Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ruTorrent 3.3 + rTorrent by WhoCares
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-21
01:17 PM
2012-03-21
01:17 PM
Can someone explain, how to configure download directories and other settings?
It always defaults back to factory settings if you reboot ReadyNAS or restart addon.
It`s a known behaviour of ruTorrent GUI: http://forums.rutorrent.org/index.php?topic=570.0
Also I couldnt find corresponding rtorrent.rc file anywhere in my unit, so where are the default settings actually kept? :roll:
Basically my problem is, that it always defaults download directory to /c/media , which I have deleted because I use different share names... (Downloads for example) :?
Message 1 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-24
08:58 AM
2012-03-24
08:58 AM
Re: ruTorrent 3.3 + rTorrent by WhoCares
are u attempting to make the settings permanent ?.... im kind of confused as to what your trying to do ...i assume u found the options to change the directory on rutorrent it's self ...
the setting files r in a hidden folder on ur nas ( dont recommend messing with it to much or at all lol but).. "\c\.rutorrent" a hidden directory is the root of the app..
if u have any success with making the settings carry over please post ... id love to play with it also
Message 2 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-24
12:31 PM
2012-03-24
12:31 PM
Yes I want to make some of the settings permanent...
Unfortunately I cannot find any trace of rtorrent config file... :?
RuTorrent is only WebGUI frontend, my question is about rtorrent config...
EDIT: OK, it wasnt the addon issue at all.
Basically I had a strange problem, where Downloads share wasnt writable to that addon.
Changed share owner to nobody, and all began to work as expected.
Still would like to know where are rtorrent default settings are kept... 😛
Message 3 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-25
08:48 AM
2012-03-25
08:48 AM
Etz wrote: Yes I want to make some of the settings permanent...
i miss understood .. i get u now ,Ran into a similar issue my self and same solution lol .
as far as the rtorrent config ... im not exactly sure were it is either, did some searching my self with no luck . i assume if u really wanted to find it u could ssh into ur box and find the dir.... but u really dont interface with rtorrent at all with rutorrent running ... i assume anything ur trying to set in the rotrrent.rc u could have set by rutorrent (editing php files) for u as the webgui will load up with it anyway ... only limitation would be that rutorrent would have to be up and going .
then again it would be alot easier to just edit the file to ur liking .... gives u the ability to cause more harm then good im guessing tho lol
this app kicks arse ... cant live with out it
Message 4 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-11
11:02 AM
2012-06-11
11:02 AM
I have the same issue. When i restart my nas all the settings are from scratch=( all the torrents that where seeding is missing and so on. How do i cange the settings permanent ?
Message 5 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-19
07:24 PM
2012-06-19
07:24 PM
I have some answers, but not solutions (yet).
It appears they are starting up the rtorrent deamon with the -n option:
That option does this according to rtorrent help: "Don't try to load ~/.rtorrent.rc on startup"
I think normally that .rtorrent.rc is where these kinds of settings would be. I kind of agree that its lame that ruTorrent is not able to push settings changes into the rc file, or really I guess rtorrent is probably to blame for not having a way to push changes of the session back into the rc file. so the GUI is mostly useless for a lot of the settings other than temporary basis, it would appear.
I'm not sure at all where to put the settings you want if not going to load the rc file or whether there is a systemside default rc file that can be read, I'm looking into it.
As for as /c/media always being the default location, this is also hard coded into the startup script with the -d option (see above), so edit that script to change the default download location to something else you want or remove it altogether.
/usr/bin/rtorrent -n -d /c/media -o scgi_local=/tmp/rutorrent.sock -o port_range=${PORTRANGE}
Message 6 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-20
01:31 PM
2012-06-20
01:31 PM
Well first thanks a lot to WhoCares for putting this addon together. I would not have tried rtorrent without it.
That being said, here are some tweaks I have done in order to make it really work as it should. Perhaps future addon release may incorporate some of these fixes, but in the meantime it may help some of you that are having problems with it.
