- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear R6230 keeps dropping its gigabit connection to modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware version: V1.1.0.86_1.0.1
I just purchased this router and setup was pretty quick. My pervious router was only 10/100, so the LAN status light on my modem was always orange. With the R6230 the modem's LAN light was now green, showing a gigabit connection with the router. Unfortunately that only lasted a day, when I got up the next morning the LAN light was orange again. The only thing that seems to restore the gigabit connection is to unplug the router, wait a bit, then plug it back in. But like before, it usually only lasts about a day, but sometimes it doesn't last that long. This morning it only lasted about 10 minutes.
Things I tried to rectify the situation, but did not work:
1. Update firmware
2. Reboot the router
3. Restart the modem
4. Disconnect/Reconnect ethernet cable between router and modem.
Any help would be greatly appreciated. Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. what modem is it?
2. have you tried replacing the cable?
3. new devices tend to get a lot of updates at first. sometimes it helps to reset back to factory and reinstall if it got several updates. Have you tried this?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear R6230 keeps dropping its gigabit connection to modem
I was using the new cable that came with the router, but now I switched with the cable that came with the modem. I’ll report back with the results.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its always good to check the little things. Glad you got it working right!
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
