hiddenhills
Jul 31, 2014Aspirant
Slow ReadyNAS Duo access with iMac
Just purchased a new iMac and installed Word 2011 for MAC. The iMac was purchased to replace an aging Dell PC.
In setting up a default folder in Word that points back to the existing folder on my ReadyNAS drive, It takes minutes just to access the ReadyNAS folders and files. I am using the latest OS-X version on this iMac. No problems accessing the ReadyNAS folders with my old beat-up Dell. Thoughts? Thanks!
Paul
Paul
- Marto731AspirantPaul,
I presume the Dell PC had a Windows Operating system.
For your shares, can you check that AFP, ( Apple file Protocol ) is enabled.
Are you connected wired or wireless?
Regard, Marto - hiddenhillsAspirantThanks for the reply. Yes, the Dell was running Win XP.
Both AFP and SMB are enabled (green lights on) when I run ReadyNAS setup under RAIDar. I'm on a wired home network using a Netgear router.
Folders in ReadyNAS that do not contain many files are more quickly accessed. I have one folder with a large amount of Word and PDF documents and that folder takes minutes to see the files. This, with Word for MAC or under the MAC FileFinder.
Paul - hiddenhillsAspirantMaking some progress on NAS file access speed and I'm doing my part for "self help." Question: How do I make the following command line permanent?
sudo sysctl -w net.inet.tcp.delayed_ack=0
Paul - KimeraGuide
hiddenhills wrote: Question: How do I make the following command line permanent? sudo sysctl -w net.inet.tcp.delayed_ack=0
Editing/adding options directly on the /etc/sysctl.conf system control configuration file, I suppose.
As example on a ReadyNAS RN102 with ReadyOS 6.1.9 RC8 that file contains:vm.oom_dump_tasks = 1
vm.min_free_kbytes = 16384
vm.dirty_background_ratio = 10
vm.dirty_ratio = 20
net.ipv4.conf.all.arp_ignore = 1
dev.raid.speed_limit_min = 30000
kernel.core_pattern=/var/cores/core-%e
I've not a ReadyNAS Duo to check its content for that particular model (it may differs).
An alternative way would be to leave untouched the /etc/sysctl.conf file and create additional Kernel System Variables configuration files (one or more, it depends on your requirements) under the existing /etc/sysctl.d/ folder (important: those new files need to end with the .conf extension to be parsed), those ones will be parsed (by sysctl) and they will so set Kernel System Variables at boot time for you ReadyNAS (by the way, it's just an OS - Linux, BSD, etc. - feature).
As example I see that /etc/sysctl.d/ contains 00-min-free-kbytes.conf which sets:vm.min_free_kbytes = 16384
option.
It should word that way and, IMHO, I think it's a better clean way to manage Kernel System Variables by creating additional custom configuration files.
By typing the sysctl --all command your system will display all the (available and used by default) variables and by typing the sysctl --system command you system will display the parsed (provided) ones; as example by typing sysctl net.ipv4 you will see all the IPv4 related variables.