First I will list high level summary of what was tweaked and then some details. Lastly I will list some future things I want to look into for later. Brace yourself this is a lot to read, but if you're serious about using rtorrent I think you'll find this useful. I have discovered rtorrent to be extremely powerful. I'm removing both utorrent and transmission (if I can figure out how to remove transmission) from my machine.
Summary
Summary
- rtorrent.rc was excluded from the addon. Include it so that various configuration options can be used, which are not possible without it.
- session was not configured. Configured for use of session. A configured session dir allows you to stop and restart rtorrent and have it remember all the torrents you had loaded.
- Changed some things in the frontview startup scripts
- Configured file permission umask of downloaded files so that I can access from share without being admin user.
- Set up watch folders, more to do here, this is very powerful feature.
- configured encryption
- .rtorrent.rc is per user, there is no way to override this with rtorrent. Since this addon is configured to run rtorrent as admin, simply create the following file:
~admin/.rtorrent.rc
You can search the web and find tons of examples for what to put into this file. It turns out that rtorrent is quite more powerful then I realized, with the ability to create event driven scripts. I'm still learning. Due to the size of it, I put my version of the file at the end of this post. - In order to enable the .rtorrent.rc file, the startup script has to be modified, to exclude the -n option. That script is found in:
/etc/frontview/addons/bin/RUTORRENT/RUTORRENT_service
- Once you have rtorrent picking up the rc file for config, you can move several other configuration items into there instead of from the command line at startup. The startup script has the download dir hardoded to /c/media, for example. It also has the port range specified here, though its configurable through frontview. I moved everything into the rc file, my RUTORRENT_service file now looks like this:
#!/bin/bash
Note - I also added the line to remove the sock file since I found that sometimes during testing this file got left hanging around and made it impossible to start rtorrent again. Maybe there is a better approach for that.
. /etc/default/services
. /etc/frontview/addons/ui/RUTORRENT/rutorrent.config
rm /tmp/rutorrent.sock
/usr/bin/rtorrent -o scgi_local=/tmp/rutorrent.sock - The following lines have to be added to ~admin/.rtorrent.rc in order to provide what was previously in the RUTORRENT_service cmd line. Use whatever dir and ports you want
# Default directory to save the downloaded torrents.
There are more things in that file to configure, see my example at the end. But those two entries accomplish what was previously done in the startup script.
directory = /c/raid/extra/partial
# Port range to use for listening.
port_range = 31667-31767 - The session concept is used to remember torrents you want loaded when you stop and start rtorrent. In order to use a session, create a directory somewhere for it and then add a line to .rtorrent.rc. Mine is this:
session = /c/.rtorrent/session
- Files downloaded with rtorrent are owned by admin.admin and not writeable by everyone. You can add the following line to .rtorrent.rc which will chmod all downloads to rwxrwxrwx:
# chmod rwx for everybody
system.umask.set = 0000 - I want encryption turned on always. This is configured with the following line in .rtorrent.rc
encryption = require
- rtorrent has powerful watch folder capability, I am just barely scratching the surface. You can add the following bit to .rtorrent.rc. What this accomplishes is that when you drop a .torrent file into the specified watch dir, it will detect it, add the torrent to the session and start downloading to the default download dir(specified above). However, when its complete, it will move the downloaded file to the final destination folder specified. So in this case, the torrents will download into the partial folder and when they are complete will move to downloads.
note, you can create more than one of these, I created two here so you can see, but you can create as many as you want. So that you drop your torrents into one of several different watch folders, which will determine where the final completed download will end up# Schedules to watch folders
schedule = watch_directory_1,11,20,"load_start=/c/raid/extra/rtorrent/watch/*.torrent,d.set_custom1=/c/raid/extra/downloads/"
schedule = watch_directory_2,12,20,"load_start=/c/raid/extra/rtorrent/watch/music/*.torrent,d.set_custom1=/c/raid/extra/music/"
# Move completed downloads to preset target
system.method.set_key = event.download.finished,move_complete,"d.set_directory=$d.get_custom1=;execute=mv,-u,$d.get_base_path=,$d.get_custom1="
Note also the system.method line added. This is an event driven script which does the moving of the final file. Google around to learn more about what rtorrent can do. - There are several other parameters in .rtorrent.rc which I uncommented and configured, see my complete file below.
