realtek1's avatar
realtek1
Apprentice
Jun 07, 2016
Backup to ReadyNAS from FTP issue
Hi,
Has anyone experienced issues when backing up from a remote FTP server to the ReadyNAS using the ReadyNAS backup page?
Basically, if one of the files is over 1GB, the file fails to download and the backup job stops after downloading 1GB and also the backup job is marked as "Success" even though in the log it says failed?
I have experienced this with 2 different FTP servers.
Thanks
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello realtek1,
    For the meantime, can you please try setting up FTP backup job for local share of the NAS as source and another share as destination?
    • realtek1's avatar
      realtek1
      Apprentice
      Hi,
      Yes I did try this before and just tried it again and it does seem to work fine when using the ReadyNAS as an FTP server and then backing up into another folder.
      I'm really not sure what could be causing this issue.
      To rule out a timeout issue I decreased my router bandwidth to a rediculasly slow amount so it took a very long time but it carried on going until it hit 1GB for an hour or so.
      • realtek1's avatar
        realtek1
        Apprentice
        Is there anyway I can troubleshoot this issue further? Any logs I can view apart from the ones through the GUI?
        Thanks
  • At least we have the error now. The command line is actually a frontview command so being run inside a script and you just specify the backup job id to run.
    FileZilla does not re-establish a connection from what I can see at that same point.
    Perhaps one of the two uses different connection settings.
    • StephenB's avatar
      Are you running curl 7.43.0 (enter curl --version to see)
      My RN202 has this:
      root@RN202:~# curl --version
      curl 7.43.0 (arm-unknown-linux-gnueabi) libcurl/7.43.0 OpenSSL/1.0.1t zlib/1.2.8 libidn/1.25 libssh2/1.4.2
      Curl 7.43.0 is a bit old (2015 July), but openSSL is current.
ProSupport for Business
