× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Wifi on iPhone but not not laptop or range extender
collectionbin
All of a sudden our wifi started acting up.  I can access the internet with my desktop via ethernet cable (no wifi card on desktop) through the router and on wifi with my iPhone.  I cannot access the internet with my laptop's wifi nor my father-in-law's laptop, and the wifi range extender no longer picks up the wifi signal either.  What has happened?  I have turned the router off and back on and I have hit the factory reset button.  Our ISP says it isn't anything on their end; it is definitely the router.  Any suggestions?
Model: WNDR3400v2|N600 Wireless Dual Band Router
Message 1 of 9
Accepted Solutions
collectionbin
Re: Wifi on iPhone but not not laptop or range extender
Brother in law reset the router, and now it works. Never mind the fact that I reset it 2 times myself. Unbelievable.
Message 7 of 9
All Replies
Can you use the LAN connection (see below) to get into the device's web interface and check the wifi settings?
http://www.routerlogin.com/
or
http://www.routerlogin.net
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 9
collectionbin
I can do that. What do I need to check?
Message 3 of 9
The wifi settings.
Start on page 107 of the manual:
Wireless Connectivity
WNDR3400v2 | Product | Support | NETGEAR
Message 4 of 9
collectionbin
The 2.4 Ghz band is the one that isn't working properly. If it matters, when we disable security it works.  Once we enable the password, it doesn't allow access.  The 5-G works, but the laptops and range extender don't recognize 5G.
Message 5 of 9
collectionbin
Also, the firmware is  the most recent one: 100521081.  Could it be a bad update?
Message 6 of 9
collectionbin
Message 7 of 9
Message 8 of 9
That is not Netgear firmware that I recognise.
The latest for you is probably: Firmware Version 1.0.0.38
The next round is on you.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 4204 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