- There are ways to also have the .torrent files moved when the torrent is started and/or when its completed. I want to trick that out also so that when I drop a torrent file into a watch dir, rtorrent will pick it up, add it to the session and then move the torrent file someplace else for safe keeping.
- There are some interesting options only available through patches and recompile of rtorrent. The most important one is ipfilter capability. Another one is the ability to preallocate downloads to their full size. A third one is related to the next item.
- By adding the "equal" patch and compiling rtorrent, its possible to reseed things using the watch folders. This is complicated to explain but basically the watch drop folder trick mentioned above only works for new torrents. if you want to reseed something you downloaded a long time ago, then if you try to drop it into watch its going to either re-download it, or if you move the downloaded content to the default download dir and try to drop the torrent file into the watch folder, it will see its finished, but will not move it back and continue seeding. There is a solution I found, https://wiki.archlinux.org/index.php/Rtorrent#Manage_completed_files but it requires the "equal" patch.
- I would like to see if I can run rtorrent as myself instead of admin, since I own all dirs where torrents might end up. I have found that if I create a folder through my NAS sharing as myself and then try to point rtorrent to download there, it will fail unless I also made sure to chmod that dir 777. If rtorrent was running as me it would never have this problem. However, when I tried to change the startup script to run as me, it didn't quite work with ruTorrent correctly. This is probably fixable, but I didn't have time to figure it out.
- rtorrent has the ability to auto create labels somehow, I need to figure that out.
- I would like to configure rtorrent to make sure it never consumes more than X amount of ram memory. I can see the parameter in the ruTorrent gui, but not sure where to configure that in .rtorrent.rc yet.
- I modified the startup.sh script to execute rtorrent with a nicelevel set to lower priority. This is entirely optional. The file in question is
/etc/frontview/addons/bin/RUTORRENT/start.sh
and I added --nicelevel 19 just before -x. So the final file looks like this:#!/bin/bash
# This should contain necessary code to start the service
screen -dmS "rtorrent" start-stop-daemon -S -m --pidfile /var/run/RUTORRENT.pid -c admin:admin -q --nicelevel 19 -x /etc/frontview/addons/bin/RUTORRENT/RUTORRENT_service
RTOR=`ps ax | grep rtorrent | grep -v SCREEN | grep -v grep | awk '{ print $1 }'`
