× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear WNDR4500 N900: how to timing WIFI?
angelot
I have the router in question, and I want to know if it is possible to time the switching on and off of the section WIFI. In the manual I found nothing about it. Thanks.
Message 1 of 3
Accepted Solutions
TheEther
Guru
Re: Netgear WNDR4500 N900: how to timing WIFI?
I can't find any manual for the WNDR4500v1, but for the WNDR4500v2 and WNDR4500v3 you can schedule to disable Wireless access through ADVANCED > Advanced Setup > Wireless Settings.  Note, the WNDR4500v2 manual barely mentions this feature on page 87.  The WNDR4500v3 manual on page 111 is better.
Message 2 of 3
All Replies
TheEther
Guru
Message 2 of 3
angelot
Ok, thanks you very match! 🙂
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2571 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
