Orbi WiFi 7 RBE973
WNDR3400v3: ps4 nat 3
JoylessFire
I DO NOT HAVE THAT MODEL!!!! I HAVE A WNDR3400V3 WIFI ROUTER, BUT IT IS NOT LISTED AS A MODEL TO CHOOSE
Firmware Version
V1.0.1.4_1.0.52
I have the most recent firmware that i'm aware of, I have followed the steps listed in these two links:
http://www.playstationing.com/ps4/how-to-change-your-nat-type-on-ps4-and-ps3/839
https://www.bungie.net/en/Help/Article/11931
I have also set my PS4 to its own IP, i have it also setup with a direct connection through ethernet. i have turned on the default DMZ server to that IP, and have set the NAT filtering to Open, i have restarted my router and my playstation4, leaving them both off for over 2 min, and STILL am getting a Nat type 3. I have had this issue before, but have been ignoring it. I am wanting to have better online connections now, as I am playing more and more with friends, and want to get it fixed now. I have no other ideas to try to get this to work.
I have also made all of those listed ports set to be forwarded and triggered (as thats what my help center showed is used instead of opening ports).  I have talked to my ISP and i've done everything i can with them to make sure its not with them. i have no where else to turn, as i can't really blame my ps4, as i just bought it 2 weeks ago. I had a ps3 before that, and it still gave me nat 3, following the same instructions
Model: CENTRIA (WNDR4700/4720)|Media Storage Router
Message 1 of 11
Accepted Solutions
JoylessFire
Re: WNDR3400v3: ps4 nat 3
Checked my most recent bill from them and they haven't been charging me for one, even though i asked specifically for one... I'll contact them when they're open and hopefully get it fixed
Message 11 of 11
All Replies
TheEther
Guru
Is your ISP box a modem or combination modem/router?
Message 2 of 11
JoylessFire
From what i know, its a combo router + modem
Message 3 of 11
TheEther
Guru
Then you will need to either put it into bridge mode or equivalent such that your WNDR4700 receives a public IP address.  Or convert your WNDR4700 into an Access Point.  Or set up port forwarding on both the combo router + modem and the WNDR4700.
Message 4 of 11
JoylessFire
I only have the one router/modem combo device. My ISP helped me set it up so that its modem to them, and router to me
Message 5 of 11
TheEther
Guru
You have the router/modem and the WNDR3400, right?
Message 6 of 11
JoylessFire
nope, Just the wndr3400v3
Message 7 of 11
TheEther
Guru
I'm confused.  The WNDR3400V3 is a router.  It doesn't have a modem.  What is connected to the WNDR3400V3's Internet port?
Let me ask another way.  Does the IP address of the WNDR3400V3's Internet port begin with either 192.168.x.x, 172.16.x.x, 10.x.x.x or 100.x.x.x?
Message 8 of 11
JoylessFire
10.1.x.x
Message 9 of 11
TheEther
Guru
Ok, 10.1.x.x is a private IP address. That means your ISP is performing NAT. If you don't have access to the ISP's box then you will have to call them and ask for a public IP address.
Message 10 of 11
JoylessFire
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 6883 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
