- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6400V2 after upgrading to firmwareV1.0.4.118_10.0.90 continually get This site can't be reached
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whenever I go to a site that I have not visited before I temporarily get the screen "this site can't be reached" check spelling etc. Usually after a pause it does load the site but sometimes I have to click the reload button, and that the site's page loads normally. This is happening on two windows 10 laptops that are connected wirelessly to the R6400v2 using 5 gigahertz connections. Browser is Google Chrome Version 93.0.4577.82 (Official Build) (64-bit). This started happening after I updated my R6400v2 firmware to version V1.0.4.118_10.0.90. My internet speed tests at 100+ Mbps download and 11 Mbps upload. Anyone else experiencing this?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400V2 after upgrading to firmwareV1.0.4.118_10.0.90 continually get This site can't be reached
we've seen it across multiple product lines on that latest firmware.
I'd downgrade the firmware a version. Then disable auto-updates and wait for the next one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For example, a related discussion:
DNS>PROBE_FINISHED_NXDOMAIN error since latest upd... - NETGEAR Communities
Lots more detail there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I saw yesterday that V1.0.4.120_10.0.91 was available, so I upgraded to it. This new version DID NOT appear to fix the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You don't say which "the problem" has hit you – there have been reports of different issues – so, beyond your first message, it is hard to tell what you are doing and what happens or if you have tried any of the suggestions in those messages.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
You can reduce the hassle of reconfiguring all those settings by creating a backup of your settings before you reset. Then if something is still broken after the reset, and the new firmware has not fixed it, you can restore the device to its pre-reset state.
You could even try restoring the settings even if the new firmware has fixed the problems, but be prepared for the restore to also bring back your problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Previously I posted the following detailed description of the problem:
"Whenever I go to a site that I have not visited before I temporarily get the screen "this site can't be reached" check spelling etc. Usually after a pause it does load the site but sometimes I have to click the reload button, and that the site's page loads normally. This is happening on two windows 10 laptops that are connected wirelessly to the R6400v2 using 5 gigahertz connections. Browser is Google Chrome Version 93.0.4577.82 (Official Build) (64-bit). This started happening after I updated my R6400v2 firmware to version V1.0.4.118_10.0.90. My internet speed tests at 100+ Mbps download and 11 Mbps upload. Anyone else experiencing this?"
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the exact same problem with 1.0.4.118_10.0.90. I went back to 1.0.4.106_10.0.80 and the trouble continued until I did a factory reset. So, I tried 1.0.4.120_10.0.91 again. The problem returned. I tried a factory reset with 1.0.4.120_10.0.91, but it did not help.
I am going back to 1.0.4.106_10.0.80 and just leave it alone until Netgear can figure out what is wrong. I would be happy to send it in for testing if they need to see what is happening.
