- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Adding a 3rd Drive to ReadNAS 204 (1660 hours)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
I got a ReadyNAS 204 and 2 brand new WD Red 5TB. Installing the two drives took the NAS 16 hours. After that I copied 5 TB of Data (95% full) on the NAS. After that I inserted a WD Green 5 TB in slot 3. It says reshaping data will take 1660 hours (one full week). After 24 hours it says 17,5% done, so it seems quite accurate. Is this normal for a system like that?
Greetings
Wolfgang
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you still have this problem after updating to 6.5.0?
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Adding a 3rd Drive to ReadNAS 204 (1660 hours)
Which firmware are you running?
There is a known issue with the performance of hot-adding a disk to the array in ReadyNAS OS 6.4.x. There is a fix for this in the next firmware release 6.5.0.
Which services (under System > Settings > Services) and which apps are you running? If you put a high load on a system with e.g. services and apps that can slow down a reshape as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
the NAS is fresh out of the box with no apps installed and Firmware 6.4.2 running.
I only created one folder, copied 5TB of data into it and linked the folder to my PC.
I'm not using the data on the NAS in any way for now.
If it's only a performance problem I just have to wait, right?
Thanx
Wolfgang
- Mark as New
- Bookmark
- Subscribe
- Permalink
So which services are you running under System > Settings > Services ?
Yes you just need to wait.
- Mark as New
- Bookmark
- Subscribe
- Permalink
SMB, AFP, HTTPS, ReadyDLNA, UPnP and HTTP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
O.K. so it doesn't sound like you are running anything that should slow the sync to a crawl.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After a week the 3rd drive was perfecly ingetrated.
But writing files to the NAS went from 85MB/Sec (2 Discs) to 18 MB/Sec (3 Discs). Is this normal?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Update to 6.5.0 got my speed back to normal.
Should have bought the NAS two weeks later to avoid all the problems 😉
Thanks for all your kind support!
