× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Apache ReadyNAS #26463387
itze7
Hello,
I reinstalled apache over SSH because my webinterface didnt worked. Now i only get the Apache Start Page. How can i fix this?
Thanks
Model: RN10400|ReadyNAS 100 Series 4- Bay (Diskless)
Message 1 of 10
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: Apache ReadyNAS #26463387
This should be fixed now.
When you installed apache2 via SSH it enabled the default config overriding our config.
Message 10 of 10
All Replies
JennC
Re: Apache ReadyNAS
Hello itze7,
Welcome to the community!
This is something that can be done from the back end. Try contacting support center too as they can have this escalated to get higher tier remote in to your NAS to get this fixed.
Message 2 of 10
itze7
Re: Apache ReadyNAS
Thank you for the answer 🙂 I contacted the support. Hope this works.
Message 3 of 10
mdgm-ntgr
Sounds like you may have made the problem worse by doing this.
Are you able to download the logs using RAIDar?
Can you still access your data? Do you have a backup?
Message 4 of 10
itze7
Hi,
The Data is still on the HDDs. And i can access the logs on Raidar.
Message 5 of 10
mdgm-ntgr
Can you send me those logs (see the Sending Logs link in my sig)?
Message 6 of 10
itze7
Sent the logs 🙂
Message 7 of 10
mdgm-ntgr
I only just got the logs.
I see you have now updated the firmware to 6.4.2.
Are you still unable to access the web admin interface?
Which apps do you have installed?
Message 8 of 10
itze7
Hello,
The Webinterface still not works.
I dont know what apps i installed but i think i installed no one. How can i watch what apps i installed without the webinterface?
Message 9 of 10
mdgm-ntgr
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2692 views
  • 0 kudos
  • 3 in conversation
Announcements