if [ "$RTOR" != "" ]; then
echo $RTOR > /var/run/RUTORRENT.pid
fi - Here is my full .rtorrent.rc as of now
# This is an example resource file for rTorrent. Copy to
# ~/.rtorrent.rc and enable/modify the options as needed. Remember to
# uncomment the options you wish to enable.
# Maximum and minimum number of peers to connect to per torrent.
#min_peers = 40
#max_peers = 100
# Same as above but for seeding completed torrents (-1 = same as downloading)
#min_peers_seed = 10
#max_peers_seed = 50
# Maximum number of simultanious uploads per torrent.
#max_uploads = 15
# Global upload and download rate in KiB. "0" for unlimited.
#download_rate = 0
#upload_rate = 0
# Default session directory. Make sure you don't run multiple instance
# of rtorrent using the same session directory. Perhaps using a
# relative path?
# Watch a directory for new torrents, and stop those that have been
# deleted.
#schedule = watch_directory,5,5,load_start=./watch/*.torrent
#schedule = untied_directory,5,5,stop_untied=
# Close torrents when diskspace is low.
#schedule = low_diskspace,5,60,close_low_diskspace=100M
# The ip address reported to the tracker.
#ip = 127.0.0.1
# The ip address the listening socket and outgoing connections is
# bound to.
#bind = 127.0.0.1
#bind = rakshasa.no
# Start opening ports at a random position within the port range.
port_random = yes
# Check hash for finished torrents. Might be usefull until the bug is
# fixed that causes lack of diskspace not to be properly reported.
check_hash = yes
# Set whetever the client should try to connect to UDP trackers.
#use_udp_trackers = yes
# Alternative calls to bind and ip that should handle dynamic ip's.#schedule = ip_tick,0,1800,ip=rakshasa
#schedule = bind_tick,0,1800,bind=rakshasa
# Encryption options, set to none (default) or any combination of the following:
# allow_incoming, try_outgoing, require, require_RC4, enable_retry, prefer_plaintext
# The example value allows incoming encrypted connections, starts unencrypted
# outgoing connections but retries with encryption if they fail, preferring
# plaintext to RC4 encryption after the encrypted handshake
#encryption = require,enable_retry,prefer_plaintext
# Enable DHT support for trackerless torrents or when all trackers are down.
# May be set to "disable" (completely disable DHT), "off" (do not start DHT),
# "auto" (start and stop DHT as needed), or "on" (start DHT immediately).
# The default is "off". For DHT to work, a session directory must be defined.
dht = disable
# UDP port to use for DHT.
# dht_port = 6881
# Enable peer exchange (for torrents not marked private)
# peer_exchange = yes
# Do not modify the following parameters unless you know what you're doing.
# Hash read-ahead controls how many MB to request the kernel to read
# ahead. If the value is too low the disk may not be fully utilized,
# while if too high the kernel might not be able to keep the read
# pages in memory thus end up trashing.
#hash_read_ahead = 10
# Interval between attempts to check the hash, in milliseconds.
#hash_interval = 100
# Number of attempts to check the hash while using the mincore status,
# before forcing. Overworked systems might need lower values to get a
# decent hash checking rate.
#hash_max_tries = 10
Future
Notes
Message 7 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-21
10:24 AM
2012-06-21
10:24 AM
Nice little tut ... helping me alot , most of these tweaks r ones ive been trying to add my self with limited linux experience lol ( as u can imagine .... no luck) thanks for taking the time to post this .
i plan on attempting all this later this week lol ( need time to prepare for worse case lol) i had a few questions :
1) watch dir can be configed threw the autotools plugin (gui) do u have to modify it command line because of the new sessions setup , or can it just be configured once u have the session up and running threw autotools ?
2) encryption meaning data & connection encryption ? ( assuming so but i didnt think rtorrent had such a feature)
3) ive tryed to my hearts content .....but there is a new autotools update for rutorrent 3.4 which includes copy + re-link files features for the watch function . i cannot integrate it in rutorrent 3.3 it causes many errors im not equipt to fix lol . ive also tryed updating to rutorrent3.4 ( again not equipt) im hoping u have to knowledge needed to make this happen .... i would kiss u if u could 😄 ( promise im a good kisser) lol
again thanks for sharing the info and making it understandable for us linux noobs ive learned so much sense purchasing my readynas makes u wonder what else ur missing with all this new tech comming out :slap:
Message 8 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-21
11:02 AM
2012-06-21
11:02 AM
i did not try to use the autotools feature because so far it looked to have less control then what I can do directly with rtorrent. Maybe later I will come back to that.
bit torrent can allow or force encryption of the data stream so that your ISP can't detect you're doing torrents more or less. Some ISP's will throttle your bandwidth if they figure out you're torrenting. Utorrent and most torrent clients provide this. Google around.
Message 9 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-24
10:20 AM
2012-06-24
10:20 AM
rtorrent: Error in option file: ~/.rtorrent.rc:1: Invalid start of command name. <<< my first attempt at this mods lol .... 😞 rutorrent wont open addon error "service failed to load" i thouhgt i followed the directions pretty step by step ... ill give it another try when i get home from work
Message 10 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-24
10:47 AM
2012-06-24
10:47 AM
send a copy of your rctorrent.rc file
Message 11 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-24
08:09 PM
2012-06-24
08:09 PM
i copied urs to see if i could just get it up and running to start then i was going to edit it to my liking
whats strange is i got it to start ( with errors ) befor i edited "start.sh"
after editing that it stoped starting all together
reading the code i cant see y it wouldnt start ...
