power cycled, redownloaded addon. it makes no different.
other addons i have: readynas remote iphone, and the photo addon
please help.
Message 1 of 5
mdgm-ntgr
NETGEAR Employee Retired
Re: problems with EnableRootSSH (ARM) on Raidator 5.3.3
Can you download your logs (On the Dashboard, click Configure, then select Health > Logs > Download Logs) and extract the contents of the zip file. In boot_info.log what does the ssh line look like?
Is it
ssh: 0
Or do you see a large number instead of the zero?
Message 2 of 5
pimeson
The boot_info.log file is empty (!). Tried to redownload, and still empty.
The error I get in step 3 above (miswritten due to sleepiness) is "SSH access failed to be enabled due to an unknown error.". This is also in the system.old log file.
Message 3 of 5
mdgm-ntgr
Would suggest you open a tech support case (http://www.readynas.com/support). Edit the thread title (i.e. subject of first post in the thread) to include your case number.
Message 4 of 5
amac27
you shoule be able to get something like this on the logs
Fri Mar 9 20:29:00 PST 2012
Successfully enabled root SSH access. The root password is now the same as your admin password.
Can you try to download the rootSSH addon on another computer? I think it might be just corrupted.
If not please open a ticket with support.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3724 views
  • 0 kudos
  • 3 in conversation
Announcements
