shardie
Jun 09, 2018Aspirant
Advise please : how should i use my readyNas
Hi all.
ive recently got two ReadyNas’s and have been using both, however im not sure if im using them correctly or at least the best way. Can i get some advice from you guys as i am used to using a Apple Mac mini as a server.
my setup is as follows:
RaedyNAS 2100 (4 x 2tb) - 8tb drive space
ReadyNAS 2120 (4 x 3tb) - 12tb drive space
I do video editing on a iMac that has 7tb internal storage (customised), and an external 4tb usb 3 drive for backup of the video drive in the iMac.
on one NAS i would like all my files shared (music, pictures, vectors, etc etc) where we can all access,....
my question is , should i use the 2120 (12tb) on Raid 0 an then use the 2100 (8tb) as a backup of the 2120? Or
use the 2120 with 2 x raid 0 (6tb) and a backup of the other 6tb on one NAS and use the 2100 only for video files ? Etc etc
other services id like to use is Plex for all our movies (3tb).
What about Resilio vs Backup jobs?
Thanks - ill make a diagram of how we are using it
- shardieAspirant
One more thing..... each NAS has two network ports. Should I be using both or just one? How cab i get the maximum usage if i use both ports? Example, can one port have a different ip from tye other and only be accessed via a certain ip range etc etc
Personally I wouldn't use RAID-0 on either NAS. Though if you really need the extra space on the RN2100 I guess you could do that (backing it up to the RN2120 configured as XRAID).
If your switch supports link aggregation you can use both NICs - ether setting it up as static LAG on the switch (round robin on the two NAS), or you can use LACP on both switches.
How many users do you have?
- shardieAspirant
Well for now there are only 2 fulltime users. Other users are my kids (Plex) and my wife (accessing files now and again.)
It seems from the forums that the 2100 is the better NAS than the 2120, if the RAM is upgraded. Both NAS's are running 6.9.3.
No, my switch doesnt support link aggregation at all.
Why would you not use Raid 0 when there is a constant backup? What Raid would you suggest? For backups, would you suggest using Resilio or just the normal backup jobs?