im going to try a fresh install and re-mod see if i have success
also ... im not to familiar with linux but the instructions to save the rc file to :
i assumed theres a home folder of some sort named ~admin/ not to sure but the instructions in the rc file recommended a save to:
i saved to both (lack of better decision) lol
ps: working on permission right now to rule that out ..... ive already edited the .rc file simply commented out the watch dr lines ill set that later with the addon and used real dir for the save folders
#min_peers = 40
#max_peers = 100
#max_uploads = 15
#download_rate = 0
#upload_rate = 0
# relative path?
# deleted.
#ip = 127.0.0.1
# bound to.
#bind = 127.0.0.1
#bind = rakshasa.no
port_random = yes
check_hash = yes
dht = disable
# dht_port = 6881
#!/bin/bash
fi
~admin/.rtorrent.rc
~/.rtorrent.rc
Message 12 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-24
08:14 PM
2012-06-24
08:14 PM
take out the nice level thing. I took it out of mine since then too. I don't think that's the problem though.
Could be file permissions. Make sure the related files are either owned by admin or with permissions for admin to read at runtime.
You also see that my rtorrent.rc file has a few directory names specified and you will need to edit those to actual dirs on your system where you intend to have default downloads and sessions saved. Then make sure those dirs exist.
Message 13 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-24
08:16 PM
2012-06-24
08:16 PM
in answer to your question about ~admin/.rtorrent.rc.
In unix you can refer to your own home dir with the '~'. So if you were going to save the file to the home dir of the current user, you'd say ~/.rtorrent.rc.
However in unix if you put a username after the tilde, then its referring to the home dir of that user.
Check /etc/passwd to see what the home dir is for your admin user. On my system it was /home/admin
Message 14 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-24
09:13 PM
2012-06-24
09:13 PM
My Procedure ( maybe i did something wrong u can spot) :
1) rtorrent.rc - Created and saved in /c/media (copy of urs)
2) Putty into my nas & copy the file into place:
also copied to ~/.rtorrent.rc
3) move to /etc/frontview/addons/bin/RUTORRENT/ to edit RUTORRENT_service (i copy it to /c/media/ edit and copy back )
*edit* file in windows (wordpad) and save as:
Copy back and run rutorrent
3) /c/.rtorrent/session created
rutorrent starts (with errors) :
"[24.06.2012 20:41:27] WebUI started.
[24.06.2012 20:41:27] Bad link to rTorrent. Check if it is really running. Check $scgi_port and $scgi_host settings in config.php and scgi_port in rTorrent configuration file."
but the service is running (looks like it) ....
So i op out of the start up script editing and try the command "rtorrent" ( to check if its up) i get the following error :
After deleting ~/.rtorrent.rc rtorrent starts with this error :
(21:08:32) Could not read resource file: ~/.rtorrent.rc
but rutorrent wont .... Somthings wrong .. i dono were to start lol
NAS-8B-81-B8:~# cp /c/media/rtorrent.rc ~admin/.rtorrent.rc
NAS-8B-81-B8:~# cd /etc/frontview/addons/bin/RUTORRENT/
NAS-8B-81-B8:/etc/frontview/addons/bin/RUTORRENT# ls
running.sh RUTORRENT_service start.sh stop.sh
NAS-8B-81-B8:/etc/frontview/addons/bin/RUTORRENT# cp RUTORRENT_service /c/media/
#!/bin/bash
NAS-8B-81-B8:/etc/frontview/addons/bin/RUTORRENT# cp /c/media/RUTORRENT_service RUTORRENT_service
NAS-8B-81-B8:/etc/frontview/addons/bin/RUTORRENT# rtorrent
Message 15 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-24
09:36 PM
2012-06-24
09:36 PM
Ok So file permissions 777 for both files .... same error
Message 16 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-24
09:47 PM
2012-06-24
09:47 PM
like I said, you have to edit the rtorrent.rc file and change some of the paths, you can't just use exactly what I used. Fix that. Check all the permissions
Message 17 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-24
10:02 PM
2012-06-24
10:02 PM
also, the way to start rtorrent is to use frontview to start and stop it.
Message 18 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-24
10:40 PM
2012-06-24
10:40 PM
Figured out the problem with the rc file .... Simply editing it in windows ruined the line returns and such i had to download an editer to edit the file correctly ...
