× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear centria wndr4700 radios down
Gilbertova
Follower
Hello after using my Netgear centria wndr4700 for a long time the wifi radio was automatically turn down and I can't turn them on again. I tryed using the phisical button outside the box as well as by using the software access to the router without sucess.
I had issues in my home network using the newest firmware version (v1.0.0.56) and for this I stay using the previous version which is V1.0.0.52 on a windows sistem. I wonder if the radios problem would be a form of forcing me to upgrade my firmware or is there a way to fix it?
Model: WNDR4700|Centria - Storage router
Message 1 of 2
wcalifas
Prodigy
Re: Netgear centria wndr4700 radios down
press the wifi button again for about 5 seconds and let it go when its powered up. You can always try and downgrade the firmware and see if that revives it.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 628 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
