Orbi WiFi 7 RBE973
GS724Tv4 - top speed 100Mbps
joliveira-kbc
Dear Community,
I have a GS724Tv4 which has the latest firmware version:
Product Name GS724Tv4 ProSafe 24-port Gigabit Ethernet Smart Switch, 6.3.1.34, B1.0.0.4
Serial Number 3H024B56002CC
Base MAC Address A4:2B:8C:06:3A:70
Problem: data transfers cannot go higher than 100Mbps. I tested iperf3 on a Hyper-V server, VMware ESXi and a Linux Ubuntu 16.04... Top transfer speed is always below 100 Mbps.
If I plug those servers directly to a computer transfer speed is always higher than 500 Mbps (depending on CPU and NIC).
Please, could someone help me?
Thank you.
Kind regards,
Jose
Model: GS724Tv4|ProSafe 24 ports Gigabit Smart switch
Message 1 of 3
Accepted Solutions
joliveira-kbc
Re: GS724Tv4 - top speed 100Mbps
Hi Schumaku,
Problem was on Ubuntu's 18.04 driver - autonegotiation was failing. Setting up 1000 Mbits full duplex on nic settings fixed the problem.
Thank you for your help.
Kind regards,
Jose
Message 3 of 3
All Replies
schumaku
Guru
The link speed on the ports in the data path indicate full Gigabit (Speed LED: green) or Fast (Speed LED: amber)?
Message 2 of 3
joliveira-kbc
Hi Schumaku,
Kind regards,
Jose
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1151 views
  • 0 kudos
  • 2 in conversation
Announcements