.. i am usding front view to start and stop rtorrent ...
assumming the same thing happend with start up i also re-made RUTORRENT_service .. im up and running ( i think will have to test the session part is working)
WOOT WOOT --- told u i was a linux noob lol learned alot tho :
for other noobs out there = i used Komodo Edit 7.0 to edit the files and u have to change the file prefrences /line ending to UNIX (\n) to prevent issues if u edited the files in windows
thanks for trying to help me Dewdman i know its frustration when the user should know better 🙂 lol
Message 19 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-24
11:57 PM
2012-06-24
11:57 PM
I would reccomend for the future you use apt-get to install pico or vim so you can edit the files directly on unix. glad you got it working
Message 20 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-07-05
04:26 AM
2012-07-05
04:26 AM
I need a second pair of eyes to se what I have done wrong. I have earlier had rtorrent running on ubuntu
Symtoms:
- Torrents will not autoload from watched catalogs
- Torrents can not be started, they are stuck in PAUSED (Save as catalog is "./" acording to rutorrent)
- If I restart torrents are gone from rtorrent.
My .rtorrent.rc
Symtoms:
My .rtorrent.rc
#min_peers = 40
#max_peers = 100
#max_uploads = 15
#download_rate = 0
#upload_rate = 0
directory = /c/media/temp/download/
# relative path?
# deleted.
#ip = 127.0.0.1
# bound to.
#bind = 127.0.0.1
#bind = rakshasa.no
port_range = 6890-6990
port_random = yes
check_hash = yes
dht = disable
# dht_port = 6881
schedule = watch_directory_1,11,20,"load_start=/c/media/temp/default/*.torrent,d.set_custom1=/c/media/default/"
schedule = watch_directory_2,12,20,"load_start=/c/media/temp/music/*.torrent,d.set_custom1=/c/media/Music/"
schedule = watch_directory_3,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_4,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_5,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_6,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_7,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_8,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_9,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_10,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_11,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
schedule = watch_directory_12,12,20,"load_start=/c/media/temp/tv/xx/*.torrent,d.set_custom1=/c/media/Tv/xx/"
Message 21 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-07-05
08:54 AM
2012-07-05
08:54 AM
It sounds suspiciously to me that the session dir is not being used. Did you make sure to create the following directories before starting rtorrent:
Also, your watch configuration looks off, you have tv/xx repeated a bunch of times?
/c/.rtorrent/session/
Message 22 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-07-05
12:42 PM
2012-07-05
12:42 PM
I missed some permissions, this guide helped me: http://www.readynas.com/forum/viewtopic.php?f=36&t=62668&p=351300&hilit=configure+rtorrent#p351300
the xx is just censored information. Things seam to work now.
Next up is to find a RSS torrent downloader thats works with this setup.
Edit: I saw now the I missed a # at line 1. This was not related.
Message 23 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-07-05
01:16 PM
2012-07-05
01:16 PM
There are a few little quirks. For example I have found with the watch feature that if you remove the .torrent files after they've been collected that when it finishes it will get into some kind of stuck state for that torrent and won't start seeding it right. So I plop them in the watch dir, I wait until they have been swept up, then I remove them. There is supposedly a .rctorrent.rc script floating around that will move the torrent files after they are swept up, automatically, but I haven't had time to pursue it.
Message 24 of 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-07-08
10:40 PM
2012-07-08
10:40 PM
I have a problem. When I try to download a torrent (from torrent file) I get "Bad response from server: (500 [error,list]) Link to XMLRPC failed. May be, rTorrent is down?". Does anyone know what this means and how I can fix the problem?? After this error message, nothing works, I get thios message: "09.07.2012 15:42:24] Bad link to rTorrent. Check if it is really running. Check $scgi_port and $scgi_host settings in config.php and scgi_port in rTorrent configuration file." Restarting the service on the NVX just reproduces all the same problems..and as I have indicated elsewhere, I cant seem any torrent client to run, including Transmission (which used to work) and I even tried the uTorrent which doesnt work.
edit: fixed by reinstalling the ReadyNAs firmware.
Message 25 of 35
