PaulTaylor24's avatar
PaulTaylor24
10Gb Switch
Just looking for a basic non PoE 24-port 10Gb switch for desktop PC's. Any advise on a basic cost effective model to achieve this?
I have filled the Netgear call back form in over the last three days with no responce so trying this option.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi PaulTaylor24,
    Welcome to the community! :)
    Currently, there is no 24-port 10Gb Unmanaged Switch model.  However, NETGEAR has a 5-port, 8-port and 10-port 10-Gigabit Unmanaged Switches.  Check the following data sheets below:
    XS505M / XS508M Data Sheet
    GS110MX / GS110EMX Data Sheet
    If you really need a 24-port 10Gb switch, you may want to consider the XS728T switch which is a 10-Gigabit Ethernet Smart Managed Switch model.  It has 24 1000/10GBase-T RJ-45 copper ports and it supports VLAN, LAG, network monitoring (SNMP), etc.  Kindly check its data sheet below:
    XS728T Data Sheet
    DaneA
    NETGEAR Community Team
ProSupport for Business
