- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
6.8.1 on legacy RNS6U boot issues - upgraded usb package?
- Mark as New
- Bookmark
- Subscribe
- Permalink
As i updated my backup NAS RNSU6 today it stuck in shutting down. After rebboting manually it is stuck on displaying "Readynas".
I would love to try an USB firmware recovery but the last version available is 6.7.4 as "Raidar Version".
Any chance an update is to be released soon? i know it is unofficial, but the Backup NAS should be up again keeping all the data of my RNS516 in a save spot.
I was forced to update to OS6 caused by incompabilities in the rsync protocoll.
Hoping for a little help @Skywalker @mdgm-ntgr
Thanks in advance
Best Benedikt
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You’ll need to rename the OS6 firmware .img file to RAIDiator-x86-something to get it to work with USB Boot Recovery for RAIDiator-x86 systems.
However if the problem is not with the firmware internal flash then USB Boot Recovery won’t help.
There are other possibilities e.g. a bad disk
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 6.8.1 on legacy RNS6U boot issues - upgraded usb package?
You can update the USB Boot file with the latest firmware by substituting the new image file for the old one.
Just download the current version of the that you want to use and swap out the firmware file.
Then just follow the directions on the USB Boot and it should work for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am aware that it might be a disk fault too, spin up sounded ok, and LEDs showed no error, but let's see and again thanks a lot. I thought that the package is signed with other keys that's why i asked.
So i will just rename the .bin to raidar*** and check if it works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not raidar***
RAIDiator-x86-***
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks a lot for all the answers, i turned out to be a failed drive on slot 3, S.M.A.R.T. looks good for the disk, rebuild runs currently, let's see if it needs to be exchanged.
Sorry for not suspecting a drive fail, but it seems that on an Raidar unit this is not so easy to find out. In the end i was starting adding one disk after another to see which one prevents the unit from booting.
As said above thanks a lot for all the help, awesome as always
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you solved it. Usually it is pretty easy to tell that you have a failed drive, but there are some corner cases where it isn't.
