timlinden's avatar
timlinden
Pro Pioneer Root Access, Used to Work Fine..
Hi Guys
I was able to sucessfully root and install CrashPlan. Back when we had to update JRE I was able to do that as well. Now I'm having issues again with it filling up disk space. I was able to telnet and clear the crashplan upgrade files again, but for the life of me I cannot get root access to work again. Any pointers?
Tim
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    It's possible that when the root volume was filled some config files were corrupted.
    I assume you've installed the glibc6 update add-on needed to continue to use Crashplan?
    • timlinden's avatar
      timlinden
      Yes that installed fine a few months ago and everything was working like a charm again.
        mdgm-ntgr
        Does your /etc/default/services look right?
