Orbi WiFi 7 RBE973
Reply
GS105 v3 issue
PTAa
GS105 v3 issue
Hello group,
My GS105 v3 switch behaves oddly.
The switch has three connections:
- Port1: 1000 M cable to the fiber router with Internet and IPTV subscription
- Port2: 1000 M cable to the IPTV STB
- Port3: 10 M Remoterig RRC-1258 MkII controller for remote radio
Whenever the Port3 device is off, all works just fine with the TV.
But when I activate the RRC, both the TV signal and the remote radio stalls.
The Ethernet interface on the RRC-1258 can be changed to 100 M.
When I do that, all works fine.
Why can't the GS105 handle an active port with a 10 M signal?
For some reason, it looks like the total bandwidth is reduced so much that the TV signal stalls.
Message 1 of 5
Guru
Re: GS105 v3 issue
Does the problem travel if you use the other ports?
Possible that this device maybe inducing some odd signals.
Try a different switch to see if the problem follows or not.
Message 2 of 5
PTAa
Re: GS105 v3 issue
Same for all ports.
I also tried it with my FS105 v2, same results.
But the WiFi Plus access point from the IPTV provider handles it well.
Apparently, it does not happen so much when I use a streaming channel.
If it is real-time channel, it is bad.
If I select the Open LogFire channel, is breaks down completely.
That channel has a lot of motion in the picture due to the flames, so the traffic is high.
P-T
Message 3 of 5
PTAa
Re: GS105 v3 issue
No ideas?
P-T
Message 4 of 5
schumaku
Guru
Re: GS105 v3 issue
this sounds like a bug or a big oversight in the QA process....
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 484 views
  • 0 kudos
  • 3 in conversation
Announcements
